Old Dec 05, 2010, 07:02 PM
E-reevo is offline
Find More Posts by E-reevo
E-reevo's Avatar
Joined Aug 2010
Speed control question
I was wondering if your esc burnt up would you lose all control of the plane or would you still have the use of servos. Thanks!
E-reevo is offline Find More Posts by E-reevo
Old Dec 05, 2010, 07:18 PM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
If your esc burnt up you would lose all control of the plane. No servo's no nothing.
wellington53 is offline Find More Posts by wellington53
Old Dec 05, 2010, 07:20 PM
RyanPSU21 is offline
Find More Posts by RyanPSU21
RyanPSU21's Avatar
USA, MI, Harrison Township
Joined Sep 2000
If you're ESC burnt up and it contained the BEC that was powering the RX then you are out of luck and going to have no control.
If the ESC did not contain the BEC powering you're reciever or you were using a seperate RX battery, then no, you still have control of your servos.
That being said, the couple of times I've seen an ESC burn up it's either started a fire in the plane or come close to it so one better land in a hurry and get the ground almost as fast as crashing to put the flames out if need be.
RyanPSU21 is offline Find More Posts by RyanPSU21
Old Dec 05, 2010, 09:43 PM
flypaper 2 is online now
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Had that happen to one of mine. Left a trail of smoke from about 300 ft. like I'd beem shot down with AAA
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 05, 2010, 11:24 PM
machinate is offline
Find More Posts by machinate
machinate's Avatar
Joined Jan 2010
A lot depends on how the ESC fails. It's possible to burn up some of the power MOSFETS and lose your motor but still have a functional BEC. It's also possible to roast the whole thing and lose radio contact. Mostly the difference comes down to luck.
If you're concerned, or flying a large and therefore dangerous model, you should use a separate BEC.
If you're paranoid, consider running a separate receiver pack like we used to use with fuel-powered models.
machinate is offline Find More Posts by machinate
Old Dec 06, 2010, 03:33 PM
moyg is offline
Find More Posts by moyg
Morristown,NJ
Joined Oct 2003
Had a 80% XBOW w J250 motor. The motor wore out & pulled a lot more than the ESC could handle - flames came out mid-air burning through the FFF, had enough control to land it. BEC was still good afterwards.
moyg is offline Find More Posts by moyg
Sold 100A speed control Ron Cate Aircraft - Electric - Power Systems (FS/W) 3 Nov 12, 2010 03:25 PM
Alert Value Hobby Lipo Battery & Electronic Speed Control SALE! mtdoramike Hot Online Deals 3 Nov 08, 2010 06:21 PM
Discussion Hitec HAS-3mb with Jeti JES110 Speed Control.... broken? derekm280 Batteries and Chargers 2 Nov 06, 2010 08:05 PM
Discussion Steam Speed Control jonriley56 Steam Boats 6 Nov 04, 2010 11:02 PM
Sold Kontronic Jazz 40-6-18 speed control bfraser Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 10:31 PM
