Old Jun 02, 2015, 11:12 AM
Lucas86 is offline
Find More Posts by Lucas86
S800G,v922,Master CP,V450D03
Lucas86's Avatar
United Kingdom, England, Greenford
Joined Jan 2013
HK-450TT PRO V2 6S build begins
Finally took a plunge and ordered parts for 6S 450 clone build.
Any comments and suggestions are welcome
Here's what I picked (with UK buddy codes where available) :
HK-450TT PRO V2 Flybarless 3D Torque-Tube Helicopter Kit (Align T-Rex Compat.) (UK Warehouse)
$66.16
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
NTM Rotor Drive 450 Series 1700KV / 930W (UK Warehouse) No buddy code
3x TGY-306G-HV High Voltage Ultra Fast/High Torque MG Digital Alloy Cased Servo 3.7kg (UK Warehouse)
$21.99
For tail servo I will probably use Align DS525M, which currently sits on V450D03
2x Turnigy 1300mAh 6S 35C Lipo Pack (450 helicopter HK/Trex/Rave/E4 etc) (UK Warehouse) No buddy code
Tarot ZYX-S2 From ebay.co.uk
Hobbywing Platinum 50A V3 Brushless ESC w/7A BEC (EU Warehouse) No buddy code as I used one
Hobbyking™ 0.5M Hardened Steel Helicopter Pinion Gear 3.5mm Shaft - 12T
$2.05
Hobbyking™ 0.5M Hardened Steel Helicopter Pinion Gear 3.5mm Shaft - 11T
$2.05
Edit:
ZYX-S DSM2/DSMJ Compatible Satellite Receiver Cable (UK Warehouse)
OrangeRx R100 DSM2 Compatible Satellite Receiver
Lucas86 is offline Find More Posts by Lucas86
Last edited by Lucas86; Jun 13, 2015 at 10:40 AM. Reason: Added satellite receiver and ZYX S2 cable
Old Jun 02, 2015, 11:36 AM
dteel is offline
Find More Posts by dteel
I failed to crash a heli once!
dteel's Avatar
United States, CA, El Cajon
Joined Mar 2014
Looks like you have it well planned out.
Curious why you chose that flight controller, it's a fair controller from what I've heard but I've also heard that it was lacking in several aspects. I don't have one so I didn't dwell on the data and can't remember what was said. I've been sticking with using the K-Bar as I found it easy to set up and very reasonable in price.
Any thought to the receiver?
It should be a very nice flying helicopter when it's all said and done.
dteel is offline Find More Posts by dteel
Old Jun 02, 2015, 12:48 PM
Lucas86 is offline
Lucas86's Avatar
Joined Jan 2013
Picked ZYX S2 cuz I already have one.
It's on my V450D03. And I found setup very easy. And as far as my skills let me tell, it holds very well. It's very stable.
Probably will hook up sat receiver straight to ZYX. Thinking of one of hk orange sat receiver.
Old Jun 02, 2015, 05:29 PM
Taffysparky is offline
Find More Posts by Taffysparky
Cymru am Byth
Taffysparky's Avatar
United Kingdom, Wales, Llanelli
Joined May 2015
Receiver
I've just ordered the lemon 6ch plus sat from ebay £18.99 for my build.
servos for cyclic came today aswell as a new tail rotor connector can't wait to carry on with build.
it's my 1st one and using the same zyxs2 as u.
it's a second hand model but I enjoy tinkering so I'm rebuilding it
Taffysparky is offline Find More Posts by Taffysparky
Old Jun 03, 2015, 02:11 AM
Zaphod69 is online now
Find More Posts by Zaphod69
Australia, SA, Adelaide
Joined Feb 2013
Good luck with the build. Looking forward to seeing it completed
Zaphod69 is online now Find More Posts by Zaphod69
Old Jun 13, 2015, 10:54 AM
Lucas86 is offline
Lucas86's Avatar
Joined Jan 2013
Edited first post - added satellite receiver and converter for ZYX S2.
Got all parts now.
Kit came with incorrect main shaft.
The groove for the collar is too high. So the shaft moves up and down around 4 mm (see video)
Tried up side down but it's even worse - groove goes down main bearing.
Will have to contact hobbyking with that.
Other concern :
Got some white residue close to solders on satellite receiver (see photos)
Ebay seller says all of the ones he sells are similar.
Yet I'm not sure if I can use it safely.
Any opinions on that?
So far tried it with orangerx R620 and it seems it bound properly (solid led on both)
Old Jun 13, 2015, 12:21 PM
Lucas86 is offline
Lucas86's Avatar
Joined Jan 2013
Can't get right channel mapping on zyx s2.......
I've got a bad feeling about this.....
Old Jun 15, 2015, 01:10 AM
Lucas86 is offline
Lucas86's Avatar
Joined Jan 2013
So far no luck with R100 satellite :-(
Research shows that few people got it working with Spectrum satellite but still couldn't find any reasonable information.
I think I'm going to have to use conventional receiver, although that's not what I was planning when buying ZYX S2.
If I would know I would consider different FBL unit.
I wanted to avoid using bigger conventional receiver with three additional cables...
Got quite dissapoiting reply from hobbyking regarding incorrect main shaft.
I showed them video and described the issue but of course that's not enough for them.
I will try to post more details in the evening.
Old Jun 17, 2015, 01:24 AM
Lucas86 is offline
Lucas86's Avatar
Joined Jan 2013
This is how ridiculous Hobby King can be....
My message to them:
"Hi,
450 class heli kit I ordered recently came with wrong main shaft.
The groove for collar is too high on main shaft. Because of that the main shaft can move up and down.
Here is link to video to show you what is the problem:
https://goo.gl/photos/6beHNQfBCBjzhW647
I tried to flip main shaft up side down but it was even worse - groove went down under main bearing.
Could you make sure you send me the correct part for that kit??"
And their reply:
" Hi Lukasz,
Thank you for patiently waiting for our response, Lukasz. We sorry to know that there is an incorrect item in your order. We would like to solve this concern in as immediate as possible. For us to do that, please provide the following:
1. Photo of the item which you have received.
2. Photo of the correct item (from the website). You may encircle the correct part from the product listing.
3. SKU of the incorrect item (if available).
We are committed in making sure that this incident will not happen again.
For us to be able to provide you the compensation for the incorrect item (if proven), kindly access to RMA - Warranty Returns. This does not mean that you will have to return the rest of the items back to us. This is the new process to file a claim. This will help us to solve your concern in the most rapid way.
Once logged in to your HobbyKing account, please follow the instructions in this link: http://support.hobbyking.com/hc/en-u...cles/202704344.
https://hobbyking.zendesk.com/attach...RMA+form+2.JPG
https://hobbyking.zendesk.com/attach...n+RMA+form.JPG
https://hobbyking.zendesk.com/attach...+by+Sparks.JPG
Once done, we will forward the information to our Product Specialists to check your claim. If proven, then we will immediately proceed to the resolution.
We look forward to your response and cooperation. Please do not hesitate to contact us back. Thank you and take care.
Regards,
Jordine L.
HobbyKing Support Team"
Now don't get me wrong.
I do understand we are not paying for top quality but at least I would like to have a complete kit, with no incorrect parts. Their customer service is a joke.
You can laugh now, enjoy :-D
Not only I described the problem but I also included a video to show what I mean!
I'm assuming if I would send them photos in the first place, they would ask for video...
"wrong main shaft" - can this be misunderstood?!?! :-D
It's sad how they always try to deter/discourage customers.
(times up, got to go)
Old Jun 17, 2015, 02:11 AM
spykez is offline
Find More Posts by spykez
Where's the swimming pool
spykez's Avatar
Joined Jul 2011
Lucas, besides checking both ends of the shaft.
1. check your bearing blocks are facing the right direction. I know some bearing blocks designs are actually asymmetrical top/down.
2. Look for shims. You may need a couple of 5mm inner dia shims.
3. Not sure what kind of shaft you have. If it's not lipped you may be able to move the collar.
spykez is offline Find More Posts by spykez
Old Jun 17, 2015, 02:27 AM
Joined Feb 2013
My message to them:
And their reply:
Lol you were lucky. My 450 kit was missing the entire tail! That was never resolved and I ended up buying one off eBay instead.
Old Jun 17, 2015, 04:32 AM
Lucas86 is offline
Lucas86's Avatar
Joined Jan 2013
Thanks for input guys :-)
1. I don't think that's the case. Main frame came already assembled. I think I would notice if it wouldn't be assembled correctly. But I will double check that once I get home
2. Good tip, thanks.
3. It is lipped / grooved (is it same thing? ) Would it be ok to put the collar on the shaft with no lip?
The collar wouldn't move if there would be no lip??
I think hobby king should change name to "hassle king"....
Did they ask you to provide photo of missing item? :-D
Old Jun 17, 2015, 05:08 AM
spykez is offline
spykez's Avatar
Joined Jul 2011
Some heli's do not have lipped main shafts to stop the shaft dropping through the bearing blocks.
These heli's usually require that 'stop' from a collar i.e. MSH. I believe the first few Align micros were the same.
However, I think the newer Aligns have lips instead of a collar, as the lip will stop the shaft from moving.
Generally, if you have a lip, there's no collar. Like I'm rebuilding a 250 I crashed, the current main shafts are lipped and no collar.
My advice, check that your frame is built correctly, check for shims. If the shaft is collared, you may be able to move it. If in doubt buy an Align shaft.
Old Jun 17, 2015, 05:28 AM
spykez is offline
spykez's Avatar
Joined Jul 2011
Actually, I just googled hobbyking for the lols...
Is this what you have? (Assuming pic doesn't change)
If it is, it looks like you can adjust the collar height. The grub screws should, in theory, hold down the collar. Use thread locker though.
Between that and the align shaft with the lip I showed you earlier, however, I'd go for the Align shaft, quite frankly. Maybe tarot makes a similar one.
Old Jun 17, 2015, 06:14 AM
Lucas86 is offline
Lucas86's Avatar
Joined Jan 2013
Yup, that's the one.
And the groove is simply too high.
When I'm trying to move the collar down and tighten grub screws it just pops a bit higher.
Lip/groove position doesn't let me tighten grub screws.
I think Florida Heli had same issue with his tarot kit. He described it better than I do.
I think I can work around this with my rotatory dremel tool, yet I still would like hobbyking to provide the CORRECT part for the kit I paid for.
Thanks for help and tips anyways :-)
Wanted HK-450TT PRO V2 3D or similar kit mewrongway Aircraft - Electric - Helis (FS/W) 0 Jan 05, 2015 03:02 PM
Discussion HK-450TT Pro V2 Flybarless RexSmith Electric Heli Talk 10 Apr 04, 2014 03:05 PM
Alert Buddy Code for HK-450TT Pro V2 Flybarless and the items required to build it!!! RexSmith HobbyKing 0 Feb 22, 2014 10:49 PM
Discussion HK-450TT PRO V2 Flybarless 3D Torque - Which servos UFOking Mini Helis 3 Jan 17, 2014 09:00 PM
Discussion HK-450TT PRO V2 or CopterX 450 pro? Advice needed. carl1864 Electric Heli Talk 5 Nov 09, 2013 07:49 PM
