Old Jul 14, 2015, 12:36 PM
mrittinger is online now
Find More Posts by mrittinger
ARFs make me BARF
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Build Log
22" ff-> rc sbd/a24
With the quick and fatal destruction of my short lived 24" Jug, I decided to move on and try another.
Picked up a 21 3/4" span Diels printwood SBD Dauntless kit. Might build it as a USAAF A24, we'll see.
Will post as I progress. Looks like nice kit, great wood, canopy, jap tissue,decals.....
mrittinger is online now Find More Posts by mrittinger
Old Jul 14, 2015, 01:03 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
21 3/4" span
She's had a child ?, and I knew nothing about it
eflightray is online now Find More Posts by eflightray
Old Jul 14, 2015, 01:12 PM
ARFs make me BARF
mrittinger's Avatar
Joined Dec 2000
Bambino ! Lol
Should be nice ship...
Old Jul 14, 2015, 01:31 PM
Brian Allen is online now
Find More Posts by Brian Allen
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
Mark
Gotta love the A-24. Go for it.
Brian
Veni Vidi Volavi
I came I saw I flew
Brian Allen is online now Find More Posts by Brian Allen
Old Jul 14, 2015, 02:10 PM
glewis is online now
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
With that big wide wing and a 21" span, you should have an abundance of power.
You could add another servo and make a droppable bomb? That would be cool!
glewis is online now Find More Posts by glewis
Old Jul 14, 2015, 03:31 PM
ARFs make me BARF
mrittinger's Avatar
Joined Dec 2000
I could use rudder servo since its rarely used. I like to keep it simple though....
Old Jul 14, 2015, 03:36 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
O man now I need to get back on my Guillows SBD
Old Jul 16, 2015, 07:02 AM
ARFs make me BARF
mrittinger's Avatar
Joined Dec 2000
Started cutting a few parts...this is a nice kit, but a wee bit overcomplicated.... Lots of parts and a lot of cutting, especially stringer notches.
Old Jul 16, 2015, 08:50 AM
T_om is offline
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
I am probably telling you something you of course already know, but for the benefit of others perhaps it is worth mentioning.
I never "cut" stringer notches any more. I have a bunch of homemade "notch files".
I don't have any shots of one handy but here is exactly the same thing except with grit on all sides instead of just on one edge like my notch files. I use this type in different grits to shape foam and balsa blocks.
The notch files are made from free paint sticks from big box stores (I like the ones from Lowe's better than the ones from Home Depot). Plane or sand them to the thickness required for the notch, put a thin-to-medium coat of epoxy on the edge, then sprinkle carborundum or silicon carbide grit in the wet epoxy. I have different grits but found 80 and 120 to be the most useful. After it sets, you have a file the exact thickness you want and it just floats through balsa and foam. A stroke or two per notch is all it takes.
Amazon carries it but I get mine from my local Woodcraft store. http://www.amazon.com/Silicon-Carbid...ription-iframe
Tom
T_om is offline Find More Posts by T_om
Old Jul 16, 2015, 09:30 AM
ARFs make me BARF
mrittinger's Avatar
Joined Dec 2000
I do similar. I use a piece of 1/16 sheet with a strip of 320 grit a hair narrower than 1/16 glued to the edge. I have autobody self adhesive sandpaper. I put a guide on each side so the depth is exactly 1/16, so I get a nice tight fitting 1/16 square slot.
I also have one without guides to sand in the keel slots.
Old Jul 16, 2015, 11:22 AM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I found my flat needle file makes a perfect 1/16 notch. The file removes wood slowly too. While this requires a bit more effort, but I get a nice clean notch.
I just purchased #11 scalpel blades and a handle from www.havels.com. I'll be cutting parts soon and testing it out. The scalpel blades seem much sharper than hobby knife blades. I usually use a single edge razor blade because Xacto blades don't last very long.
What do you use for cutting parts?
Old Jul 16, 2015, 12:02 PM
ARFs make me BARF
mrittinger's Avatar
Joined Dec 2000
No 11 X Acto. Over 1/8" balsa I go to bandsaw.
Old Jul 21, 2015, 12:22 AM
Jugjock is offline
Find More Posts by Jugjock
Jugjock's Avatar
Arvada, Colorado
Joined May 2004
On the frequency now, Mark. Very much interested to see how you detail this one. Thanks for the tip on notches; and Glenn, thanks for the URL on surgical blades. I swear, the X-acto blades are getting duller by the batch. Chris
Jugjock is offline Find More Posts by Jugjock
Old Jul 21, 2015, 06:29 AM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
[QUOTE=Jugjock;32210111 I swear, the X-acto blades are getting duller by the batch. Chris[/QUOTE]
As are single edge razor blades. Only ones I can find now are made in China out of some kind of soft steel. A few cuts and in the trash. They are cheap and inexpensive...
Old Jul 21, 2015, 06:57 AM
coulee is offline
Find More Posts by coulee
I FLY ORANGE!
coulee's Avatar
United States, SD, Tripp
Joined Jun 2009
I am sure glad someone else is noticing this. At the beginning of the Curtiss build, I bought a new brick of 100 x-acto blades (the fancy blue ones) and I swear to peanut butter, I used twenty to get through one plane.
I remember as a kid just being lucky to have AN x-acto blade for a years worth of hobby stuff... they were never perfect but they always managed to stay sharp enough.
Ted
coulee is offline Find More Posts by coulee
Build Log 24" FF->RC Jug mrittinger Scale Kit/Scratch Built 148 Yesterday 05:16 PM
Build Log BBCC6 Bristol Beaufighter 28" FF->RC victapilot Balsa Builders 2 Jul 15, 2015 04:43 PM
Sold Heritage RC SBD kit acemcduck Aircraft - Fuel - Airplanes (FS/W) 1 Jan 01, 2015 10:19 AM
Build Log Very Slowww RC Dougas SBD-3 Dauntless malt_master Electric Warbirds 3 Mar 21, 2007 10:56 PM
