Old Nov 14, 2014, 05:37 AM
United Kingdom, Scotland, Argyll and Bute
Joined Oct 2012
Video
Hz Supercub (floats)
The flying weather in Scotland hasn't been so good lately so having to look back a few months to the 'good' times
nicktwinnflying (1 min 55 sec)
drambuidhe is online now Find More Posts by drambuidhe
Old Nov 16, 2014, 05:11 PM
Flap flier
Flahultarn's Avatar
Sweden
Joined Aug 2011
Nice! Was the landing in fpv? Impressing!
Flahultarn is offline Find More Posts by Flahultarn
Old Nov 17, 2014, 02:01 AM
Joined Oct 2012
Thanks- no I can't lie, I chickened out with the fpv for a landing. If I'd got it wrong I would have had a cold swim
Old Nov 17, 2014, 02:20 AM
Flap flier
Flahultarn's Avatar
Sweden
Joined Aug 2011
Haha, chicken I'm just in the start of my flying experiences but have thought that landing FPV on flat water must be doable. Large and infinite landing strip! But that is theoretical, might be different IRL though...
Old Nov 17, 2014, 03:28 AM
Joined Oct 2012
Well yes, water does provide a nice large and sometimes flat surface to land on, but don't forget what you see through your fpv transmissions isn't as good as your HD footage watched later
On a totally mirror calm day I tried it and hit the surface at way too much speed and she nosed right over.
An ex-BA pilot I fly with reckons there's many a full scale float plane that's done the same , the mirror flat water makes it difficult to judge distance from , I can vouch for that one
Here's one of my first (desperate ) successes though
nicktwinnflying Super cub fpv float plane (10 min 57 sec)
Old Nov 17, 2014, 04:35 AM
Flap flier
Flahultarn's Avatar
Sweden
Joined Aug 2011
Hey man, I'm impressed by a number of things in your vid=) On two (didn't learn my lesson from the first) flights I've got carried away and been flying out down wind and not been able to get home again and as you say hearing the motor to loose power is frustrating. I'm flying in woodlands so in the moment I got near the ground I lost video so not possible to land the excellent way you did. I guesss you felt quite satisfied after that landing! I had to order a new glue after my disasters...
What FPV-setup do you run? Guess you have an OSD so har far out were you at the most?
What size battery? I'm flying a Fun cub recently redesigned for twin motors and using a 4S 2200 I'm hoping for about 15 min flight time that might give some more safe margin and still be able to fly more freely.
You don't happen to record the FPV-cam? Would be very interesting to see this vid from that perspective together with the OSD info...
Scotland is the kind of landscape I like the most =)
Old Nov 17, 2014, 02:59 PM
Joined Oct 2012
Hi Flahultarn,
The fpv kit is Immersion 600mw vtx with stock rubber duck antenna
Immersion Patch Spironet 13dbi antenna on Immersion Uni vrx
Powered off dedicated 2s 1000mah lipo
No osd (then) just battery alarm.
Flight battery- 3s 2200 Zippy Compact(good for >18mins)
No other camera- No16 used for flight record and fpv.
Old Nov 17, 2014, 03:09 PM
Flap flier
Flahultarn's Avatar
Sweden
Joined Aug 2011
Hi Flahultarn,
Ok, thanks for the info! Suprised it can take the weight as good as it does...
Old Nov 18, 2014, 03:07 AM
United States, CA, Orange County
Joined Apr 2013
Nice videos. I'd like to build a similar FPV plane.
I have the spironet patch antenna on my receiver as well and I wanted to mention that because it is a CP antenna it would be better matched with a CP antenna on the transmitter. If i remember correctly there's a 3dbi loss going from a linear antenna to a CP, and 3dbi theoretically doubles range. Your video looks great but if you want an increase in range and decrease in interference I think a CP on the transmitter would be worth it.
thehelidude is offline Find More Posts by thehelidude
Old Nov 18, 2014, 04:16 AM
Joined Oct 2012
Hi Helidude, I usually do use an Immersion cp antenna on the vtx on my other planes . The furthest I've been is around the 3.5 km mark. I used the rubber duck antenna on the seaplane to add a bit more weight forward and to see how it performed , since it had lain in the box the vtx had come in and never been used.
I've been gobsmacked by its performance to be honest!
I generally fly lower with the seaplane so didn't expect much range.
The weird thing is I am getting just as far as the cp and swear I have a sharper pic??
nicktwinnflying (8 min 21 sec)
Sold PZ Extra 300, HZ Supercub airframes Strizzo Aircraft - Electric - Airplanes (FS/W) 13 Sep 24, 2014 02:10 PM
Discussion Buying the HZ SuperCub LP w/ Floats as a first plane ParkFlyers Beginner Training Area (Aircraft-Electric) 40 Jun 25, 2014 12:50 AM
Discussion Hz Supercub On Floats Sinai1 Parkflyers 2 Oct 24, 2007 10:09 PM
Discussion want to put floats on a HZ SuperCub xxxnt7 Electric Plane Talk 5 Jul 30, 2007 02:24 PM
