Old Dec 12, 2014, 11:53 AM
PoorDad57's Avatar
United States, VA, Smithfield
Joined Dec 2014
3S or 4S Difference for Ducted Fan
I have a 70mm 3000KV ducted fan, well two actually, that I'm installing in a scratch built RA-5C Vigilante. I believe they will draw about 43 amps. I used 45 amp ESCs (cutting it close). I have 3S 2200 25C 11.1 volt batteries. Should I spring for 4S batteries? The plane can handle additional weight. Would I get more thrust from the fans using the higher voltage batteries? I apologize if my newbie question is stupid and has been answered a couple of hundred time previously.
PoorDad57 is offline Find More Posts by PoorDad57
Old Dec 12, 2014, 12:12 PM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Well KV is RPM per input volt so if you up the voltage you will see more RPM's and theoretically, more thrust. Can the fan motors handle the voltage? Check the specs. Can the ESC's? You're already pushing your luck with the ESCs. Also, 25c isn't much for EDF use.
On the other hand, thats a bad a$$ project!! Looks great! Please PLEASE send me some pictures when you get it going.
barracudahockey is online now Find More Posts by barracudahockey
Old Dec 12, 2014, 12:18 PM
PoorDad57's Avatar
Joined Dec 2014
Thanks! Yes, the motors list 4S as recommended battery. I didn't do a good job of research before buying everything. Got the amps matched ok Battery 55A, ESC 45A, Motor 43A, but didn't understand the 3000KV thing and how that related. That's good news if I can gain some thrust (It is already pretty good). Plane weighs a touch over 4 lbs. Here's a couple more pics. I'm reworking the flight controls right now. When these photos were taken I had internal servos, but there is too much play in the linkage. I rigged it for Elevons, so the entire surface moves. I'm going to put the servos outside and connect directly to the Elevons. Won't be as pretty but it will work far better. I want this thing to fly twice. I think it's going to be pretty fast.
Old Dec 12, 2014, 12:32 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Your amps will go up with 4s so you will need a larger ESC. What fans and motors do you have? How much battery do you think the plane can carry? on most of my 70mm jets i use 3600kv and 4s as a base line but I also use use 4s 4000 mah batteries.And 70amp ESC this gives about 800 watts. We need to know what the motors can handle. If they are Mega 16/15/3 you dont want much more than 45 amps or they wont last long. What do you think the plane will weigh?..
OK your post came in as I typed this...Do you have a amp meter?
Old Dec 12, 2014, 12:48 PM
PoorDad57's Avatar
Joined Dec 2014
No, don't have a meter. Here's the motor information. I'm cutting it close on the ESC, and apparently not turning up to rated RPM with the 3S?
Specification
70 mm duct Fan
3000 KV brushless Duct Fan motor for 70 mm Duct Fan
Recommend to use 14.8v 4s lipo battery
For most RC Jet EDF Model
Weight: 44 grams (70mm Duct Fan) / 98 gram (Motor)
the max thrust :1250g
max current : 43A
recommend esc : 50A
recommend number of cells : 4s lipo battery
Package included:
2x 70mm Duct Fan Unit with 3000KV motor
Old Dec 12, 2014, 03:03 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
I recommend that you get a watt meter and 4s batteries...And go from there. But they should work for your project. Just try to have a bit of extra size in the ESC. if not you may over heat them.Even if you have to go to 60 amp . And get 40c batts or better if you can
Old Dec 12, 2014, 04:57 PM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
3000Kv is good for 4s. If...you are running a low count blade fan. With a average 5 blade fan, WeMoTec, Eflite, etc you will get around 30-35A and 415-430W. And you will only need 2200Mah packs. If you use a high blade count fan, that motor will burn up on 4s.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Dec 12, 2014, 05:55 PM
PoorDad57's Avatar
Joined Dec 2014
So I will get more thrust with the 4S vice 3S?
Old Dec 12, 2014, 08:00 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Yes if the parts can handle the extra current/Amps
Old Dec 12, 2014, 08:25 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
If you are getting 43 amps on 3S which is approximately 477 watts. Going to 4S will result in the watts going to at least 850 watts which is 57 amps. So make sure all your gear can handle the new power level plus 10% to be safe.
The Don is online now Find More Posts by The Don
Old Dec 12, 2014, 11:21 PM
Joined Jan 2014
I'm loving your Vigilante. I want it! A 64mm, 70mm, or 80mm version would be a treat.
Alpha.MotionRC is offline Find More Posts by Alpha.MotionRC
For Sale or TRADE Great planes sonic blast ducted Fan JET Techman63 Aircraft - Electric - Jets (FS/W) 1 Oct 18, 2014 12:36 AM
For Sale E-flite BL15 Ducted Fan Motor, 3200Kv with ducted fan unit coolgg Aircraft - Electric - Airplanes (FS/W) 1 May 04, 2014 03:48 PM
For Sale E-flite BL15 Ducted Fan Motor, 3200Kv with ducted fan unit coolgg Aircraft - Electric - Power Systems (FS/W) 0 May 04, 2014 03:45 PM
For Sale E-flite BL15 Ducted Fan Motor, 3200Kv with ducted fan unit coolgg Aircraft - Electric - Power Systems (FS/W) 0 Apr 05, 2014 08:57 PM
