Old Nov 18, 2014, 10:37 PM
RC Aerobat's Avatar
Australia, SA, Adelaide
Joined Jul 2013
Question
Max angle of attack for wing in ground effect vs the same wing not in ground effect
With two identical wings, one flown in ground effect and one not, does the maximum possible angle of attack before stall change with the ground effect wing? eg. higher, lower?
Also do leading edge slats work as well on a wing in ground effect?
RC Aerobat is offline Find More Posts by RC Aerobat
Old Nov 22, 2014, 11:15 PM
Australia, VIC, Bass
Joined Jan 2013
This is a pretty technical question -as most of the lift in ground effect is generated buy pressure beneath the wing,then in theory the airflow over the upper surface may brake away into a stalled condition without the wing losing much lift...but the increase in drag would be significant slowing the craft down which then results in rapid loss of lift. ?? Hope that helps.
windnsea is offline Find More Posts by windnsea
Old Nov 23, 2014, 08:46 AM
RC Aerobat's Avatar
Joined Jul 2013
Thanks, so you can still fly with the wing stalled.
Yeah thanks, thats the kind of answer I wanted.
Old Nov 24, 2014, 11:38 PM
Denver, CO
Joined Dec 2005
The farther you go into a stall the less lift you have. If you go far enough into the stall, the wings lift is not going to support the aircraft. Then the only thing holding the aircraft up is the motors thrust, if its not directed downward the aircraft is going down. There are many charts that describe it, here is one (described in link below). The basics are that you have more lift in ground effect, and can either go slower, or increase the angle of attack, and have more lift that if you did that in free airflow.
http://www.academia.edu/461509/Groun..._Ground_Effect
Roto Rob is offline Find More Posts by Roto Rob
Discussion Multiple DJI 2.4ghz datalink / ground stations in same area nomos Multirotor Talk 2 Oct 25, 2014 12:32 AM
Discussion Belt CP - blade tracking OK but paddles not in same plane as blades, slight angle turnbui Micro Helis 2 Jun 30, 2009 01:57 PM
Question Effects of built in angle of attack on speed envelope? iceburg47 Foamies (Scratchbuilt) 4 Feb 07, 2009 12:38 AM
Discussion WIG - Wing in Ground-Effect alexcmag Waterplanes 17 Jul 31, 2008 10:08 AM
Off Site Exotic Aircat 2.0 Part Assmb Kit Wing in ground effect (WIG) vrylowflyer Aircraft - General - Miscellaneous (FS/W) 0 Jul 30, 2007 08:57 AM
