Old Apr 23, 2014, 01:29 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Build Log
Resurrection of an older "M" Class boat
Thought I would start a new thread on my efforts to restore/resurrect an old " Marblehead boat.
Some probably would have ash-canned this one, and after it arrived I had similar thoughts. On further inspection, the most work will be to restore the hull - both shape as well as internal structure. It arrived as "Hull Only" with a lot of flex or too thick gel-coat cracks. Also have a suspicion that there may have been some port/starboard collisions (bumps?) in it's past life. If you look close in photo #1, you can see a hull in need of repair and fairing. This will be biggest challenge.
Anyway, spent some time getting the skin deck off and evaluated the internal wood structure. With all the garbage removed, and with certain wooden structure to repair or replace, I think this will be a fun challenge. I doubt that it will be competitive outside of club racing, and budget is pretty well limited. It certainly won't be on the high technology side of things. Based on previous questions posted, it was set up for a swing rig, however it may go to a standard rig just for ease of building and rigging. Jury still out on that one.
Second photo is the hull leaning on my truck, and as you can see - it is pretty sparse inside. A lot of the glue joints have failed, as have some of the wooden fillets. As noted, it doesn't appear any of the internal wood has been waterproofed - thus leading to some wood failure. Many of the glue joints look like they didn't adhere to hull or the joints have failed. Even the rudder block on bottom of the hull can be raised and glue lifts from hull along with rudder tube.
Looking into the future, I think a nice veneer wood deck and rig would look nice, especially with a light tan/gold/brown hull paint job. Just thinking for now. Will continue to post photos as work goes forward.
Dick L. is offline Find More Posts by Dick L.
Old Apr 23, 2014, 01:43 PM
palmcoastfl
Joined Aug 2003
Looks like a good project, good luck
will be watching this one
tigman is offline Find More Posts by tigman
Old Apr 23, 2014, 08:17 PM
Brighto?
Mike Denest's Avatar
United States, DE, Newark
Joined Dec 2003
That's an interesting bulb shape, sort of laminar flow. What does it weigh?
Mike Denest is offline Find More Posts by Mike Denest
Old Apr 23, 2014, 08:29 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
It was part of one of the photos, but then didn't show up. I think it was reused for "another" yacht. I've tried to get weight and also dimensions of keel to use as a starting point, however I've been unsuccessful. Will probably have to start all over - do a float and start loading it up to reach what I suspect is the waterline. At least it will get me in the "ball park".
The boat design is a TURNER, so perhaps someone will know of one in much better shape so I can get some dimensions. Right now, what I have is only a smidgeon better than a piece of 2x4 and if it was a 2x4 at least I could see and mark waterline.
Will let you know if I hear or find out.
Dick
Old Apr 24, 2014, 03:11 AM
Joined Apr 2002
scaling a very small photo the bulb is about 10" long 2" diameter, applying simpsons rule to a similar laminar flow section shows it would be 14-15 lbs up to a max of 16.
Looking at that hull shape I wouldn't be too concerned about its designed waterline length Dick but run with the apparent trend of loading up to a maximum waterline.
Some of the photos I have seen suggest that effectively overhangs albeit short, hardly noticable ones are back in fashion.
Robert May is offline Find More Posts by Robert May
Old Apr 24, 2014, 06:42 AM
United Kingdom, Stourbridge
Joined Nov 2012
Robert
your estimated weight calculation looks as though it might be 50% (100%) to heavy. generally boats from the mid eighties to present carry about 8lb of lead.
the american designs at that time weighed in about the 10 - 12lb region
mark dicks is offline Find More Posts by mark dicks
Old Apr 24, 2014, 08:04 AM
Joined Apr 2002
all I have done is scaled a 10" long 20% max chord laminar flow section into a spread sheet and it threw out a range given the inaccuracy of a low res photo
Photo perspective would make a difference if the bulb were only 9" long
Old Apr 24, 2014, 08:50 AM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
I was just "guessing" at 6 to 7 lbs. with a keel length of 17 to 19 inches as a starting point.
Old Apr 24, 2014, 11:24 AM
Brighto?
Joined Dec 2003
Originally Posted by mark dicks View Post
Robert
The Toad I am restoring weighed @ 14 lbs. 10 of that is the bulb.
Old Apr 24, 2014, 03:46 PM
United States, MA, Wenham
Joined Jan 2007
The keel is 17 1/4" when measured from the bottom of the boat to the top of the lead.
The fin itself was similar to the Pinter fin, and may have even been an early version of the pinter fin.
The ballast is 2" by 10" and might be laminar. Who cares, boats of this age are all laminar, so you get your start somewhere then figure out how to make them better.
The Keel and bulb weigh 7lbs 7oz together. Using deduction, the keel should be 7oz (Carbon) and the ballast should be 7lbs.
That is the target weight you should shoot for, but can go up or down from there within reason with good results.
The keel slot is square, so you shouldn't have any trouble putting a fin in there, and having to conform it to it's keel slot. The slot is built right, and goes all the way up to the deck. So inclusive of the part inside the boat, this whole keel is 21.5" long.
Yes, the fin was recycled into "Another" Marblehead as the fin & bulb combo is the ideal target weight for Terry Allen's MAX, which I own the moulds for, and have moved toward making some boats. The 17" draft is also ideal for Redds Pond.
So yes, the hull was free, but the ballast is being recycled.
If you don't have any local draft limitations, why not experiment with a long-fin. Get something nice & deep.
Keep in mind that the weight of the fin will likely increase the longer you go, so decrease your target bulb weight. Proabably only a couple ounces, but stay as close to 7lbs 7oz as you can and you'll be good.
Good luck with the build. Great to see it's started.
Everybody starts somewhere. You've just gotta start, regardless of what others might tell you.
Hell, I threw my first attempt in the dumpster, and if you end up doing the same here, you're out exactly nothin, but would have gained everything in the way of experience.
And that's the only thing that makes a fast boat.
And when somebody tells you it's not competitive, just agree with them and carry on.
After a couple years of being not competitive, that guy's gonna wonder why he can't pass you on the race-course.
breakwater is offline Find More Posts by breakwater
Old Apr 24, 2014, 03:59 PM
Joined Jan 2007
Oh, and when that happens, be sure to stick your nose up in the air and tell them that their boats just aren't competitive.
It'll taste good when you do.
Old Apr 24, 2014, 07:20 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
@ Breakwater: Thanks for weight and dimensions. I guess I wasn't too far off with my initial guesstimates of weight and length for keel and bulb.
Building boats in the past I used some shaped "lumber" for a keel - making it a general foil shape and leaving it deeper than normally accepted. At the top of the keel, I left a longer tab sticking up from the keel box and held the keel in place with some "serious" spring clamps. To be safe, I cross drilled the blade and inserted a stainless shackle pin as a safety measure to back up the clamps. This allowed me to sail with an extra deep keel, assess the heeling angles at wind strengths normal for my locale, and when I had the righting moment pretty close to the desired average angle of heel, I simply cut off the top of the keel to appropriate length. The keel was then shaped a bit further for refinement, and again the boat was sailed with a bit more performance. Finally, the keel blade was covered with glass or carbon, and I used the wood core blade for a season or two. While it was slightly heavier, it gave a good feel for a quick-to-make keel and could always become a male plug down the road if I needed to reduce weight.
The "lumber core" usually consisted of a series of redwood, cedar or white pine strips. I laminated at various grain directions and finished with a double coating of WEST resin - before adding the cloth. I never had a keel failure, lamination or warp and any bending (side-to-side) was not sufficient to worry about. This one may have several carbon tubes/rods running the length to aid is stiffness.
Old Apr 24, 2014, 09:29 PM
Joined Jan 2007
Chip, Chip, Chip away.
Eventually it's no longer chipping and you start plowing.
Tonights project-
"Resurrect" a B Rig.
Good luck!
Old Apr 30, 2014, 07:40 AM
SailingJunkie's Avatar
United States, CT, Essex
Joined Mar 2013
Hi Dick,
When you say its a TURNER, would that be John?
Think he did a series of designs called Wa Wa's This may be one of them.
SJ
SailingJunkie is offline Find More Posts by SailingJunkie
Old Apr 30, 2014, 07:47 AM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
I would have to defer that question/suggestion to "Breakwater" - as he rescued the boat from the dumpster,, and offered to me for cost of freight. With that sort of financial investment, I can do a bunch of "workbench modifications" and the cost remains negligible.
I really would love to hear from an owner (or previous owner) to obtain some further historical info on this particular design. Any help with the history is appreciated.
Discussion Model boating in New Jersey, M.A.C.K. & Legend Model Boats ken_nj Dock Talk 84 May 30, 2014 07:24 AM
Question Modeltech P-51 ARC it's an older Hobby People plane RcjunkieAZ Fuel Plane Talk 9 Feb 08, 2014 07:18 AM
Help! Suggest a foamie design for an older clubmate V-Man Foamies (Scratchbuilt) 21 Oct 14, 2013 12:32 PM
Discussion Control rod advice for an older HLG _AL_ Hand Launch 2 Sep 23, 2013 04:34 AM
Discussion I own a RC boat older than me, will be using it for an arduino project, need help! huseyinozsut Micro and Sub-Micro Boats 3 Nov 25, 2012 04:52 PM
