Old May 15, 2015, 12:55 PM
sajeev is offline
Find More Posts by sajeev
United States, VA, Fairfax
Joined Feb 2004
best electronics?
Here is my configuration:
t-rex 450
EC135 scale fuse
I plan to put a 4 blade scale head on it.
it has a Turnigy 2800kv motor and a CC 35 amp ESC.
What would be the best stablization system for it for scale like flying? Hands off hover ?
Many thanks
sajeev is offline Find More Posts by sajeev
Old May 15, 2015, 02:03 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
sajeev:
For your size, most of the smaller 3axis gyros will do the job nicely without breaking the bank. I have used many and for the money, the AR7200BX will work very nicely. You will need to mechanically phase the head or have a plug n' play head. Your radio will be the best determining factory for your gyro choice. Hands 0ff Hover is not a function of the gyro but directly caused by the proper setup of the head, servos, and tail. Balance point is important too, but for most flying, scale helicopters have tended to be setup slightly nose heavy for better forward flight characteristics. Hope this helps.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old May 15, 2015, 02:09 PM
sajeev is offline
Joined Feb 2004
Thanks Don. I assume with the BX receivers I don't need a gyro for the tail?
Old May 15, 2015, 04:55 PM
getsuyoubi is online now
Find More Posts by getsuyoubi
United States, NY, New York
Joined Sep 2013
Correct, it's a full blown FBL system.
getsuyoubi is online now Find More Posts by getsuyoubi
Old Jun 11, 2015, 02:15 PM
sajeev is offline
Joined Feb 2004
HK 4 blade head
I got a HK 4 blade head. First hover, the heli is all over the place. Completely unstable.
Old Jun 11, 2015, 02:23 PM
Keyrigger's Avatar
Joined Sep 2009
Sounds like you didn't do the blade phasing properly. There are lots of posts on this forum about how to set the phasing up so have a look for them and see if that is where your problem stems from. Simple way to check, put one blade directly over the boom and push forward on the elevator stick. There should be no movement of the blade at all. If there is, your phasing is wrong and needs to be setup. Take care.
Don
Old Jun 11, 2015, 02:40 PM
sajeev is offline
Joined Feb 2004
i did phase it. Here is a video i made yesterday of the play in the swash lock assembly
HK 4 blade head play (0 min 58 sec)
but i think the problem is with the blades. i need to weigh them all and balance them. I will start over and more slowly this time.
Old Jun 11, 2015, 03:34 PM
Keyrigger's Avatar
Joined Sep 2009
Yes, there is a lot of play in that assembly. Start with trying to get the swash driver arms tighter to the washout base. If the driver can allow the swash to move too much, it will be hard to control. The blades must be balanced to weigh the same, and their center of gravity must also be in the same place for each blade. You need to be within .2gr of each other with small blades. A simple see-saw balancer from Align will let you get them pretty much spot on for static balance. One other thing that might help is to lower the swash driver on the main shaft a bit. At zero pitch, it should have the arm level to the swash. Good luck with the work.
Don
Old Jun 11, 2015, 03:57 PM
Bad Creation is offline
Find More Posts by Bad Creation
Bad Creation's Avatar
United States, FL, Orlando
Joined Dec 2009
Hello hey try tightening up your Swash driver is where the brass fitting is that's where all your slop is I have worked with those heads many of times I have 4 of them now I am using weighted Blades with mine though You will need a 1.5MM hex head to tighten it up. And by the way you would do a lot better with a 40amp ESC and a 4cell Batt because of it being so tail Heavy but it will work with a 3Cell just have to add more weight here's mine
EC-135 new footage (5 min 3 sec)
Bad Creation is offline Find More Posts by Bad Creation
Old Jun 11, 2015, 04:33 PM
sajeev is offline
Joined Feb 2004
Wow !!! That is so smooth and stable. Could you please help post some close up pictures of your setup and mods etc?
Old Jun 11, 2015, 04:34 PM
sajeev is offline
Joined Feb 2004
Yes the brass fitting it where it's loose. I was planing to add some washers and/ or a hex nut.
sajeev is offline
Joined Feb 2004
What are weighted blades ?
Old Jun 11, 2015, 04:36 PM
sajeev is offline
Joined Feb 2004
ESC is 40 amp CC talon. But can the motor take that voltage ?
Old Jun 12, 2015, 08:24 AM
Joined Dec 2009
There already is a Hex nut their I told you wrong its not the Brass fitting its the screw that go' thru it and here's where I got the weighted Blades http://www.scaleflying.com/Symmetric...5-_p_1072.html now if your going to use these Blades you can not use them with a FBLs system I do not have a FBLs system on my Heli's but I have grown accustomed to flying mine that way it can be a hand full at times so if you want to take it easy I would Recommend getting the FBL's System. Oh and by the way the Motor can handle the 40amp it will actually run cooler this is the motor I use http://www.hobbypartz.com/60p-dym-0011.html and its a 2750KV I am running a 13tooth Pinion I am using 5 of these Motor's in my Scale Heli's but the motor you have should be good enough. Hey I have a B400 inside of mine Check out my Channel on youtube you can see all my Planes and Heli's Name: 100_1564.JPG
Description: this is the tool I was talking about
Old Jun 12, 2015, 08:35 AM
sajeev is offline
Joined Feb 2004
your youtube channel is C Hunt ?
Discussion Best Electronics warbird56 Electric Plane Talk 18 Oct 17, 2014 07:27 PM
Question Best way to power essential electronics? danstrivelli Multirotor Power Systems 0 Jul 17, 2014 11:52 AM
Sold The best ever large electric retracts Electron NEW Chuchuf Aircraft - General - Miscellaneous (FS/W) 3 Feb 21, 2014 12:27 PM
Question What Is The Best radio And Electronics To Use On 1/8 gpv-1 Venom Bikes John_G Motorcycles 1 Nov 22, 2013 09:44 PM
