Old May 30, 2015, 01:52 PM
bijoy krishnan is offline
Find More Posts by bijoy krishnan
bigB3699
Joined Mar 2015
Question
Is it possible to connect more than 1 proximity sensors to APM 2.7 ???
I need to use more than one (atleast 3)proximity sensors for my hexacopter to avoid obstacle !!!!
i use hk pilot 2.7 (apm 2.7)!!!
i know one can be connected to the analog port not sure if more than one is possible or not !!!!
if yes , which ports should i use to do that and how to controle it through mission planner!!!
bijoy krishnan is offline Find More Posts by bijoy krishnan
Old May 31, 2015, 08:39 AM
Oldgazer is offline
Find More Posts by Oldgazer
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
Like I already told you the answer is NO. APM does not support multiple Sonar sensors, and the only functions the Sonar provides is aircraft altitude below 7 meters.
Oldgazer is offline Find More Posts by Oldgazer
Old May 31, 2015, 04:34 PM
Robert_AU is offline
Find More Posts by Robert_AU
Australia
Joined Jul 2012
There have been a few engineering students posting on RCG for help with their projects. Anything is possible but YOU must have the necessary skills to solve the problem.
You have the wrong flight controller for this project. The APM doesn't have the processing power or available memory required. Arducopter developers are no longer developing for the APM, with development moved entirely to 32 bit platforms, such as, the pixhawk and clones.
The only thing missing to use multiple sonars on the APM or pixhawk is the code to do it. The I/O hardware exists. YOU would need to write the code to read the sonars, interpret their meaning and to avoid obstacles. Although, lasers would be better than sonar. If you do not have the necessary programming skills, you should change your project.
Robert_AU is offline Find More Posts by Robert_AU
For Sale APM 2.6 2.1 XBees + Sensors + more JasonGlatzer FPV Equipment (FS/W) 0 Mar 27, 2015 08:34 PM
Sold APM 2.7.2 with Power Module and Voltage/Current Sensor tpearsall Aircraft - Electric - Multirotor (FS/W) 2 Mar 07, 2015 03:04 PM
Sold PM 2.6 + sensors FY31AP +Hornet OSD APM 2.1 Mimim OSD Xbees + More JasonGlatzer FPV Equipment (FS/W) 1 Dec 30, 2014 06:15 AM
Sold APM 2.6 + sensors FY31AP +Hornet OSD APM 2.1 Mimim OSD Xbees + More JasonGlatzer FPV Equipment (FS/W) 0 Nov 26, 2014 08:48 PM
Sold APM 2.5 with Airspeed sensor, Power module, and more! snipeworm Aircraft - Electric - Multirotor (FS/W) 3 Jun 09, 2013 11:44 PM
