Old Apr 06, 2015, 11:51 PM
Jerry Suhrstedt is offline
Find More Posts by Jerry Suhrstedt
United States, WA, Puyallup
Joined Mar 2015
Quadcopter Lifts off unevenly
Built a new copter, here's what I got:
550 wide quad frame
Turnigy 950 KV motors
Afro 30 A ESC's
Arducopter 2.6
Turnigy 9X Transmitter / Receiver
Installed latest firmware. Went thru entire Mission Planner setup wizard... calibrated GPS, compass, radio transmitter, etc.
When copter starts to take off, one side of the copter starts to tip over and then if I give it enough throttle it will pick up and finally get airborne.
When running in LOITER, seems to hover pretty stable. But then again the LOITER feature is probably compensating for some of the motors.
Is this an APM issue? ESC issue?
Fix?
Jerry Suhrstedt is offline Find More Posts by Jerry Suhrstedt
Old Apr 07, 2015, 12:36 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Gyro doesn't work properly when it's on the ground. Just get it up in the air as quickly as possible when you take off.
Hajile is online now Find More Posts by Hajile
Old Apr 07, 2015, 01:28 AM
Tesadorn is online now
Find More Posts by Tesadorn
United States, MI, Ann Arbor
Joined Sep 2014
Have you double checked your ESC calibration?
Tesadorn is online now Find More Posts by Tesadorn
Old Apr 07, 2015, 02:32 AM
Exidous is offline
Find More Posts by Exidous
Mildly Awesome
Netherlands, LI, Brunssum
Joined Mar 2011
ESC, Gyro and/or accel calibration most likely. Or the CG is off.
Exidous is offline Find More Posts by Exidous
Old Apr 07, 2015, 01:10 PM
Oldgazer is offline
Find More Posts by Oldgazer
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
You need to check all of the above, but I'd wager getting into the air quickly is the key.
FWIW, flybarless helis do the same thing if you sit on the ground too long...
Oldgazer is offline Find More Posts by Oldgazer
Old Apr 07, 2015, 01:28 PM
Joined Sep 2014
HMM... I have 10+ quads... when properly configured mine lift of relatively even!
Old Apr 08, 2015, 07:30 AM
Marc Dornan is online now
Find More Posts by Marc Dornan
United States, IL, Glenview
Joined Nov 2013
550 wide quad frame
Afro 30 A ESC's
Arducopter 2.6
Fix?
This sounds like you have a center of gravity problem. One side is too heavy. Have you checked that it is balanced, weightwise? You can confirm this by enabling motor logging and checking that. Some motors will be working harder in a stable hover.
Marc Dornan is online now Find More Posts by Marc Dornan
Old Apr 08, 2015, 05:10 PM
Joined Mar 2015
My motors are spinning up unevenly. Throttle goes from 0 to superfast with one motor not even turning until the throttle goes way up. Have tried both the "All at once" and the "Individual" calibration several times. For instance, when calibrating using "All at once", I go thru the procedure and when done, the motors spin up super nice with 0 throttle on the stick they don't spin. But when giving it some gas, everything is super linear as the stick goes up.
Then I unplug the power to exit calibration mode, plug battery back in to test and I'm back to motors not moving on 0 stick and when I give a slight amount of gas, the motors shoot up to super fast with no gradual climb with motor 3 not even spinning.
In Mission Planner my THR_MIN setting is 130 but when I change it to either end of its settings, seems to make no difference. I notice that the ESC's are not beeping like the APM specs say they should... just figured that was indicative of the Afro 30A versions.
Any help is super appreciated.
Old Apr 08, 2015, 07:27 PM
Joined Sep 2014
Have you tried calibrating them one at a time with the receiver only? (directly, with FC set to the side)
This can help determine if you escs are acting correctly.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old Apr 08, 2015, 08:34 PM
Joined Mar 2015
Here's a video with much more detailed information.
IMG_4366 (3 min 18 sec)
Old Apr 08, 2015, 10:08 PM
Oldgazer is offline
Oldgazer's Avatar
Joined Dec 2013
When you power off the Quad after you calibrate the ESCs to the radio, either leave the radio on, or turn the radio on FIRST and then power up the quad.
ALWAYS turn the transmitter ON first, then power up the aircraft. When you shut down, you power off the aircraft and then turn the radio off.
Old Apr 08, 2015, 10:17 PM
Joined Nov 2013
https://youtu.be/3FJ_YTDAY68
Your escs and motors are fine I would say. The issue seems to be your gyro/accel calibration. I cannot see your HUD display in the video. Is it level when the quad is level? When you move the quad around is the HUD display moving appropriately? Have you got your flight controller orientation parameters correct? At a given throttle when the one motor is not spinning can you make it spin by moving the quad so that that motor is lower than the others? This will quickly tell you.
Old Apr 08, 2015, 10:25 PM
Oldgazer is offline
Oldgazer's Avatar
Joined Dec 2013
I'm thinkin' its the order he is shutting down after the ESC calibration... NEVER turn the TX off before powering down the aircraft...
Old Apr 08, 2015, 10:48 PM
deeh_46 is offline
Find More Posts by deeh_46
deeh_46's Avatar
Joined Sep 2006
Maybe check your minthrottle or mincheck. I don't have ardu fc but I do check them on Acro Naze board.
deeh_46 is offline Find More Posts by deeh_46
Old Apr 08, 2015, 11:06 PM
Joined Mar 2015
No that's not the issue. Tried using your suggestion but still have the same problem.
Help! Quadcopter wont lift off and hover wiipro Multirotor Talk 6 Dec 27, 2014 07:27 AM
Discussion Tricopter - uneven lift with quick throttle increase stevo1957 Multirotor Talk 5 Nov 26, 2014 08:51 PM
Discussion Quadcopter pulls to the left on lift off Cheekie Bandito Multirotor Talk 10 Mar 22, 2014 01:50 PM
Discussion Nitroplanes Brushless A-10 uneven motor light off help JettaManDan Foamy EDFs 2 Aug 07, 2010 08:50 AM
Discussion Throttle Servo Lifting uneven with Flymentor hidavi Beginner Training Area (Heli-Electric) 11 Mar 18, 2010 11:30 AM
