Old Jan 22, 2016, 10:55 AM
mdon is offline
Find More Posts by mdon
France, PACA, Marseille
Joined Feb 2013
WLTOYS V912 and Turnigy 9X
Hello
My V912 flight ok with my TX 9x .... but only less than 1mn and falls down.
i must rebind and take off.
is it a signal lost ? and why ? i have changed once my PCB ...
is it a batt too low ?
mdon is offline Find More Posts by mdon
Old Jan 22, 2016, 06:03 PM
kiwi_craig is online now
Find More Posts by kiwi_craig
Slideways at warp speed.......
kiwi_craig's Avatar
New Zealand, Auckland
Joined Mar 2014
The jst battery plugs overheat and the low voltage cuts in. Cools almost instatenous allowing rebind. This is a common problem with jst plugs
Two options, dismantle and solder the wires to the crimps, or cut off and fit a better plug
Hobbyking has a really nice tee plug, like a scaled down deans, perfect for these size heli's
kiwi_craig is online now Find More Posts by kiwi_craig
Old Jan 22, 2016, 09:13 PM
Crash Override is online now
Find More Posts by Crash Override
is always breaking stuff :D
Crash Override's Avatar
United States, MI, Charter Twp of Clinton
Joined Dec 2014
Originally Posted by john13 View Post
hello, I have v912 but after a few crashes main blades not rotating, but the motor is working, what can I do to fix it?
How about posting a video of what it's doing. If the motor is turning, but the blades aren't, it won't take off.
Crash Override is online now Find More Posts by Crash Override
Old Jan 22, 2016, 09:14 PM
OrangeBird is offline
Find More Posts by OrangeBird
Wow, the sky is clear
OrangeBird's Avatar
Canada, QC, Chicoutimi
Joined Aug 2012
Hi mdon
I had the same problem with the FX071c and it was the power switch was defective. In all my FX071c, I removed the power switch ..... I had two cut off like yours ....
See section #11 photos 41 and 41a for bypass this power switch.
And kiwi_craig solution is good too....T connector male female
When the red JST connector becomes hot, red becomes darker due to heat generated in this connector.
The JST connectors for power is not a perfect choice. The choice for the connector in FX067c is better....
OrangeBird is offline Find More Posts by OrangeBird
Old Jan 24, 2016, 03:46 PM
hifinsword is offline
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
Originally Posted by SUGARELY View Post
By replacing the tail fx067c you have reached a high point of reference for all of us (65 flights )!
Does It contrasts well with the V913 with brushless drive motor?
Although the tail walkera looks good and fine, after the sad experience with the 22E (2.4 gh) and another for hardware, software and prices, i don't trust more in this company;
This company will have 'certainly reached levels more' high, i wish it great success!! At the same time I continue with the use of motor h.bee to see the border line.
I can't compare the FX052 tail motor to a BL motor since I haven't tried one. The motors I am using haven't needed changing so no need to swap out.
I have swapped out the main drive motor for a BL one and highly recommend it.
Don
hifinsword is offline Find More Posts by hifinsword
Old Jan 25, 2016, 09:05 AM
mdon is offline
Joined Feb 2013
Ok, thanks, i'll try with direct batt. on good plugs ... without jst and without switch ...
Old Jan 25, 2016, 11:16 AM
SUGARELY is offline
Find More Posts by SUGARELY
ad maiora
Italy, Veneto, Verona
Joined Jan 2016
thanks to hifinsword ; i have ordered to b.good tail motor of fx067 like Orangebird and kiwi_craig.
SUGARELY is offline Find More Posts by SUGARELY
Old Feb 01, 2016, 06:03 PM
Joined Dec 2014
ESky Honey Bee Super 370 motor
I know some people here have tried it and liked the results.
I have one I plan to try, and I am curious as to what pinion gear seemed to work best for others.
Anyone?
Old Feb 01, 2016, 07:41 PM
kiwi_craig's Avatar
Joined Mar 2014
I found it no better than the stocker, they really need 3S voltage. try the same size to maybe plus one more tooth. Don't expect any miracles............
A likely better brushed motor is the Walkera "400" as fitted in the master CP and 400GPS
Old Feb 01, 2016, 08:22 PM
Joined Dec 2014
I melted a board with 3S - not doing that again.
I have 8T, 9T and 10T pinions - I think I'll go with a 10T.
I'm not after a speed demon - stock performance is fine for me on this bird. I want to keep my camera and other attachments for it, I don't want to cram a bunch of electronics under the canopy by going brushless, and I want better motor longevity with being able to repair the motor instead of replacing it when the brushes are done. So if the Esky motor compares roughly equal to stock, I'm in. I have this bird for easy relaxing flight. (Also, everything I've found on the Walkera motor shows it to be internally brushed - and so I'm not interested in it.)
When I want excitement, I have a Blade 300 CFX and a Nano CP X for real speed and serious agility.
Old Feb 05, 2016, 02:54 AM
john13 is offline
Find More Posts by john13
Joined Sep 2015
V 912 (1 min 5 sec)
john13 is offline Find More Posts by john13
Old Feb 05, 2016, 02:59 AM
Trevorh is offline
Find More Posts by Trevorh
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Sounds like the main gear or motor pinion might have lost a few teeth?
Trevorh is offline Find More Posts by Trevorh
Old Feb 10, 2016, 11:03 AM
SUGARELY is offline
ad maiora
Joined Jan 2016
brushless tail set SOS
1) The central engine with nem works perfectly; it, applied to tail motor, doesn't stop: it accelerates and decelerates continously (with nem and with extreme);
2) i have tried, with esc (from 20) and standard engine, welding 3 wires (white-red and black) on the PCB BOARD (with different dates of production); the tail doesn't move (from control there is power); i have read various links, but i haven't found the right one.
wHY ? thank you.
to CRASH OVERRIDE
with the super motor H.Bee i am good and i feel safe (sometimes i control the brushs) ;i have already consumed a pinion. i think, i have already done outputs as for 2 motors and the brushs are even more half: i use pinion with 9,10 teeths .
Old Feb 12, 2016, 05:30 PM
OrangeBird's Avatar
Joined Aug 2012
Hi Guys
Take a video with a quad is incomparable, no jello effect.
http://www.rcgroups.com/forums/showp...postcount=1194
Old Feb 12, 2016, 07:23 PM
kiwi_craig's Avatar
Joined Mar 2014
i couldn't get the brushless tail kit esc to work, still in the "Useless Parts" drawer......
Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) jameschen072 Micro Helis 475 Mar 14, 2016 09:33 AM
Mini-Review WLtoys V922 6-Channel CP Flybarless Helicopter Mini-Review FyreSG Micro Helis 8315 Jan 29, 2016 09:21 PM
Discussion WLToys V912/NEX helicopter jameschen072 Micro Helis 41 Jan 27, 2015 10:17 AM
Sold Two (2) Nine Eagles Solo Pro V 4-Channel Fixed Pitch 45 Flybar Coaxial RTF Helis ShaneXman Aircraft - Electric - Helis (FS/W) 4 Mar 09, 2012 10:23 AM
