Old Dec 09, 2014, 08:29 AM
Branjo
Joined Sep 2013
Really enjoyed looking at your build. It looks great. I have to ask where did you get all of your laser cut clamping hardware and right angle rib tools etc. Those are great and I apologize if this has been asked already. Thanks
Branden
bshultz327 is online now Find More Posts by bshultz327
Old Dec 09, 2014, 07:03 PM
slow_flier's Avatar
United States, PA, Pottstown
Joined Dec 2009
I probably have, but they come from Retro R/C (http://retrorc.us.com) Mark Freelander makes them.
slow_flier is online now Find More Posts by slow_flier
Old Dec 09, 2014, 07:42 PM
slow_flier's Avatar
Joined Dec 2009
The crankcase is coming along. I got it sealed, the three cylinder port cut and fitted for the cylinders and the beginnings of the propeller support made. The next step is to fill and seal the propeller support (and its triangular bosses), Once this complete I can add the bosses to the crankcase and start panting and detailing the engine sub assemblies.
My next problem is how to build the exhausts and the valve trains. The kit includes 3 laser cut rocker arms for the valve train but I still need rocker arm supports, push rods, valves and valve springs. All of these are extremely visible on this enginend it will look naked without them.
In the meantime, her are a couple of photos of the crankcase with the cylinders in the new homes.
Old Dec 10, 2014, 05:39 AM
Norfolk, England
Joined Sep 2001
I'd suggest sllt brass tube for the rocker mounts, wire with slit tube ends for the pushrods and sections of spring from those throw-away lighters for the valve springs with a pin and small washer for the valve stems.
Just as an aside, I've found automotive filler/primer to be good for hiding the wood grain on cylinders, crakcases and cowls. Spray on a couple of coats, sand smooth, spray again and repeat until smooth and grain free. Any weight it adds is in just the right place.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Dec 10, 2014, 09:18 AM
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
I second the primer thing. When you go to the auto store get the one labeled "filling" primer, not "etching" primer. I have seen a can that was both etching and a filler. The one I bought just labeled etching was pretty thin stuff.
Have fun with the fiddly bits.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Dec 10, 2014, 11:19 AM
Branjo
Joined Sep 2013
Thanks slow flier. Good luck with the build. Looks awesome. I will be watching!
Branden
Old Dec 10, 2014, 06:40 PM
slow_flier's Avatar
Joined Dec 2009
Ahhh, the fiddly bits.
Pete/Charlie: Thanks for the suggestions
Old Dec 14, 2014, 05:50 PM
slow_flier's Avatar
Joined Dec 2009
Well, I had a little time to work on the crankcase. I've used some 3/32" polystyrene tube to make some "bosses" that could hold the crankcase together. Once painted, the look ok. I have some #1 hex head screws coming to close up the front of the tubes.
The cylinders are next.
Old Dec 14, 2014, 07:34 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Very nice job!!
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 14, 2014, 07:37 PM
Paul Bonati's Avatar
Buenos Aires, Argentina
Joined Aug 2007
I also like your job. Watching.....
Paul
Paul Bonati is offline Find More Posts by Paul Bonati
Old Dec 14, 2014, 08:50 PM
slow_flier's Avatar
Joined Dec 2009
Thanks guys. It's appreciated. Sometimes I think I'm talking to myself
Old Dec 14, 2014, 09:41 PM
SteveT.'s Avatar
San Jose, CA
Nope, even though I don't always post a reply, I peruse everything you post...
SteveT.
Old Dec 15, 2014, 07:11 AM
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
So do I.
Jim
JIMA is offline Find More Posts by JIMA
Old Dec 15, 2014, 11:03 AM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Me too
Build Log 58" Eastbourne Monoplane by Peter Rake Old_Pilot Balsa Builders 515 Sep 06, 2014 05:33 PM
For Sale Peter Rake Eastbourne Monoplane baldguy Aircraft - Electric - Airplanes (FS/W) 0 Jul 07, 2013 01:12 PM
Build Log Peter Rake's 58" E.A.C. Monoplane Build 1905Flyer3 Scale Kit/Scratch Built 1 Jun 18, 2012 07:48 PM
Video Peter Rake designed Eastbourne Monoplane stuart warne Electric Plane Talk 1 May 25, 2009 02:29 PM
