Old Sep 24, 2015, 03:29 PM
Edge767 is offline
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
New Product
E-Flite (Staufenbiel) Red Bull Edge 540 BNF Basic 1320mm/52"
Staufenbiel Red Bull Edge 540 BNF Basic (2 min 10 sec)
Key Features
Officially licensed Flying Bulls trim scheme
AS3X® technology for rock-solid flight stability
4-channel control including a steerable tail wheel
Two-piece, plug-in wings and stabilizers with composite tube spar
Spektrum™ 6-channel AR636A DSMX® receiver (installed)
High-torque, 32-size brushless 760Kv motor (installed)
60-amp brushless ESC w/3A SBEC (installed)
4× Spektrum digital, metal-gear micro servos (installed)
Lightweight construction with durable Z-Foam™ material
Realistic spinner and 3-blade propeller
Clear canopy and cockpit detail including pilot figure
Needed To Complete
2400mAh 4S 14.8V 25C Li-Po battery
AC/DC 4S Li-Po Compatible Balance Charger
4+ channel, full-range 2.4GHz transmitter with Spektrum™ DSM2®/DSMX® technology
Completion Level: Bind-N-Fly Basic
Fuel Type: Electric
Material: Foam
Wingspan: 52 in (1320mm)
Length: 50 in (1270mm)
Flying Weight: 3.7 lb (1680g)
Motor Size: Brushless Out runner Motor 3948-KV760
Recommended Motor Battery: 14.8V 2600mAh 25C Li-Po
Minimum Required Radio: 4 Channel
Servos: 4 × 17g digital metal gear servo
Trimscheme Colors: Licensed Red Bull trim scheme
CG (Center of Gravity): 3.15 in (80mm) from leading edge
Propeller Size: 13×5 3-Blade
Minimum Speed Control: 60A Brushless ESC
Aileron: Yes
Elevator: Yes
Rudder: Yes
Flaps: No
Retracts: No
Approximate Flight Time: 6 minutes
Landing Gear: Yes
Steering: Yes
Approximate Assembly Time: Less than 1 Hour
Edge767 is offline Find More Posts by Edge767
Old Sep 24, 2015, 04:53 PM
Hawk600 is offline
Find More Posts by Hawk600
United States, NH, Nashua
Joined Mar 2011
I love the looks and I am a big fan of Edges but not sure if it was the wind or a pilot not familiar to the plane but it is not flying nice on HH video, it is all over the place and even landing seemed a little challenging.
Hawk600 is offline Find More Posts by Hawk600
Old Sep 24, 2015, 06:27 PM
carrizojim is offline
Find More Posts by carrizojim
Crashing RC's since 1978
carrizojim's Avatar
United States, CA, El Cajon
Joined Mar 2014
Didn't look too impressive did it? Not crisp and locked at all, unlike most AS3X models . I'm wondering if that was even the HH version in the video. If that's how it flies, I would rather go for something from Precision Aero/3DHS. Price is not bad though.
carrizojim is offline Find More Posts by carrizojim
Old Sep 24, 2015, 08:43 PM
Bloosee is offline
Find More Posts by Bloosee
SoCal fair weather flyer
Bloosee's Avatar
United States, CA, San Diego
Joined Jan 2012
I was interested until I saw that video, I'm wondering if they did the demo in the wind because it did not look locked in at all. If one of my planes couldn't fly a decent straight line I'd sell it.
Bloosee is offline Find More Posts by Bloosee
Old Sep 24, 2015, 08:51 PM
Rampage is online now
Find More Posts by Rampage
What tree?
Rampage's Avatar
United States, CA, Twentynine Palms
Joined Aug 2005
It's the same airplane as the FMS Edge 540 V3 sold at Motion with an AS3X receiver added.
With most of my dealings with AS3X, I'd rather not have it.
Rampage is online now Find More Posts by Rampage
Old Sep 24, 2015, 09:10 PM
Bloosee is offline
Bloosee's Avatar
Joined Jan 2012
Bingo! I forgot about the HH/FMS deal.
And I agree, I am not a fan of the AS3X recievers, they are more trouble than they are worth and I don't like the need to set up my planes with an iPhone. I use the Bavarian Demon which is basically plug and play simple, yet performs amazingly well.
Old Sep 25, 2015, 11:23 AM
Paul1PA is offline
Find More Posts by Paul1PA
Spool 'er up!
Paul1PA's Avatar
United States, FL, Oxford
Joined Mar 2010
This is the first time I've seen this name Staufenbiel affiliated with an Horizon product. Noticed the new Red Bull F4U Corsair also uses the same branding. Are they the designer or manufacturer?
Paul1PA is offline Find More Posts by Paul1PA
Old Sep 25, 2015, 07:01 PM
carrizojim's Avatar
Joined Mar 2014
For the price of a Cortex -$250!!!!!!!!!, I can buy a whole plane or two ARFs. So not worth it. On a Carbon Z Cub, the difference between a PNP and the AS3X model is $20. Where I fly next to the ocean it's always windy and the AR636A works very well because it comes pre programmed for that plane. No fuss, no muss and NO PROGRAMMING.
Old Sep 25, 2015, 07:08 PM
Bloosee is offline
Bloosee's Avatar
Joined Jan 2012
Well, yeah, the Cortex is a great deal now that they dropped the price to $249, they used to be $350. Seriously though, they are worth it too me as they are just that freakin' good! Plus it's very easy to move one unit between many planes, takes less then 5 minute to move between planes. I have had up to 5 planes sharing a single gyro so that is really just about 50 bucks per plane. I fly a lot of 3D midsized balsa planes so the Cortex is really designed for that type of thing, I wouldn't put any other gyro in my planes.
I actually liked the AS3X that came in my Carbon Z Cub, it worked pretty well straight out of the box and didn't have any of the strange stuff the AR636 seems to have.
Old Sep 25, 2015, 11:07 PM
What tree?
Rampage's Avatar
Joined Aug 2005
Neither. They're a German-based FMS reseller.
Old Sep 27, 2015, 11:07 AM
KonstantinosSt is offline
Find More Posts by KonstantinosSt
Joined Jul 2015
So this plane is the follwing plane:
Blue
http://www.fmsmodel.com/airplanedeta...irplane&ID=135
Red
http://www.fmsmodel.com/airplanedeta...irplane&ID=153
I prefer those two colors. I believe it will be a good plane. What you believe?
So FMS is been bought from HH? I want one of this and one Extra 300 from FMS or HH.
KonstantinosSt is offline Find More Posts by KonstantinosSt
Old Sep 27, 2015, 07:39 PM
Hawk600 is offline
Joined Mar 2011
Well, FMS doesn't make bad planes and honestly the AR635 rx that I tweaked the gains flies awesome so I assuming the video was made on a bad day with maybe lots of gusts or again the pilot wasn't that familiar with the plane because it is clear the plane is all over the place. I liked the red bull scheme but FMS seems more visible in the sky. I will wait to see a good hands on review.
Old Oct 25, 2015, 03:53 PM
Chill Master is offline
Find More Posts by Chill Master
Chill Master's Avatar
Österreich, Wien
Joined Jul 2011
This Product is in stock ...
... at last 😊
Chill Master is offline Find More Posts by Chill Master
Old Nov 18, 2015, 09:57 AM
blkvette is offline
Find More Posts by blkvette
United States, GA, McDonough
Joined Jan 2014
just picked up one of these , one of the best looking foamie planes i have seen paint is flawless
much better than a parkzone or eflite . i hope to maiden tommorow as the weather is bad today
blkvette is offline Find More Posts by blkvette
Old Nov 18, 2015, 03:38 PM
Joined Jul 2015
Video... Video... Video...
For Sale E-Flite Edge 540 QQ 280 BNF unixphreak64 Aircraft - Electric - Airplanes (FS/W) 3 Jan 26, 2016 11:10 AM
Wanted Kyosho Red Bull 540 Edge Crazyflyer20 Aircraft - Electric - Airplanes (FS/W) 2 Apr 28, 2015 05:33 AM
Sold E-Flite Edge 540QQ BNF Basic + Optional Zippy Compact & Nano-Tech Batteries jgalexander Aircraft - Electric - Airplanes (FS/W) 4 Oct 13, 2013 08:43 PM
Sold E-Flite Edge 540QQ BNF Basic + Optional Zippy Compact & Nano-Tech Batteries jgalexander Aircraft - Electric - Airplanes (FS/W) 0 Sep 18, 2013 02:11 PM
For Sale 3dhs edge 540 47" bnf (red bull scheme) for sale ryanburns22 Aircraft - Electric - Airplanes (FS/W) 11 Sep 02, 2011 01:31 AM
