Old Jul 27, 2015, 03:21 PM
vketil is offline
Find More Posts by vketil
Joined Jul 2015
Problem mixing elevon on Turnigy 9x
I have a problem whit mixing elevon on my Turnigy 9x for my flying wing zeta fx-61. I use the immersion ezuhf transmitter.
my setup is channel one - left wing
channel two - right wing
channel three - Throttle
Problem: whit elefon mixing the channel one (left servo) dont work at all. I know the servo is working. The transmitter is also default.
Someone had the same problem and can help me whit this?
vketil is offline Find More Posts by vketil
Old Jul 29, 2015, 11:46 AM
andreiv is online now
Find More Posts by andreiv
Joined Sep 2014
Do you have default Turnigy 9x firmware or something else (er9x, opentx)?
andreiv is online now Find More Posts by andreiv
Old Jul 29, 2015, 12:27 PM
vketil is offline
Joined Jul 2015
Thanks for your reply
I have the default Turnigy 9x firmware
What can be the problem?
Old Jul 29, 2015, 01:06 PM
Joined Sep 2014
I kinda wished you had something else than default firmware. It's been a long time since I saw the default one. If I remember correctly...in the mixer menu there are several different mixing options elevons, flaperons etc. I had problems getting mixing working correctly because I had several mixers activated at the same time -> which lead to strange behavior
Try disabling everything else except elevons. Sry I couldn't help more.
BTW you really should look into ER9X or Opentx firmwares. They transform 9X into a real radio ! You can get USBasp programmer for $3 from ebay
Old Jul 29, 2015, 02:54 PM
vketil is offline
Joined Jul 2015
I get the message: Other wing mix "on"
What does that meen? I don`t think i have any mix going on know.... Or have i?
Maybe i shoud update my controller....
Old Jul 29, 2015, 03:16 PM
Joined Sep 2014
That's exactly what I'm talking about. You have some other mix activated. For example go to Flaperon menu and make sure STATE is not ACT (should be OFF or something)
One easy way to make sure you dont have anything weird mixes on, it create a new model (or reset current)
Youtube seems to have many tutorials on elevon mixing
Turnigy 9x elevons setup for f22 rcpowers (7 min 51 sec)
Old Jul 29, 2015, 03:23 PM
Joined Sep 2014
And yeah, you should reflash it. I have the same radio with ER9X. One thing I really hated about default firmware was the fact that, you couldn't reassign switches to do something else . In er9x you can make them do what ever you want.
Help! Elevon mixing problem FlyByWheel Electric Plane Talk 12 Jul 15, 2015 06:59 AM
Discussion turnigy 9x help with elevon mixing gainey Radios 3 Jul 14, 2014 05:18 AM
Discussion Need help with elevon mixing on Turnigy 9X radio. mrebman Radios 4 Jan 14, 2013 07:45 PM
Discussion Really confused on elevon mixing on my 9x. Koo Radios 0 Aug 02, 2012 07:46 PM
Question How to do Elevon Mix on JR 9X Ash T Radios 3 Feb 19, 2005 02:59 AM
