Old Aug 23, 2012, 08:10 PM
Henry Sistrunk is offline
Find More Posts by Henry Sistrunk
Henry Sistrunk's Avatar
United States, GA, Ochlocknee
Joined Jul 2006
Giant Big Stick Conversion
Here is my latest conversion. It has been flying since March 2011.
Rimfire 160 motor
100 amp esc
16X8E APC prop
12 cells, 4200 mah.
7 servos
Henry Sistrunk is offline Find More Posts by Henry Sistrunk
Old Mar 01, 2013, 01:04 PM
garrett454ss is offline
Find More Posts by garrett454ss
Middletown In.
Joined Sep 2007
How does this fly? I'm working on one now with the same setup and was wondering.
garrett454ss is offline Find More Posts by garrett454ss
Old Mar 01, 2013, 01:26 PM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
That looks like a lot of fun to fly!
Let us know how she flies.... and what sort of flight times you're getting with that setup.
Thanks!
Hit N Run is offline Find More Posts by Hit N Run
Old Mar 02, 2013, 11:50 AM
ampmaker is offline
Find More Posts by ampmaker
Sleepy Hollow, IL
Joined Dec 2008
Henry,
Here is a picture of my own Giant Big Stik that I built in January 2011.
Monster Power 160
Turnigy Sentilon 100A ESC
APC-E 18x12
10S-4000
6 Servos
These are fantastic planes for electric power conversion. When the wind is up this plane will still go exactly where you point it. The big wing makes it float in for landings. One of my favorites.
Put my battery hatch right up front on top and added a couple of Habu air scoops for cooling inlets.
Hope you enjoy yours as much as I do mine.
ampmaker
ampmaker is offline Find More Posts by ampmaker
Old Mar 28, 2013, 09:30 PM
jk6672 is offline
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
I really want one of these with EP. The Rimfire 160 has more than enough power?
Does anyone have pictures of access plate they made?
I have a electrostik and I'm sure they fly with the same characteristics, just bigger.
jk6672 is offline Find More Posts by jk6672
Old Mar 29, 2013, 10:34 AM
ampmaker is offline
Sleepy Hollow, IL
Joined Dec 2008
jk,
Here is the hatch arrangement on mine. Magnet catch on the back. Two wooden L brackets to catch the lip on the front. Two air-scoops from a Habu to feed air down over the batteries.
ampmaker
Old Mar 29, 2013, 10:57 AM
ampmaker is offline
Sleepy Hollow, IL
Joined Dec 2008
jk,
I am using the Monster Power 160 and it has more than enough power. The Rimfire 160 actually has a little more power.
The Giant Big Stik flies even better than the Electrostik. The big Hersey bar wing will let this plane float in for landings. The heavier weight makes this a great windy day flier. Point it and it goes there. I have mine set up for flaps. I have never used them as this plane lands great without them. Will probably convert them over to extra ailerons.
ampmaker
Old Mar 30, 2013, 12:56 PM
jk6672 is offline
John
jk6672's Avatar
Joined Sep 2012
Thanks. I was thinking Hacker A60 or Rimfire, but not sure if I should run 10 or 12S. The highest I have is 8s on a TP P-47 with Hacker A50. How much room for batteries? I'd rather go higher mah than and ballast weights.
Old Mar 30, 2013, 05:31 PM
ampmaker is offline
Sleepy Hollow, IL
Joined Dec 2008
I am running 10S-4000 and there is plenty of extra room. Battery sizes have come down some. I am sure 10S-5000 would fit or 12S-4000.
ampmaker
Old Apr 10, 2013, 09:31 AM
jk6672 is offline
John
jk6672's Avatar
Joined Sep 2012
I took the plung and bought a Rimfire 160, 4 Futaba S3305 and two S3010 servos. I pretty sure I'll go with the new CC PHX Edge 80HV and a pro BEC.
Old Apr 11, 2013, 09:23 AM
jk6672 is offline
John
jk6672's Avatar
Joined Sep 2012
What are the dimensions of the cross on the wing and vertical stab? Since I have the electrostik I was thinking of doing something different with the giant and replacing those crosses (leaving the one on the fuselage intact) with some skulls like these:
Also, has anyone seen the landing gear replaced with carbon fiber ones or painted the origonal red?
Old Apr 11, 2013, 01:20 PM
ampmaker is offline
Sleepy Hollow, IL
Joined Dec 2008
jk,
The tail cross is 6.5 x 6.5 inches and the wing cross is 12.5 x 12.5 inches.
ampmaker
Old Apr 11, 2013, 01:50 PM
Thrawn150 is online now
Find More Posts by Thrawn150
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
Could you use JR ds821 servos with this?
Thrawn150 is online now Find More Posts by Thrawn150
Old Apr 11, 2013, 01:58 PM
jk6672 is offline
John
jk6672's Avatar
Joined Sep 2012
Originally Posted by ampmaker View Post
jk,
ampmaker
thanks!
Old May 26, 2013, 09:52 PM
jk6672 is offline
John
jk6672's Avatar
Joined Sep 2012
Finally ordered stick today (a long with two others, now I have to figure out how I'm going to sneak it all in the garage, lol)
Where did you guys make entrance and exit vents?
For Sale Great planes giant big stick "LPU" rcflyguy73 Aircraft - Fuel - Airplanes (FS/W) 3 Sep 27, 2012 08:08 AM
For Sale GP giant big stick rcflyguy73 Aircraft - Fuel - Airplanes (FS/W) 2 Aug 19, 2012 08:43 PM
Wanted Wanted: giant big stick ARF 03svtsnakevert Aircraft - Fuel - Airplanes (FS/W) 9 Apr 22, 2012 10:12 AM
Sold Bud Nosen A&A Kits For Sale! Citrabia, Trainer $200.00 ea. Giant Big Stick $175.00 stevster Aircraft - Fuel - Airplanes (FS/W) 4 Apr 07, 2012 08:40 PM
Wanted GP Giant Big Stick BT00561 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 29, 2012 01:06 AM
