Old Jan 07, 2015, 05:45 PM
freefall2907 is offline
Find More Posts by freefall2907
United States, IA, Iowa City
Joined Mar 2013
q tee s tee
anyone know if anyone is laser cutting these two airtronics q-tee s- tee???thank you Ronald
freefall2907 is offline Find More Posts by freefall2907
Old Jan 08, 2015, 12:00 AM
GallopingGhostlr is online now
Find More Posts by GallopingGhostlr
Vintage Aircraft Lover
GallopingGhostlr's Avatar
United States, NM, Clovis
Joined Jan 2013
I don't know of anyone laser cutting these. One thing good about these is they are so simple that doing your own kit is not hard. For one, the constant chord wing uses all the same ribs. The stabilizer is built up with no fancy shaped pieces. The fuselage sides are one piece. Basically if you print 2 plans, you can cut up one and use the cut outs as templates. Use paper stick glue to temporarily attach to balsa for cutting. In short you'll have a kit in nothing flat.
GallopingGhostlr is online now Find More Posts by GallopingGhostlr
Old Jan 08, 2015, 01:39 AM
mrcosmo is offline
Find More Posts by mrcosmo
mrcosmo's Avatar
Australia, VIC, Melbourne
Joined Nov 2009
Here you go, the Q-Tee as a laser cut kit:
http://hangarcats.com/index.php?main...&products_id=4
I have the 1morstik kit from Jtech Laser and it's awesome
mrcosmo is offline Find More Posts by mrcosmo
Old Jan 08, 2015, 02:18 AM
Joined Jan 2013
Where is Hangar Cats located? None of the links on their website explain their location. The only way to contact is through a web form to them.
Old Jan 08, 2015, 06:55 AM
kkphantom is offline
Find More Posts by kkphantom
kkphantom's Avatar
Australia, WA, Perth
Joined Nov 2010
Look on the website for the EQT and follow the link for the build log and you'll find the kit manufacturer is Eliworm on this forum which means he is in Arizona.
kkphantom is offline Find More Posts by kkphantom
Old Jan 08, 2015, 08:01 PM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
I do one in short kit version. Send me a p.m. for info.
John
Q Tee
Rubbernecker is offline Find More Posts by Rubbernecker
Old Jan 13, 2015, 09:52 PM
Joined Mar 2013
q tee s tee short kits
John PM sent
Old Jan 15, 2015, 07:47 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Awww c'mon there are like a Dozen parts to these .
A # 11 blade will do Very nicely.
Bare is offline Find More Posts by Bare
Old Jan 15, 2015, 10:30 PM
Joined Jan 2013
Originally Posted by Bare View Post
Awww c'mon there are like a Dozen parts to these. A #11 blade will do Very nicely.
They are also easy to repair.
http://www.rcgroups.com/forums/showthread.php?t=2028047
Old Jan 21, 2015, 09:50 PM
moniman is offline
Find More Posts by moniman
United States, AZ, Sun Lakes
Joined Nov 2014
I know you're looking for laser cut, but just in case here's a free plan download from outerzone for the Q-Tee http://www.outerzone.co.uk/plan_details.asp?ID=1350
moniman is offline Find More Posts by moniman
Old Jan 22, 2015, 12:59 AM
Bare is offline
Canada
Joined Nov 2000
Originally Posted by GallopingGhostlr View Post
Absolutely! Mine has been brought back from a complete mess a * few * times as well. It even looked pretty darned good...once revived.
Old Jan 25, 2015, 06:02 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
ditto
You could "kit" it out and build it faster than an order will arrive.
ozmo01 is offline Find More Posts by ozmo01
Old Jan 25, 2015, 06:21 PM
Andrew0820 is offline
Find More Posts by Andrew0820
Western KY
Joined Sep 2003
Bare and ozmo01 are correct. Parts count is minimal and there's nothing complex about the build.
George has also shown that they're an easy fix in case of a mishap.
Andrew0820 is offline Find More Posts by Andrew0820
Wanted airtronics q tee and s tee kits freefall2907 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 07, 2015 12:41 PM
Sold Q-Tee by Airtronics ton2di Aircraft - Fuel - Airplanes (FS/W) 2 Sep 23, 2014 06:55 PM
Build Log Micro-Tee, foamie a mini Q-Tee AR6400 Slow Flyer TheRealMrEd Scratchbuilt Indoor and Micro Models 33 Aug 29, 2014 06:19 PM
Discussion Airtronics S-Tee conversion from Q-Tee ? turbojoe Balsa Builders 5 Feb 27, 2013 02:48 AM
Q-Tee/S-Tee by Airtronics...... Jim_W Electric Plane Talk 16 Feb 24, 2005 08:15 PM
