Old Aug 30, 2014, 06:35 PM
United States, CA, La Honda
Joined May 2014
Originally Posted by mkpatrick View Post
I will check that, what size screws are what should be in there?
Not sure what size is suppose to be there. Motion RC sent me a replacement hardware pack to fix the problem, but the hardware package sent didn't have anything in it for mounting the nose gear. I went to a hardware store and bought short wood screws with a flat countersunk head that looked like it would fit the recess on the retract. I just bought a few of a couple of sizes and lengths. If you search on posts from me, you'll find one from a month or so ago that had a picture of the nose gear as it came with the small screws. I posted it and asked if they were too small, and they were.
Scott
seldredge is offline Find More Posts by seldredge
Old Aug 30, 2014, 09:54 PM
mkpatrick
Joined Mar 2011
Scott
What size did you end up going with?
mkpatrick is offline Find More Posts by mkpatrick
Old Yesterday, 01:44 AM
Joined May 2014
One of these, not sure which right now (don't have access to the plane), but I'd guess the smaller. It fits the tapered hole exactly. They are both about 1/2 inch long. The large one has a head that's 1/4 inch dia.
Old Yesterday, 05:23 PM
United States, CA, Elk Grove
Joined Jan 2012
I would suggest, If you can, take the gear mounting plate with you and see what size screw fits into the hole and tapered part. That's what I usually do when I'm looking for a replacement.
jgroetsema is offline Find More Posts by jgroetsema
Old Yesterday, 07:54 PM
mkpatrick
Joined Mar 2011
Is there anchor points in the fuse to drive screws into? Do they go in with a self tapping screw? Sort of like a wood screw?
Old Yesterday, 08:10 PM
mkpatrick
Joined Mar 2011
Mine seems to have come with a bad Y cable for the ailerons.
My Spectrum 9 ch 9020 also is not working. It flashes one time upon power up and then nothing.
I was hoping to fly this tomorrow.
Old Today, 12:15 AM
mkpatrick
Joined Mar 2011
Nose gear
The nose gear screws look to be fine. But I noticed a lot of play in the strut.
I see that the nose wheel strut can be simply, lifted right out of the retract, with only the music wire from the gear steering servo holding it in place.
Can this be right?
Is there some sort of grub screw to tighten here?
Old Today, 01:07 AM
Joined Jan 2012
On my nose wheel strut (Airfield very 2), it is held in by an "E" ring clip on the end of the shaft. You have to disassemble it to get to it. I'll see if I can't dig up some pics.
Old Today, 01:48 AM
Joined Jan 2012
Well, not exactly the nose gear, but should do.
[/IMG]Name: uploadfromtaptalk1409553423841.jpg
Description: Name: uploadfromtaptalk1409553450344.jpg
Description: [/IMG]in the first image you can see the trunnion (pivot point) attached to the end of the shaft. The brass insert is where set or grub screws would go. For it to steer, it needs to pivot.
In the second photo, part of the shaft extends through the trunnion. This is where the "E" ring clip would go. This is what keeps it from falling out. On the other end a collar is needed to keep the shaft from pushing through.
Hope this helps.
Old Today, 02:32 AM
mkpatrick
Joined Mar 2011
[/IMG]Attachment 7064141Attachment 7064142[/IMG]in the first image you can see the trunnion (pivot point) attached to the end of the shaft. The brass insert is where set or grub screws would go. For it to steer, it needs to pivot.
Hope this helps.
Thanks for the help on this.
I've retracted it and extended it over and over. The gear can only come so far in (upwards) when extended. It hits a stop.
But if pulled on, it slides out. However the wire that goes to the steering servo, is kept into place by a keeper, preventing it from coming out of the gear bay, this seems to be whats holding the nose strut into place.
When rolling on the ground, there is no apparent up and down play.
However, there is some side to side play.
This is a V3, which has spring wires that close the gear bay doors.
If this is a defect, I can't see a way to fix it. I haven't messed with retracts much.
BTW- Is there a way to slow these gear down as far as extending and retracting them?
New Product FMS F4U Corsair 1400mm EPO Warbird jbc Electric Warbirds 8429 Today 01:31 AM
New Product FMS Stuka 1400mm EPO warbird jbc Electric Warbirds 4296 Aug 27, 2014 11:16 PM
Discussion FMS Giant P-47 EPO 1400mm Warbird jbc Electric Warbirds 3913 Jul 14, 2014 09:08 PM
Discussion Old Bf109 by FMS Beltpilot Electric Warbirds 812 May 12, 2014 04:51 PM
Discussion FMS FW-190a 1400mm Tommy D Electric Warbirds 1811 Feb 02, 2012 07:54 PM
