Old Jan 10, 2015, 11:55 PM
connector collector
brooklyn nyc
Joined Dec 2010
2015 8.5mm Micro FPV Shootout
So as we all know micro FPV is quickly catching up to mini FPV, I know this is all happening too fast. So in my obsessive compulsive way I decided to seek out every possible way to put together the highest performing micro quad to date. Since '13 I've been building micro fpv nanoqx's and then got swept away in mini h quads. 2015 I decided no more mini's for me and things like the alienwii brought me back to the micros, after some digging I found suitable specs for 8.5mm build. I found a few under 10g frames put chaoli 15's on there with the alienwii and woowee the quad is rocketship, with a 750mah and AUW of 50g's the quad flies amazing motors stay cool and all is great. Now the FPV builds begins weight goes up to 58-60 g's performance is still there but drops dramatically after a few minuets, yes 7 min flights can be achieved before i hit 3.7 volts but the last 4 mins I dont have that punch needed to be racing high speed and get out of trouble. I digress you can use a lighter battery/500mah but flight time is 4 mins, so I'll deal with the 750's and sluggish latter 1/2 of flights until the next evolution. So now the object is to put together the lightest/ for flight performance and motor life/ longest range in video and rc control micro AUW under 60g's quad with the props out of view as much as possible .
now so far we have a huge rundown of parts and combos to make to create the best setup. I'll break it down...
Frames
Picnic quad integrated
PFG 110mm
Dreamcatcher FPV
carbon micro h
wsk 110
smiley
Sosx
Motors
Chaoli 15
hubsan
Flight Controller
Alienwii 3.4g
Brotronics Lulfro 2.56g / 3.1g with battery plug
Camera
1g fpv hobby 70mA
RMRC pico
BG hd 160-200ma
BG 1/4 hd 80mA
Hubsan
VA1100
Lenses
FPVhobby
BG wide angle
d-lens
Video TX
RMRC Pico 1280 100mA
GetFPV mini 200mw 1258/1280
5.8 1.9 w/cloverleaf 150mAh (min) – 280mAh (max)
bg200mw 170ma 2.3 gr 1.1 without metal cover.
bg600mw 500ma 3.9g
58ghz-200mw-5v
Altitude RC
Video RX
lazerbgc 1.3
generic 1.3
autoscan 5.8
Antenna
hk cloverleaf
fpv 1g cloverleaf
Regulators
Pololu 5v step up
Pololu adjustable
FPVhobby
As to not overload the variables I will be using 750 nanotech's and hubsan props only.
More to come with an official micro quad showdown website soon, any input would be great as well...
newborn is offline Find More Posts by newborn
Old Jan 11, 2015, 02:05 AM
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Frames
PFG 110mm
Dreamcatcher FPV
Motors
Chaoli 15
hubsan
Flight Controller
Alienwii
Brotronics Lulfro
Camera
1g fpv hobby 70mA
RMRC pico
BG hd 160-200ma
BG 1/4 hd 80mA
Hubsan
Lenses
FPVhobby
BG wide angle
d-lens
Video TX
5.8 1.9 w/cloverleaf 150mAh (min) 280mAh (max)
bg200mw 170ma
bg600mw 500ma
Video RX
lazerbgc 1.3
generic 1.3
autoscan 5.8
Antenna
hk cloverleaf
fpv 1g cloverleaf
Regulators
Pololu
FPVhobby
This list is great .... you pick up best current options
SeByDocKy is online now Find More Posts by SeByDocKy
Old Jan 11, 2015, 02:20 AM
connector collector
brooklyn nyc
Joined Dec 2010
I'm glad you like it, you def where a big help in researching a lot of it! Theres alot of micro FPV stuff, I'm gonna limit this contest to DIY/modded 8.5mm direct drive builds and see whats the most durable, agile, longest range, most flight time setup.
Old Jan 11, 2015, 02:37 AM
Canada, BC, Vancouver
Joined Jul 2014
Great timing! I just decided today to build a micro for indoor/outdoor flying during the winter. This thread will help tons.
So far, I've picked:
Picnic quad integrated 120mm
8.5mm Chaoli motors (17's)
Brotronics FC
Husban X4 props
Nanotech 1s 500mAh batteries
subatomic is offline Find More Posts by subatomic
Old Jan 11, 2015, 02:38 AM
Hubsan X4 - H36 - V911
bangkomit's Avatar
Indonesia, Jakarta
Joined Oct 2012
addition to your lists:
Frame:
- Micro H-Quad from smartshapes (ebay) http://www.ebay.com/itm/Micro-H-Quad...-/191364703204
Motor:
- cheap 8.5mm motor from BG (USD 5.42 a pair of 2) http://www.banggood.com/2-X-8x20mm-M...r-p-87683.html
Propeller:
- Hubsan Props from BG (USD 1.3 per set of 4) http://www.banggood.com/Upgraded-Hub...t-p-81701.html
- Rolling Spider Props from GLB (USD 3.2 per set of 4) http://www.goodluckbuy.com/parrot-mi...de-2-pair.html
Flight Controller:
- Hubsan X4 (combined with hobby grade TX, ie: SpyHawk, Spektrum, Taranis, Devo 10 etc) http://www.banggood.com/Hubsan-X4-H1...3-p-87802.html
video TX:
- altituderc nano http://www.readymaderc.com/store/ind...oducts_id=2284
bangkomit is offline Find More Posts by bangkomit
Old Jan 11, 2015, 02:43 AM
SeByDocKy's Avatar
Joined Dec 2012
Maybe I would add the Flysight TX58200M http://www.rangevideo.com/58-ghz/10-...er-module.html for me much better and cleaner than the TS5823. The mini-aomway 200mW http://www.banggood.com/AOMWAY-FPV-5...-p-947147.html is excellent too but more heavier
Old Jan 11, 2015, 03:00 AM
connector collector
brooklyn nyc
Joined Dec 2010
very nice suggestions, I will add but to test I will need some donations . So far I'm posting what I have, I have a wishlist too, but I need sponsorship. There are so many combinations here I want to limit it to 5 or six...
Old Jan 11, 2015, 07:42 AM
Brazil
Joined Jan 2014
Consider also the 5813 vTx.
marbelo is offline Find More Posts by marbelo
Old Jan 11, 2015, 01:27 PM
Aalesund, Norway
Joined Jun 2012
Bangkomit: How do you bind a Taranis to a Hubsan X4 controller ?
daggad is offline Find More Posts by daggad
Old Jan 11, 2015, 01:50 PM
United States, AL, Dothan
Joined Jan 2015
I was actually thinking about this myself and wondered if one of these micro quads could carry this Spektrum Ultra Micro Camera
http://www.horizonhobby.com/SPMVA110...CYaxoCWCPw_wcB
EvilGaming is offline Find More Posts by EvilGaming
Old Jan 11, 2015, 01:55 PM
Aalesund, Norway
Joined Jun 2012
It already does !
http://www.horizonhobby.com/nano-qx-...eadset-blh7280
Old Jan 11, 2015, 02:06 PM
Joined Jan 2015
oh that's awesome but another idea i had was to use the Carbon Micro-H with the Super X fc,esc,and motors + the Spektrum Ultra Micro
Old Jan 11, 2015, 08:29 PM
last of the sixties kids..
Cannafish's Avatar
New Zealand, Northland, Whangarei
Joined Jan 2013
My HQuad comes in at a portly 63g AUW. Flies nicely though but flight times are short. I'm using this vtx http://fpvhobby.com/229-new-mini-58-...fatshark-.html but I'm not impressed with the range thus far. No point in FPV if the range is less than 10m.
Also one consideration to take into account. IMHO FPV frames need to be strong or you'll spend more time repairing the frame than flying.
Cannafish is offline Find More Posts by Cannafish
Old Jan 11, 2015, 09:12 PM
bangkomit's Avatar
Indonesia, Jakarta
Joined Oct 2012
I dont have Taranis, but this module should do the job for your taranis
http://www.rcgroups.com/forums/showthread.php?t=2256459
Old Jan 11, 2015, 09:35 PM
connector collector
brooklyn nyc
Joined Dec 2010
None of my current builds are over 60g's, this def helps with durability, any more weight and the flight times are just too short for me/ I can't get out of trouble fast enough(not enough thrust). As far as the FPVhobby 1.9g VTX 10m is terrible, I do not like to hear that. My current best setup I can do 150m with the getfpv 1258/1280 mimi 200mw. So far that seems to be a good distance that will be a minimum goal for the best micro fpv setup. I got word from CID54 the the Micro quad Wsk 110 will be avail to print soon so that will be an interesting frame to test @34g's AUW, durability is the real question. So far my PFG 110mm and the picnic quad have stood up to abuse. Heres a sample from the PFG frame.
ps I'm keeping this test to 8.5mm brushed direct drive builds only.
getfpv mini 200mw 1280/1258 test 2 (4 min 18 sec)
Discussion Flite Test - Micro FPV Shootout - H107d, Proto-X and Nano QX Waterbound Mini Multirotors 3 Jan 07, 2015 12:13 AM
Discussion Pinto the FPV micro quad - 54g - 8.5 minute flights - Cleanflight CATPart Mini Multirotors 14 Dec 30, 2014 03:08 PM
Sold Micro FPV RMRC Pico Wide Camera, Altitude RC Nano 5.8 vtx, True RC Antenna Enginerd1 FPV Equipment (FS/W) 2 Nov 29, 2014 12:56 PM
For Sale Mini FPV 5.8 Combo Deal! Micro 32 ch 200mW VTx, Super HAD and Antennas! punkindrublik FPV Equipment (FS/W) 10 Oct 07, 2014 06:06 PM
Question Micro EDF using brushed 8.5mm? bungholio Micro EDF Jets and Power Systems 4 Apr 28, 2011 11:33 PM
