Old Jul 23, 2014, 10:26 PM
Joined Sep 2011
Build Log
Foam Dragon
I like the design qualities of a plane called the Wing Dragon from Artech.
Some of the things that are good about the plane are:
- its a push prop
- It is has ailerons (optional)
That prompted this attempt at building a foamy version of the plane.
It uses a monoblock for the fuselage and is a first attempt at creating a wing with folding the foam over on itself.
Wing is 40 1/2" with 9" LE to TE. The aileron's are cut 1 1/2" into that 9 inches.
The foam section of the fuse is 15" front to back and made of 10 pieces glued together.
The boom portion is 19". Two inches will be burried into the fuse. I used a carbon arrow shaft.
The elevator will be placed 13" from the rear of the fuse.
barjunk is offline Find More Posts by barjunk
Discussion Foam Dragon shaped micro quad with FIRE (Help?) dmarksvr DIY Electronics 4 Sep 20, 2013 06:49 PM
Help! Foam Dragon shaped micro quad with FIRE (Help?) dmarksvr Mini Multirotors 2 Sep 20, 2013 03:43 PM
Discussion Blohm & Voss BV 138 'Sea Dragon' Foam Builders Kit Gemma Jane Scale Kit/Scratch Built 60 Oct 29, 2011 06:32 PM
Sold Dragon Profile 3D Foam Plane sold by Hobby Lobby bolarobric Aircraft - Electric - Airplanes (FS/W) 1 May 29, 2007 07:49 PM
For Sale 3D Radio Controlled Flat Foam Dragon Kit Toniano Aircraft - Electric - Airplanes (FS/W) 0 Oct 11, 2006 11:16 PM
