Old Sep 02, 2015, 07:53 PM
Whitehouse is offline
Find More Posts by Whitehouse
Joined Jan 2015
New Product
JJRC H22 3D Inverted Flight 2.4G 4CH 6-Axis Mini RC Quadcopter
http://www.banggood.com/JJRC-H22-3D-...5346232014041X
Description:
Brand: JJRC
Item name: H22 3D Inverted Flight Mini RC Quadcopter
Frequency: 2.4G
Channel: 4CH
Gyro: 6 axis
Quadcopter battery: 3.7V 220mAh 15C(Included)
Remote battery: 3 x AAA dry battery(Not included)
Charging time: 30mins
Flying time: 5-7mins
Color: Green,Blue,Red
Features:
3D Inverted Flight, 360 degrees rollover
With Headless Mode,no need to adjust the position of aircraft before flying .
One key to return function makes it easily to find the way home.
4 Channel which can do ascend, descend, forward, backward, left sideward fly, right sideward fly and rolling 360
It has 6-axis gyro which can have more stable flying and be easy to control
Lightweight airframe with nice durability
Battery protection
Function: Up / down, Forward / backward, Swerve, Turn left / right, 360 degrees rollover, One key to return, Headless mode, 3D inverted flight
Whitehouse is offline Find More Posts by Whitehouse
Old Sep 04, 2015, 07:25 AM
1auriec is online now
Find More Posts by 1auriec
Australia, VIC, Melbourne
Joined May 2011
Looks interesting. The Banggood description is tantalising, as the photos seem almost deliberately to conceal details, such as the battery bay. It does seem from the charger cable though that this quad uses the micro Losi plug, similar to the JJRC 1000.
Also no dimensions are given, though since it uses a 220mAh battery, you might guess it is very similar in size to the JJRC 1000. For that one the standard battery is I think a 250mAh one, although it can also use various other ones even up to 380mAh.
Its shape looks somewhat similar to the JJRC 1000, although the feet have a significantly different shape, somewhat similar to the Eachine H8.
In any case, although I would like one of the new 3D small quads, I won't be buying this one, as there is no Mode 1 version.
1auriec is online now Find More Posts by 1auriec
Old Sep 04, 2015, 07:40 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
If the battery is 220 mAh, that would be the same as the H8 3D, which has identical battery capacity stock.
SoloProFan is online now Find More Posts by SoloProFan
Old Sep 04, 2015, 08:08 AM
Lycan Animal is offline
Find More Posts by Lycan Animal
Vox Furry Regem
Lycan Animal's Avatar
Joined Dec 2014
Transmitter looks similar to H8 3D as well which might explain why the H8 3D uses the same protocol as the H20 if it's a rebrand of the JJRC H22?
Better LED's than H8 3D and looks too.
Lycan Animal is offline Find More Posts by Lycan Animal
Old Sep 29, 2015, 05:59 AM
Vox Furry Regem
Joined Dec 2014
Coupon at GeekBuying: JERTHZNH $18.99
Better yet it's the Dark Knight version (I don't know, the colour I guess?)
JJRC H22 Flying (1 min 45 sec)
Old Oct 25, 2015, 09:05 AM
t00nz843z is offline
Find More Posts by t00nz843z
Joined Jul 2013
Move over Eachine/JJRC H8. You got competition!
This little micro quadcopter has something for everyone. It's a nice stable flier at beginner's rate, very maneuverable at intermediate, and just insane yaw at expert. Oh did I mention that it can flip and fly inverted? The only thing that would have made it perfect is if they'd have put better lights on it.
Find it here from Banggood.
Pro's
- Stable flier at beginner, maneuverable quadcopter at intermediate, insane yaw rate at expert.
- Great flipping quadcopter, with both 360 and 180 degree flips.
- Flies very well both normal side up and upside down.
- Headless mode and fast one key return
- Relatively inexpensive.
Con's
- Poor lighting. Not a good night flier.
- Can be unstable combining expert rate with headless mode. Insane yaw rate pirouettes just ain't an option
And here's my flight with it
JJRC H22 The Spinning Inverted Drone (12 min 13 sec)
Description:
Brand: JJRC
Frequency: 2.4Ghz
Channel: 4CH
Gyro: 6 axis
Colors: Green, Blue, Red
JJRC H22 Features:
- 3D Inverted Flight, 360 degrees rollover
- Headless Mode, One key return.
- 4 Channel throttle/pitch/roll/yaw
- 6-axis gyro stabilization
- Lightweight durable airframe
- Battery protection
Functions: Up / down, Forward / backward, Swerve, Turn left / right, 360 degrees rollover, One key to return, Headless mode, 3D inverted flight
Package Includes:
1 x JJRC H22 RC Quadcopter
1 x Transmitter
1 x 3.7V 220MAH battery
1 x USB cable
4 x Blade
1 x Manual
Description:
t00nz843z is offline Find More Posts by t00nz843z
Old Oct 25, 2015, 09:13 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Considering the transmitter, and the programming of the rates, I wonder if this is just a H8 3D with a different body shell? Can it also do a barrel roll when you give forward, then center sticks, and while it still moves forward due to the built up momentum, hit flip button and aileron, to make it roll?
Old Oct 25, 2015, 05:16 PM
Irock1985 is offline
Find More Posts by Irock1985
Noob
Irock1985's Avatar
United States, CA, Moreno Valley
Joined Jan 2012
Tmart has them on sale right now for $19.99 with the red color in stock at their US warehouse
Click Here for Tmart Link
Also does anyone know if this will bind to WL Toys 2x2 transmitters?
Irock1985 is offline Find More Posts by Irock1985
Old Nov 04, 2015, 04:43 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Well, It is a H8 3D with different body shell. Or the H8 3D is a H22 3D with different body shell, if the JJRC came first. H22 3D also has add-on board on the receiver, all in all making this quad almost 3 g heavier than the H8 3D.
I find it handles a breeze a little less than the H8 3D, probably due to the bigger surface area of the body and frame. In medium rates it flies about the same as the H8 3D, on high rates the H22 has the crazy yaw that we've come to love, and hate, from other quads like the H20 and H8 Mini. Nice to impress spectators, but not very practical when flying around, as it results in a lot of turns spinning out. Much prefer the max yaw rate of the H8 3D, or the Floureon H101, which has fast yaw but a very proportional rudder response, so it's still quite easy to make wide turns.
Also, don't crash the H22 3D, as the paint looks great, but chips off easily.
Btw, anyone found good replacement motors other than stock? It uses an odd motor size, 7 x 17 mm, instead of the more common 7 x 20 and 7 x 15...
Old Apr 06, 2016, 11:09 AM
theimacman is offline
Find More Posts by theimacman
Flyin' Ryan
theimacman's Avatar
United States, IL, Champaign
Joined May 2012
Here is my review:
JJ R/C - H22 (3D) - Review and Flight (13 min 11 sec)
theimacman is offline Find More Posts by theimacman
Old Apr 16, 2016, 01:28 PM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Just ordered one of these. Anyone have a link to larger batteries that fit inside the H22?
BGR is offline Find More Posts by BGR
Old Apr 16, 2016, 01:47 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Nanotech 260 mAh should fit, as well as Tmart 300 mAh batteries.
Check this topic, under "Eachine H8 3D": http://www.rcgroups.com/forums/showthread.php?t=2456519
Old Apr 16, 2016, 02:20 PM
BGR is offline
BGR
BGR
Foam Junkie
Joined Dec 2003
Thanks for the info. I assume the battery compartment on the H22 is similar in size to the H8 3D.
Old Apr 16, 2016, 02:41 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
It is, although the plastic on the H8 3D is more flexible, so it might allow a "fatter" battery to still be fitted.
For Sale JJRC H9D 4CH 2.4G 6 Axis Gyro 0.3MP Camera FPV RC Quadcopter with LCD Screen Golden FlyGuy912 Aircraft - Electric - Multirotor (FS/W) 2 Feb 05, 2016 11:39 AM
New Product Eachine h83d mini 2,4 g 4ch 6- axis inverted flight one mey return rc quadcopter nickden Mini Multirotors 19 Aug 30, 2015 10:31 AM
Discussion Syma X8G 4CH 8.0MP RC Quadcopter 2.4G 6 Axis Gryo With Headless Mode HD Camera 3D Fli GeekBuying Geekbuying.com 0 Jul 13, 2015 06:12 AM
Discussion JJRC H8C DFD F183 2.4G 4CH 6 Axis RC Quadcopter With 2MP Camera RTF Kenxiaofei Electric Heli Talk 4 Jun 08, 2015 06:43 PM
