Old Jan 22, 2015, 04:34 PM
montaukmsc is offline
Find More Posts by montaukmsc
Joined Aug 2013
Need CG for hobby king F86 90mm fiberglass
I finally got around to finishing the hobbyking F86 90mm fiberglass plane and would like to be sure of the CG I'm hoping those of you who have and flown it could give me some input to the measurement that best works. With the tiny elevators I don't want to be to nose heavy an run out of elevator. Another thing is I used the stock 5 blade change sun fan with the het Typhoon 650-68-2250 and with 6cells drawing 105amps its producing 7.3lbs of thrust the plane loaded weighs 6.75lbs so it should be great what pisses me off Is I also just built the HK viper version 2 and purchased the Extreme Rc jet fan/HET combo which is suppose to draw the same amps on 8s and produce 10lbs of thrust well it also only produced 7lbs. The only thing with the F86 is I have no front duct nothing would fit with that . But back to my original question on the cg?
montaukmsc is offline Find More Posts by montaukmsc
Old Jan 22, 2015, 05:35 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
My scratch built F86 had the balance point about 1" ahead of the TE at the root. I determined this by the use of a "chuck glider"
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Jan 23, 2015, 07:43 AM
Joined Aug 2013
Thanks but im looking for someone that has the same plane to get a starting point
Old Jan 23, 2015, 08:12 AM
Joined Sep 2000
I also have an HET F 86 with a 36" wing span. The BP for that plane is 4" ahead of the TE, measured at the root.
If no one else has any comments, you might go on line and look for a balance point calculator. I used to have one but my PC but it crashed so I can't supply a URL.
Old Jun 12, 2016, 01:24 PM
Zenoaheli is online now
Find More Posts by Zenoaheli
United States, NM, Albuquerque
Joined Nov 2015
I suggest building a bigger elevator the guy at our field couldn't get his to rotate at 2000 input watts 8 lbs flying weight
Zenoaheli is online now Find More Posts by Zenoaheli
For Sale hobby king 90mm L-59 $875 crated and shipped mikeeyy1993 Aircraft - Electric - Jets (FS/W) 0 Dec 01, 2014 04:57 PM
For Sale 90mm hobby king viper jet billy0428 Aircraft - Electric - Jets (FS/W) 3 Oct 22, 2014 04:24 PM
Sold 90mm EDF ViperJet Hobby King Fiberglass Red7fifty Aircraft - Electric - Jets (FS/W) 4 May 29, 2014 12:16 AM
Discussion Hobby King F-18 EDF 90mm Jet Fiberglass 920mm cprice Electric Ducted Fan Jet Talk 1 Feb 18, 2013 08:39 PM
Sold HK Fiberglass 90mm F86 Sabre RCFEVER Aircraft - Electric - Jets (FS/W) 2 Oct 02, 2012 12:00 PM
