Old Jun 20, 2014, 07:58 AM
United States, TN
Joined Mar 2011
How To Determine When It's Time To Take A Lipo Pack Out Of Service?
What methods are used to determine when it is prudent to take Lipo packs out of service from a safety (fire) and/or performance perspective?
Thank you.
itsme2 is offline Find More Posts by itsme2
Old Jun 20, 2014, 08:03 AM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
When you start noticing an unacceptable drop in flight performance or the low voltage cut-out starts activating early. This will depend on application, a battery that is unacceptable in a high demand application might be fine in another less demanding model.
Or I guess if the pack is badly puffed and looks like it might burst or has other serious physical damage.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jun 20, 2014, 09:37 AM
Sverige, Värmlands Län, Filipstad
Joined Jan 2009
Or if the internal resistance (IR) is getting high(er) it can be an indication that the LiPo battery has seen it's better days. Some chargers can display IR when charging LiPo batteries. It can be good to keep track of IR values so one can see over time if it change to higher values. In practice You will notice decreased performance from the LiPo battery at high throttle and sooner or later it's time for recycle bin for a LiPo, it is only a matter of time for all LiPo. But one want to have as many cycles as possible but still good performance out of LiPo packs. Very cheap LiPo packs maybe have less chance to achieve that but You never know. Same for expensive and supposed to be "quality" packs, maybe they will last longer but one never know.
In my competition F3A models I use ThunderPower LiPo (G8, 25C) and they seems to cope with many cycles, still give good performance and have still rather low IR.
Last time I checked IR on one of my 5 cell LiPo packs 5000 mAh (TP G8 Pro Lite+, 25C) the IR was between 2.5 and 2.9 milli Ohm and it had about 20 charge cycles so far on it.
But low C rated battery will have higher IR then high C rated LiPo.
For every day flying maybe ThunderPower Lipo is on the expensive side but they are usually rather good.
/Bo
bossee is online now Find More Posts by bossee
Old Jun 20, 2014, 09:48 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I gather that all lipo cells will gradually develop higher internal resistance with use/abuse. Nowadays, I try to store packs at 3.75 to 3.85 volts per cell and not over discharge them to the point where packs become hot vs barely warm.
When they finally puff up and lose their punch, I set them aside and eventually discharge and dispose of them.
E-Challenged is offline Find More Posts by E-Challenged
Old Jun 20, 2014, 10:59 AM
A man with too many toys
United States
Joined Feb 2001
Thank you.
I use IR.
When the IR gets to double of what it was on a new pack it's time to retire it. It pays to keep records of your batteries. I test all new batteries and check about every 20-30 cycles.
Note:
IR changes with charge and temperature so try to take readings at the same charge state and temperature.
RC Man is offline Find More Posts by RC Man
Old Jun 21, 2014, 11:50 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Seems some of the experts disagree and have posted that state of charge has little to no effect on IR.
Old Jun 21, 2014, 12:02 PM
Aberdeen
Joined Mar 2006
I'm no expert but yes, i used to think that charge had an effect but after testing I can confirm it doesn't, at least nothing significant.
Temperature on the other hand has a big effect and heating during charging or discharging can fool you into thinking that the change of charge state has decreased IR, when in reality it's almost all caused by increase in internal battery temperature.
Old Jun 21, 2014, 05:11 PM
So. Cal.
Originally Posted by RC Man View Post
I use IR.
Can I have your 'retired' packs? I'll pay shipping!
mrforsyth is offline Find More Posts by mrforsyth
Old Jun 21, 2014, 08:10 PM
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
I fly battery packs until they change dimensions or they'll no longer deliver the performance I need. My "testers" are the planes I fly them in and a noticeable drop in performance isn't necessarily grounds for retiring packs as long as they haven't changed dimensions. Sometimes I simply don't perform maneuvers as close to the ground as I would with a healthier pack and sometimes I fly weak packs in less-demanding planes.
And sometimes I re-purpose weak packs for other things like external power packs for my video camera or photo strobes. I used an old pair of TP2100-3S (8C) packs for several years that way and that was after flying planes with them for nearly 4 years. I'm currently using some old TP3300-3S ProLites to power my FPV video RX and monitor and they still do that just fine after flying planes and multirotors for 4+ years.
I don't even care what the capacity or IR is. If packs do what I want them to for as long on a charge as I expect them to without changing dimensions, then they pass all the tests that matter to me. The reason I'm comfortable with that practice is I fly a premium brand of LiPo packs and they aren't known for sudden failures. They wear out, but they do so in a predictable manner.
Pete
PGR is offline Find More Posts by PGR
Old Jul 01, 2014, 08:01 PM
United States, CA, Fairfield
Joined Aug 2011
When the IR is 25 milli ohms per cell I take them out of service or use them for other purposes
Ermilo is offline Find More Posts by Ermilo
Old Jul 01, 2014, 09:13 PM
United States, FL, Orlando
Joined Oct 2013
Keep in mind that IR is inversely proportional to capacity so 25mohm might not be so bad for really tiny packs while it would be really bad for high capacity batteries.
CerealKiller159 is offline Find More Posts by CerealKiller159
Old Jul 01, 2014, 09:17 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
And it depends on what is used to measure the IR.
With my method, 25mohms is great.
hoppy is offline Find More Posts by hoppy
Old Jul 05, 2014, 02:35 PM
Joined Aug 2011
I thought I had this issue worked out, now I see that is more complicated. I use my icharger to test my IR. As close as I could get to an answer as to when I should retire a battery was 25. Now I am back at square one. Any electronic engineers out there?
Old Jul 08, 2014, 09:04 AM
Joined Aug 2011
Do you mean 25mohms per cell?
Help! IMAX B6 AC Times out every time with Lipo's Custnam Batteries and Chargers 8 Apr 26, 2014 03:57 PM
Discussion How to determine flight time based on battery drain? maxnew40 Power Systems 9 Mar 27, 2014 12:07 AM
Discussion A Perspective: How much time does it take? FrankC Life, The Universe, and Politics 53 Nov 30, 2013 07:35 AM
FAQ how do I determine what version simonK are on my ESC's ? remvideo Multirotor Electronics 1 Nov 08, 2013 12:58 PM
Discussion GP Cessna 182 - How to know when the tank is full without taking out the cowl? calvarezr Fuel Plane Talk 12 Aug 05, 2007 03:35 AM
