Old Apr 17, 2016, 01:42 PM
chip.greely is offline
Find More Posts by chip.greely
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
Build Log
Introducing the Bone Fish
Following up on lessons learned from my Albacore and Cross-Over designs, I set my Design Goals for a light weight symmetrical design VTPR ship. Applying some of Justin's success from his Buzz, I laid out a symmetrical fuselage design and cut out my foam blank. Target flying in the stronger winds of the Bay Area, I reduced the wing span and chord design to minimize drag and perform in higher wind velocity.
Target weight under 10oz with Pull/Pull Stab & Rudder and 35% Ailerons.
chip.greely is offline Find More Posts by chip.greely
Old Apr 17, 2016, 01:45 PM
Carlsbad, Ca
Joined Mar 2007
The fuselage design almost demanded a fishy scheme and I have to credit the old Tom & Jerry cartoon series for the idea of the Bone Fish, as the Alley Cats searching thru the garbage cans always pulled out those fish headed skeletons
Old Apr 17, 2016, 01:47 PM
Carlsbad, Ca
Joined Mar 2007
Cut, colored and covered my symmetrical wings and fitted them into the fuselage
Old Apr 17, 2016, 01:51 PM
Carlsbad, Ca
Joined Mar 2007
Time to start inking the fuselage,...I still like using the Sharpies and moved to the large Chisel Tips for covering a larger surface area. New stuff protects everything with 3mil.
Fitted with the wing for a final finish look
Old Apr 17, 2016, 01:54 PM
Carlsbad, Ca
Joined Mar 2007
Fitted High Torque Metal Gear servos in the fuselage for Pull/Pull operation of both Stab & Rudder
Old Apr 17, 2016, 01:58 PM
Carlsbad, Ca
Joined Mar 2007
Large surface area Rudder with magic hinge and Full Flying Stab with 180 degree throw
Carlsbad, Ca
Joined Mar 2007
Starting to take shape, after cutting ailerons and tape hinging them in place
Old Apr 17, 2016, 02:04 PM
Carlsbad, Ca
Joined Mar 2007
Dremel cut a carbon fiber plate to make extended servo arms for the Pull/Pull operation.
My thru-fuselage placement of these servos may not have left me enough clearance on m y Rudder Pull/Pull lines. Some modification may be required.
Old Apr 17, 2016, 02:51 PM
JGAF is offline
Find More Posts by JGAF
Aerobatics!
JGAF's Avatar
United States, CA, Oceanside
Joined Nov 2007
Use a couple of plastic clevises attached to your extended servo arm to set up your pull/pulls. If you need to adjust the tension just unhook the clevises and twist the line.
I usually mount my rudder servo vertically to avoid dealing with a long & short pull/pull line. You may find a good placement for yours behind the wing or far enough below/above the ailerons so that it won't get in the way and you will have the ability to easily work on it.
Unfortunately I don't believe you're going to have much luck as far as more performance in big wind with the change in wing design. You will probably find a higher potential roll rate though. The weathervaning fuselage is the biggest hindrance there, whether it's thick or thin. In fact a thicker fuselage with more of an airfoiled shape would be your best bet.
This 12 oz Swiss Fish here had wings with a thinner chord and airfoil, and it was a fair bit slower than the buzz (at 9-10 oz with a fatter chord and airfoil).
Jivin' with the Breeze (8 min 12 sec)
Anyway, really cool project Chip. I'm excited to see others going this direction.
JGAF is offline Find More Posts by JGAF
Old Apr 17, 2016, 06:18 PM
gonzalo contrera is offline
Find More Posts by gonzalo contrera
gonzalo contreras
gonzalo contrera's Avatar
caracas
Joined Feb 2007
Hi Chip, whit a Voltij style.....
gonzalo contrera is offline Find More Posts by gonzalo contrera
Old Apr 17, 2016, 06:31 PM
Carlsbad, Ca
Joined Mar 2007
Ha,
...the Voltij style EPP build was this one, the Volt
Old Apr 17, 2016, 06:32 PM
Carlsbad, Ca
Joined Mar 2007
Originally Posted by JGAF View Post
........Anyway, really cool project Chip. I'm excited to see others going this direction.
Thanks Justin,...
....for advancing our sport....
Old Apr 17, 2016, 11:39 PM
Slopemaster is offline
Find More Posts by Slopemaster
Slopemaster's Avatar
United States, ID, Boise
Joined Aug 2015
Very Cool, definitely good for keeping the brain to thumb connection tuned up.
Slopemaster is offline Find More Posts by Slopemaster
Old Apr 22, 2016, 12:52 AM
Carlsbad, Ca
Joined Mar 2007
Picked up some Braided Line for my Pull/Pull,...
....instead of using the Dacron Fly Line I've used before. Crossing my Stab lines and just transitioning the vertical to horizontal orientation on my Rudder lines. I'm running both sets thru the head of a small Wire Tie, which I've CA'ed into the fuselage to help guide and keep them taunt against the fuselage.
Taped my 1000mah 6V AAA battery pack up front to achieve a 10oz AUW
Old Apr 26, 2016, 12:40 AM
Carlsbad, Ca
Joined Mar 2007
I cut out and drilled the Aileron control horns,...
....and fitted my control rods. Just need to make a couple Z-bends and adjust my servo trim.
Time to start thinking about the routing of my servo lines to the Rx side of the fuselage and bundle them.
Build Log Beginner Vac U Tug Jr Fishing boat and Recovery Boat Build Update: Caught First Fish f.a.r.m.e.r Scale Boats 70 May 26, 2016 06:10 AM
Sold Nieuport 17 - VK kit bones + UPDATE w/ motor - Bones sold; motor still available Jim OHaver Aircraft - Electric - Airplanes (FS/W) 0 Jul 04, 2009 07:26 PM
Yippee! New HD Fish (yes, flying fish) hybris 3D Flying 12 Apr 27, 2004 10:42 PM
1 Fish, 2 Fish, Red Fish, I crashed my Raven! LuckyArmpit Electric Sailplanes 5 Apr 25, 2004 06:54 PM
