Old Aug 19, 2015, 01:27 PM
Bob Carver is offline
Find More Posts by Bob Carver
Joined Jul 2012
Help!
Quanum diy headtracker on Turnigy 9XR transmitter
Greetings,
I just received my new quanum diy goggles and head tracker.
It is not clearly explained how to make this work on the 9XR.
Any ideas?
Bob Carver is offline Find More Posts by Bob Carver
Old Aug 19, 2015, 02:47 PM
locoworks is offline
Find More Posts by locoworks
isle of man
Joined Aug 2003
it is supposed to plug into your trannys trainer socket and you use the software you can download from the hobbyking website to program the head tracker and assign the channels you want it to operate. then you set those channels on the tranny as if they were being used by a buddy box slave unit. the headtracker is used instead of a buddy box to control the channels.
locoworks is offline Find More Posts by locoworks
Old Aug 20, 2015, 12:34 PM
Joined Jul 2012
I already tried all that.
I confirmed the head tracker is working (plots), assigned ch7 and 8, (which are the gamble channels), saved the changes.
Trainer function is activated on the transmitter, but I only see ways to edit parameters for flight controls (ele, ail, thr, rud). Is there something else I need to do to the transmitter?
Old Aug 20, 2015, 01:57 PM
isle of man
Joined Aug 2003
possibly, watch this, it is for the taranis but you tranny may have something similar to do. the taranis only lists the 4 primary controls in the trainer section too
TARANIS and Quanum Head Tracker - Full setup instructions (15 min 12 sec)
Old Aug 20, 2015, 10:10 PM
jt41time is offline
Find More Posts by jt41time
Just call me Justin.
United States, CA, Simi Valley
Joined Jun 2009
as far as i know, trainer function is for trainer IN. in the mix setup, you should have a TRN7 100% for ch 7. and so on..... Thats how it is on my setup. I have a 9xr(opentx) with the DIY setup of that HT.
jt41time is offline Find More Posts by jt41time
Old Aug 24, 2015, 02:18 PM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
I had to do this to get it to work on my 9XR.
At first it wouldn't work, tinkering around with a multimeter eventually showed me that either the head tracker plug was sending to the wrong pin, or the trainer port was listening to the wrong pin. So i soldered the two pins together.
Apparently, fatshark needed this modification as well to get its headtracking to work. The pin the headtracker uses for its data is isn't actually connected to anything.
Hajile is online now Find More Posts by Hajile
Old Oct 18, 2015, 11:36 AM
out of stock is offline
Find More Posts by out of stock
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
So to get the quanum head tracker to work with the 9xr I'll have to solder those pins together?
out of stock is offline Find More Posts by out of stock
Old Oct 18, 2015, 01:12 PM
Joined Jul 2012
Yes. But be careful. Those solder blobs may look like they're touching, but there's actually no continuity between them. It would be pretty bad if the blobs merged together while you were soldering and ended up shorting the Vcc pin. The guy that assembled the 9XR used way too much solder.
Old Oct 18, 2015, 01:14 PM
DONT PANIC! :)
Joined Jan 2012
Soldering is my specialty. Lol
What part is that in the above photos?
Old Oct 18, 2015, 01:16 PM
DONT PANIC! :)
Joined Jan 2012
I have the quanum head tracker. Is this modification required? I'm not familiar with the tracker your using.
Old Oct 18, 2015, 01:40 PM
Joined Jul 2012
Then maybe you can get that excess out. I'm too afraid of melting the plug to wick it away, and there's no way for me to keep it from sliding around on the table.
On the other side of that board is the six pin futaba socket. That hole on the left is for the JR socket.
I'm using the Hobbyking Headtracker. Same as the video above.
Old Oct 18, 2015, 02:12 PM
DONT PANIC! :)
Joined Jan 2012
So all I have to do is open the radio and solder a bridge between those two pins?
And the included cable will work?
Old Oct 18, 2015, 02:55 PM
AlbEagle is online now
Find More Posts by AlbEagle
Joined Jan 2009
Check my video
G H (8 min 48 sec)
And my website
rcworld.tk
AlbEagle
AlbEagle is online now Find More Posts by AlbEagle
Old Oct 18, 2015, 10:04 PM
DONT PANIC! :)
Joined Jan 2012
I seem to still be confused.
Isn't this the cable I need to plug into the futaba port of the 9xr and the other end goes to the head tracker?
Does it not work? I really apologize and appreciate the help.
Old Oct 18, 2015, 10:39 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Yes you use that plug but pins 3 and 6 on the 9xr still need to be shorted.
Martin Y is offline Find More Posts by Martin Y
Help! Charging a Turnigy 9XR transmitter Lipo djmessina Multirotor Power Systems 3 Jun 10, 2015 11:46 PM
For Sale Turnigy 9XR PRO Radio Transmitter Mode 2 dannemange Aircraft - General - Radio Equipment (FS/W) 3 May 04, 2015 04:46 AM
For Sale Turnigy 9xr w/ Turnigy Lipo and 9xr Transmitter Stand salmans21 FPV Equipment (FS/W) 9 May 02, 2015 07:00 AM
Discussion OrangeRX DSMX/DSM2 2.4GHz DIY Transmitter Module and a Turnigy 9xr Pwedege Radios 12 Sep 07, 2014 04:49 PM
For Sale Turnigy 9xr, turnigy transmitrer lipo, 9xr Transmitter Stand salmans21 Aircraft - General - Radio Equipment (FS/W) 2 Feb 05, 2014 01:00 PM
