Old Jan 08, 2016, 04:52 PM
lu4414 is online now
Find More Posts by lu4414
Padawan
Brazil, SP, São Paulo
Joined Jan 2015
Help!
How far i can discharge a battery safely?
Hi
I`m going to build my first tricopter (also my fisrt eletric model) so i want know whats the mimimum voltage per cell in my battery that still safe and will not short my battery life too much, but also will let me fly for a reasonble time?
Any recomendations will be apreciate!
lu4414 is online now Find More Posts by lu4414
Old Jan 08, 2016, 05:14 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
3.7V/cell. I shoot for 3.8V/cell.
cmdl is online now Find More Posts by cmdl
Old Jan 08, 2016, 05:17 PM
kamcoman is offline
Find More Posts by kamcoman
Douglasville, GA
Joined Sep 2004
Lots of Tri-copter info in the Multirotor Forums here on RC Groups. To know how to answer your minimum voltage question we would need to know what kind of battery you are talking about. Lithium Polymer battery packs typically should not be discharged lower than a resting voltage of 3.7V per cell. This usually means you can run them down to about 3.3V under load. When I built my multirotor, I got a lot of info from the Scratchbuilt MultirotorForum.
kamcoman is offline Find More Posts by kamcoman
Old Jan 08, 2016, 05:25 PM
losi man is online now
Find More Posts by losi man
losi man's Avatar
United States, MI, Detroit
Joined Oct 2015
110% agree....3.3/2.4 ubder load.. let stand a few min cells rat 3.7..
losi man is online now Find More Posts by losi man
Old Jan 08, 2016, 06:01 PM
James_S is online now
Find More Posts by James_S
United States, WA, Woodinville
Joined May 2014
That's about 50% discharged at that level. You can safely fly them lower than that, but I try to store them around 3.7V/cell to maximize life.
James_S is online now Find More Posts by James_S
Old Jan 08, 2016, 06:42 PM
FiftySlicks is online now
Find More Posts by FiftySlicks
United Kingdom, Scotland, Edinburgh
Joined Jun 2014
3.7v unloaded/resting voltage is about 20% capacity remaining, this is what you want to aim for to maximise the lifetime of the pack. Discharging below 20% once or twice won't cause much harm but you don't want to make a habit of it (though if the choice is between going below 20% or crashing...definitely sacrifice the pack for the sake of the craft).
In order to get 3.7v resting voltage you'll have to go somewhere below that in flight. Depending on the current draw and condition of the battery that might be anything from 3.6v down to 3.3v. Below 3v/cell you begin damaging the cells so avoid that.
FiftySlicks is online now Find More Posts by FiftySlicks
Old Jan 08, 2016, 06:57 PM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
More like 40%. But yes, I can fly them lower. I prefer to get them close to storage charge instead.
Old Jan 09, 2016, 11:33 AM
Padawan
Joined Jan 2015
Thanks by all inputs...any other trough of lipo will be aprecciate!
Old Jan 10, 2016, 01:40 PM
Joined May 2014
It depends what I'm flying, but I often run mine a bit lower, and then the last flight of the day I only go down to storage charge. It's just a matter of preference.
Question How do you know how many amps an 18650 LiPo can safely discharge? zach26276 Batteries and Chargers 15 Nov 17, 2015 11:52 AM
Discussion How far can i push my batterys? bananawhiz Multirotor Talk 0 Jun 08, 2014 07:08 PM
Question How far down can I drain my batteries? Electrofish Batteries and Chargers 18 May 10, 2014 10:37 AM
Discussion How high/far away can I safely fly with my setup? Smokescreen38 Beginner Training Area (Aircraft-Electric) 12 Apr 04, 2006 09:28 AM
How far can you push an axi 2808-24 safely... papasmurf Power Systems 24 Mar 23, 2005 12:43 PM
