Old Jan 31, 2015, 02:33 PM
vollrathd is online now
Find More Posts by vollrathd
vollrathd's Avatar
Joined Jan 2007
Cool
Three Phase Alternator - Three Phase Motor?
This video shows a Tera Hobby brushless motor directly connected to a Hyperion ZS3020 motor. Spinning the Tera motor shaft, either by hand, or with a power drill instantly drives the Hyperion motor in lock step rotation. Placing a bit of drag on the driven motor's bell results in slowing down the battery operated drill driving the "alternator".
No computer magic is involved, these two motors are simply directly wired to each other. Reversing two wires also reverses the "motors" rotation.
I've also done this with various Hacker motors, and other brands. Not all combinations will work. Like using two identical motors will not work. One seems to need to be slightly bigger than the other. All of them will turn the driven motor, but by "Cogging", not by lock step. Also, direct very low resistance connections must be made between the two motors. The voltages involved are low, and currents relatively high. Common Radio Shack type jumpers will not do the job.
The purpose is to show that our brushless motors are somewhat like a synchronous three phase motor, driven by an ESC that allows a DC battery to drive the motor.
Three Phase Alternator and Motor (0 min 23 sec)
vollrathd is online now Find More Posts by vollrathd
Question cheap esc on 12v three phase motor hozone DIY Electronics 12 Mar 12, 2013 11:03 AM
Build Log FMS Mini F16 Build and Mods (alternative to Phase 3 EF16) Si Goodchild Foamy EDFs 15 Dec 06, 2010 06:00 AM
Why three phase AC? landru Power Systems 55 Jul 29, 2008 02:33 AM
Question two phases out of three aint bad?... theKM Power Systems 7 Apr 13, 2007 03:22 PM
Three-phase, Y-connected, 60 Hz Induction Motor Analysis mach Scratchbuilt Indoor and Micro Models 0 Feb 06, 2002 05:13 PM
