Old Feb 22, 2015, 04:14 AM
Joined Feb 2015
twin horse 9053 conversion to 2.4G
Hi Folks,
ok ok, I know this heli is pretty much toy grade and not worth spending much cash on, but I think I have a faulty Tx on one channel (I have lost rear rotor throttle)
I can get a 3ch 2.4G setup cheap enough to warrent it. But I've never worked on helis before (I'm monster truck geek)
So my question is, do I need to change the PCB that seems to control everything ?
I can see the aerial is soldered into it, so is it a combined ESC/Rx ?
Thanks for any help dudes
barnetbasher is offline Find More Posts by barnetbasher
Old Feb 22, 2015, 04:37 AM
mono's Avatar
Joined Aug 2008
hello
yep, the pcb is a combo, containing the rx, coaxial mixer & gyro and the esc's for the two main motors and the tail motor.
The no throttle on tail issue could be either a blown mosfet on the pcb, a faulty tail motor or the least likely possibility of a problem in the tx.
What hardware did you have in mind for the conversion?
mono is offline Find More Posts by mono
Old Feb 22, 2015, 05:32 AM
Joined Feb 2015
Originally Posted by mono View Post
hello
Thanks Mono, someone on here suggested this is a good buy for not much cash, http://www.banggood.com/Wholesale-Wa...074870201208QV
Old Feb 22, 2015, 06:57 AM
mono's Avatar
Joined Aug 2008
The 7E is okay but range limited as it comes, however you would find it a rather expensive and difficult project to use that with the 9053.
Walkera don't have (and never had) a 3ch rx/mixer/gyro/esc brick that you could use with that radio as a replacement board on the heli.
Alternatively, going separates, i.e. a separate rx, a coaxial mixer, a gyro, 2 brushed esc's for the mains, 1 brushed car esc (fwd/rev) for the tail, would cost a small fortune apart from being a difficult job.
The easiest route (and more cost effective) is to either replace the board with one from a similar 3ch 2.4ghz heli for which both the board and the tx are available as spares, but it still won't be cheap. You can usually get the whole rtf for similar to what it would cost for the board and tx.
Something to think about anyway.
Old Feb 22, 2015, 04:54 PM
Joined Feb 2015
Thanks bud, I think i'll mail the place I got it from and see if they can help. Makes sense to be sure which part is faulty
EDIT, just ordered a new PCB for just a few so will see if that sorts it
Old Feb 23, 2015, 03:57 AM
mono's Avatar
Joined Aug 2008
okey dokey, that may be the best solution for that particular heli.
Were you able to test the tail motor itself to make sure it's functional?
Old Feb 24, 2015, 03:49 PM
Joined Feb 2015
Yes bro, I dobbed a battery on it and it spun freely in its housing
Discussion New Dynam A-10 Thunderbolt II Twin 64mm EDF Jet with Retracts 2.4G RC 5 Channel Ready hobbypartz Product Announcements 51 Yesterday 02:40 PM
For Sale 2.4Ghz 1.2G LawMate + 2.4g High Pass Filter + 1.2G vx+2.4G kevinlib FPV Equipment (FS/W) 5 Sep 20, 2014 12:40 PM
For Sale 2.4Ghz 1.2G LawMate + 2.4g High Pass Filter + 1.2G vx+2.4G kevinlib FPV Equipment (FS/W) 1 Jul 13, 2014 04:40 PM
Discussion 15% OFF Brand New 4CH 2.4G Dynam Hawk Sky 1370MM 2.4G RTF nitroplanes Hot Online Deals 0 Nov 12, 2013 09:46 PM
Discussion F-18 EDF How to conver Twin Motor? xdreamx Foamy EDFs 2 Feb 21, 2010 05:07 PM
