Old Jul 16, 2014, 11:39 AM
Joined Jul 2014
Question
Naza lite and Sbus R3008SB
Hello guys, and ladies (if there is any )
I just get my new radio Futaba T10J with RX R3008SB.
So i try to connect this set to my Naza lite via Sbus, but its not working...
I have check the RX an set it in mode B (7ch + Sbus), connected it to the port X2 on Naza and port 8 on RX, then i went to settings on Naza software and select D-Bus connectivity. Nothing happened
I call Futaba support but it seems that there is only one guy who works for Futaba and he is constantly on the phone with another costumers...
Any way RX R3008SB and naza works perfectly on traditional mode.
DJI support confirms that naza lite can handle Sbus connectivity, but they was unable to troubleshot this problem...
Any help highly appreciated, thank you in advance!
Vova4o is offline Find More Posts by Vova4o
Old Jul 16, 2014, 06:22 PM
Joined Jul 2014
And we go up!
Old Jul 16, 2014, 11:39 PM
United Kingdom, Wales, Bridgend
Joined May 2014
Have you tried the bottom sbus port?
Stuzx61978 is offline Find More Posts by Stuzx61978
Old Jul 17, 2014, 12:32 AM
Joined Jul 2014
The horizontal port it's sbus2 not s bus.
And yes I did try that one as well
Old Jul 18, 2014, 04:29 PM
Joined Jul 2014
And the last time up
Old Jul 19, 2014, 03:19 PM
Joined May 2014
Silly question m8, when you selected dbus in naza assistant did you write to controller ??
Old Jul 19, 2014, 07:28 PM
Joined Jul 2014
I'm not quiet sure what you was trying to say, and how to do that?
Old Jul 20, 2014, 03:05 AM
Joined May 2014
When you change settings within naza assistant, they need to be written to the naza controller.
With the naza lite, if I remember correctly, it a button in the top left of the screen.
Old Jul 26, 2014, 07:01 AM
igetcha69's Avatar
United Kingdom, England, Romford
Joined Apr 2014
did you get this sorted mate? I'm experiencing the same issue....connected to the Sbus on the receiver but the Naza Lite wont recognise any connection
igetcha69 is online now Find More Posts by igetcha69
Old Jul 26, 2014, 01:17 PM
Joined Jul 2014
Sorry for the late reply, no unfortunately i'm stuck with this question and the same point where im started.
However i came to the store who sold me 10J controller, and the was unable to help me also.
we spend few hours trying to hook up transmitter with any other receiver, but was unable to do so.
I have a strong feeling that Sbus simply not working on Naza lite, and DJI tech support does not know about that...
Old Jul 26, 2014, 04:15 PM
Joined May 2014
I have the naza lite on my f450 hooked up with sbus, and I use futaba reciever and t8j, and it works fine.
Old Jul 26, 2014, 06:13 PM
igetcha69's Avatar
Joined Apr 2014
yeah i too have a Naza Lite setup using Sbus but that is with an RS2008SB receiver....myself and the op are having issues with the new Futaba R3008SB receiver that comes included with the Futaba T10J transmitter
the R3008SB is capable of using regular Sbus as well as Sbus2...the Naza Lite can be used with Sbus but no matter what i try the Sbus port of the R3008SB will not work
what is strange though is that i have the Sbus cable plugged in and in addition i have channel 5 plugged in for my gimbal pitch control and channel 7 plugged in for the camera switcher (TBS Discovery pro...i would normally use channel 8 for the camera switcher but on the R3008SB channel 8 is for the regular Sbus)
the Sbus doesn't work and the camera switching doesn't work, but rather strangely the gimbal pitch control works perfectly
so the Naza Lite is most definitely capable of using Sbus which means that there must be an issue with the R3008SB receiver itself
Old Jul 26, 2014, 11:17 PM
Joined Jul 2014
Then there is only one way to find out, get another receiver that works with T10J and plug it in i guess.
I will try to find one in nearest future.
P.S. we have try to plug servo to channel 8 - Sbus and servo went crazy, so we assume that Sbus is working.
Old Jul 27, 2014, 02:12 AM
Joined May 2014
I took a look at the PDF online, are you sure it's not to do with the sbus programming within the tx?
Don't know how you'd go about it, but the t10j allows you to plug servos directly into the back of the tx , to assign channel numbers.
I'm wondering if it's some weird problem, with the naza not knowing what channels are assigned to what?
Old Jul 27, 2014, 06:45 AM
igetcha69's Avatar
Joined Apr 2014
hi mate,
i had been wondering the same thing but can't really work out how i would go about it. when you go to that section in the tx it asks you to connect a servo to the back of the tx but I'm not sure what happens after that point yet as I've not read up on it in the manual (which i will take a closer look at now! lol)
i do recall the manual showing an actual servo being connected to the back of the tx though so I'm unsure of how that would translate to connecting it to the Naza Lite?
Wanted dji f450 with naza lite or naza lite alone Planest28 Aircraft - Electric - Multirotor (FS/W) 1 Jun 17, 2014 10:25 AM
Help! Frsky X8R Sbus and Naza FC acuralegendz Multirotor Electronics 10 Jan 31, 2014 04:57 AM
Sold NIB DJI NAZA V1 + GPS and NAZA LITE + GPS guyst Aircraft - Electric - Multirotor (FS/W) 3 Oct 03, 2013 10:04 AM
Discussion Naza Lite, Naza V1 or Naza V2 vibration issue - confused Alex84 Multirotor Talk 2 Aug 29, 2013 11:02 PM
Discussion DJI NAZA with Futaba FASST Sbus Rx (R6303)? iskoos Multirotor Electronics 7 Nov 23, 2012 12:44 AM
