Old Aug 28, 2015, 10:10 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Originally Posted by capoli View Post
North, here's that SPM attempt. Capoli
Perfect... got it
Just rebuilding the shocks on my Vaterra Glamis Fear, will try to take a look at it later tonight
North_of_49 is offline Find More Posts by North_of_49
Old Aug 29, 2015, 02:35 PM
Joined Dec 2011
Originally Posted by North_of_49 View Post
Perfect... got it
Here's one right back at ya. All I did was change the wing type to 1 aileron : 1 flap. This set up everything automatically and didn't mess with what you had already done...
- your flaps are still set up the way you had them and they're on the same 3-pos switch.
- your Gear channel is still on the same 2-pos switch
The only thing that changed is the flaps moved to channel 6 and Gear moved to channel 5 (like mentioned yesterday, the default on Spektrum and compatible systems is flaps on ch6, gear on ch5). So you'd need to swap those two connections at your receiver... plug flaps into Aux1 and your PERS into Gear.
If your lights ON/OFF operates backwards, reverse the Gear channel in the radio under Servo Setup / Reverse
I assume you are using Y-cabled ailerons.
You can achieve the same thing that's been done in this modified .spm file I'm attaching yourself just by going into your radio right now and changing the Aircraft Type to Wing: 1 Ail 1 Flap. That's all you need to do
You will now see this is Channel Assign...
Rx Port Assignments
5 GEAR:Gear
6 AUX1:Flap
Channel Input Config (your switches)
5 GEAR: A
6 AUX1: N/A (because you already chose your flaps switch in the Flaps System menu).
Old Yesterday, 08:31 PM
capoli is offline
Find More Posts by capoli
Tail Dragon
United States, IA, Lansing
Joined Jun 2013
Perfect... got it
Got it - thanks a ton North!!!
capoli is offline Find More Posts by capoli
Old Yesterday, 10:34 PM
Joined Dec 2011
No problem, man.
I noticed you have some pretty extreme numbers programmed in your flaps system menu for down elevator and servo speed... about double in both cases of what I have on my Sport Cub and even mine are kind of what others might consider extreme. Fellow member Joel (turboparker) was explaining in another thread how too much down ele just ends up negating what the flaps actually do, if I can find it I'll send you the link.
As for deployment time, I just wouldn't want to see that bite you if you got into trouble and needed to retract them quickly. I found a way in my DX9 to set up two different speeds for my flaps, a slower speed for deploy and faster one for retract. It uses a combination of settings in the flaps system along with settings in the main servo setup menu. I think I have about a 4 or maybe even 5 second deployment for full flaps with maybe half that time or less to retract them.
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Kit/Scratch Built 14 Oct 16, 2009 02:03 AM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Fuel Planes 2 Jan 05, 2008 01:26 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Scale Airplanes 1 Dec 31, 2007 03:39 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Parkflyers 3 Dec 29, 2007 07:32 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Electric Planes 1 Dec 29, 2007 06:39 AM
