Old Dec 18, 2014, 12:44 PM
Joined Dec 2014
brushless setup for a 32" scale boat
Hello! Looking for advise on what people are using for brushless setups on scale boats. I build my own fiberglass hulls, which are not built for speed. They are of a lobster boat style, not of the fast maine style but a larger boat with more draft. The last one i built was 32"x12" and used a dumas 12volt motor direct drive with a 2 1/2" wheel which made it go about a walking pace. I am in the process of making another hull same style but i would like for this one to get up on plane. I am just starting to learn about using brushless but from what i gather i should be looking for a kv rating from 700-1000 and run 6-7.2 volts? Also does it need to be water cooled? I am trying to stay as cheap as possible also. Any input appreciated! I attached a picture of the hull i am trying to replicate
chartersj is offline Find More Posts by chartersj
Old Dec 18, 2014, 12:54 PM
BOATBring Out Another Thousand
bbenner's Avatar
United States, ME, South Bristol
Joined Sep 2013
I run a 35-48 900kv NTM propdrive outrunner motor with a 2" prop on my 36" lobster boat on 9.9 volts, more than enough power to get on plane.
Can we get a few more pics of your hull? I make a few downeast style lobster boat hulls myself.
Brent
bbenner is online now Find More Posts by bbenner
Latest blog entry: Busy!
Old Dec 18, 2014, 01:07 PM
Joined Dec 2014
nice! I will put up a picture when i get home from work. So your motor does not get hot enough to worry about water cooling? what about your esc?
Old Dec 18, 2014, 01:13 PM
bbenner's Avatar
Joined Sep 2013
The motors just fine with no water cooling, it doesnt see a ton of wide open time. I do run the watercooling on the esc mostly because it has the tube, I use Hobbywing Seaking 120 amp escs so they are way more than enough.
Brent
Old Dec 18, 2014, 01:48 PM
Joined Dec 2014
I would also do water cooling for the esc. Would this one work with the 900kv ntm?
http://www.hobbyking.com/hobbyking/s...C_4A_SBEC.html
Old Dec 18, 2014, 03:02 PM
bbenner's Avatar
Joined Sep 2013
Ya it should work fine.
Brent
Old Dec 18, 2014, 08:08 PM
Mopar Musclecar fanatic
xx29l9's Avatar
Oregon
Joined Oct 2008
Is it just me or does the hull in the picture look a lot more of a displacement type than a planing type hull? Not sure how fast you will be able to push the water aside with that shape. But it is always fun to try....
bob
xx29l9 is offline Find More Posts by xx29l9
Old Dec 18, 2014, 09:09 PM
Joined Dec 2014
bob
Your right its not exactly built for planing, however there is a few of these hulls here where i live that are around 50-55ft long and 20 foot wide and with close to 1000hp they will plane out and do over 20kts. Quite spectacular to see actually.
Old Dec 18, 2014, 09:15 PM
Joined Dec 2014
Here is the last boat i made from scratch
Old Dec 18, 2014, 11:07 PM
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Very nice model, welcome to the forum. Where do you hail from?
Mark
the goon is offline Find More Posts by the goon
Old Dec 19, 2014, 07:41 AM
bbenner's Avatar
Joined Sep 2013
Very nice! You have a mold for that hull? Any others?
Brent
Old Dec 19, 2014, 09:05 AM
Joined Dec 2014
thanks. Im from grand manan, new brunswick canada. I dont have a mold but would like to make a couple molds but have no idea how to go about doing it
Old Dec 19, 2014, 10:02 AM
Plures Naves Quam Mentes
sound sailor's Avatar
United States, NY, Westchester
Joined Jul 2011
Nice model! Very similar to those I saw visiting Alma, NB.
Bill
sound sailor is online now Find More Posts by sound sailor
Old Dec 19, 2014, 10:41 AM
bbenner's Avatar
Joined Sep 2013
I know how to do it but I dont think I can explian it well enough for someone to learn. If you have the experience with fiberglass its not super hard but is fairly time consuming. I make my molds in 1 part so I dont have to deal with a seam and they dont have a flange so I grind them down and pop finished parts.
Brent
Old Dec 19, 2014, 11:20 AM
Joined Dec 2014
do you make them anything like this guy does?
How To Make Fiberglass Part - Part 1 (9 min 9 sec)
Sold wtt: 1/8 scale for brushless 10-14th scale cyclist01 Cars - Cars and Parts (FS/W) 0 Nov 26, 2014 06:44 PM
Help! How do I setup a rudder for a Cabin Cruiser type boat? The_Angry_Saxon Scale Boats 2 Nov 05, 2014 05:24 AM
Build Log Rc Perkasa torpedo boat ,Hooben,1/32 scale hassn Scale Boats 22 Oct 05, 2014 11:23 AM
Help! Need info for eledctrical power for a 1/32 scale PT boat rabosr Scale Boats 18 Jul 07, 2014 09:55 PM
Sold Genesis Brushless Boat - Mid 60mph setup birdy233 Boats (FS/W) 1 Jun 11, 2014 11:03 PM
