Old Feb 05, 2016, 12:54 AM
Shumie is offline
Find More Posts by Shumie
United States, CA, Riverside
Joined Apr 2013
Bad batteries?
So I have this battery set up on a Cap 232 with a 120cc Spektrum reciever with Hitec 5645s and the system works great. So I got the same battery setup for a Yak 55 and after a short maiden flight I checked the batteries and they were almost dead. Re testes and the same thing. Bad batteries? It's the set up from Troybuit models.
Shumie is offline Find More Posts by Shumie
Old Feb 05, 2016, 02:35 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Have you checked how many amps the radio and servos are drawing in your Yak? Maybe there's a faulty servo that's drawing too many amps.
abenn is online now Find More Posts by abenn
Old Feb 05, 2016, 02:53 AM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Yup, I agree. We need to know how much you're drawing, specs of the batteries, specs of the bec(I'm assuming you're using one) etc. All you've really told us is "I had a battery in one plane, I put it in another and it went flat."
Ira NZ is offline Find More Posts by Ira NZ
Old Feb 06, 2016, 05:12 PM
Shumie is offline
Joined Apr 2013
How to check?
All right school me how do I check how many amps I'm drawing?
Old Feb 06, 2016, 05:22 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
Put one of these http://www.hobbyking.com/hobbyking/s...arch=wattmeter between the ESC and the lipo.
cmdl is online now Find More Posts by cmdl
Old Feb 06, 2016, 05:24 PM
Shumie is offline
Joined Apr 2013
Right on thanks
Old Feb 06, 2016, 05:25 PM
Shumie is offline
Joined Apr 2013
Gas
Just so you know this is a 50cc gas plane with LiFe batteries no ESC
Old Feb 06, 2016, 09:09 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Please specify exactly what battery you are using.
Then what battery charger are you using and how you set up the charge.
It also helps if you include links to the equipment. That way there will be less speculation in the replies you get.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Feb 07, 2016, 02:44 AM
abenn is online now
Joined Jul 2004
A wattmeter is used for electric models to measure the amps and power drawn by the motor, but may be too insensitive for the, hopefully, small amps draw of the receiver and servos. If you have a digital meter you can make up or buy a short servo extension lead, make a break in its red wire, then insert the harness between the battery and receiver and put the meter probes or clips across the break to measure the amps that are flowing.
Old Feb 07, 2016, 01:25 PM
Shumie is offline
Joined Apr 2013
Right on thanks abenn
Old Feb 07, 2016, 04:00 PM
Shumie is offline
Joined Apr 2013
Setup
http://www.troybuiltmodels.com/items/TBMPOWERSYS4.html
Batteries
Old Feb 07, 2016, 04:04 PM
Shumie is offline
Joined Apr 2013
Charger
http://hitecrcd.com/products/charger...harger/product
Old Feb 07, 2016, 04:09 PM
Shumie is offline
Joined Apr 2013
Mode
In my other identical set up I've charged it in the same manner.
LiFe mode
1.8 amps
auto
Through the JR plug at the switch
Thanks man.
Old Feb 08, 2016, 02:19 AM
abenn is online now
Joined Jul 2004
OK, so the first thing to do is still to find out how many amps the system is taking. Since we now know you have a bunch of electronics there to power the ignition as well as the radio, I suggest you measure the amps with only the radio connected, and then again with everything connected. That way you can narrow down where the amps are going.
1.8A charge rate sounds okay for the battery, by the way, so long as you're letting the charger complete the charge. It could take up to 2 hours at that charge rate.
Old Feb 08, 2016, 10:51 AM
Shumie is offline
Joined Apr 2013
Watt meter
Getting a watt meter today
Sold Traxxas XO1 with bad ESC and batteries ton2di Cars - Cars and Parts (FS/W) 2 Apr 26, 2015 06:51 PM
Help! bad charger or bad battery, how to tell which one? giantkevmiester Batteries and Chargers 11 Jan 02, 2012 11:04 AM
Discussion eflypower.com bad align battery & bad service OzDragonFlyer Vendor Talk 3 Sep 19, 2007 06:17 PM
Bad battery... NImh bad , bad... gulio Batteries and Chargers 7 May 24, 2005 08:16 PM
Help! bad motor or bad battery beginningdave Beginner Training Area (Aircraft-Electric) 3 May 14, 2005 03:11 PM
