Old Jul 14, 2014, 12:54 PM
What's goin' wrong?!
ege53's Avatar
Joined Feb 2005
Build Log
Fast Company
I have thought about making a plane like this for a couple of decades. I know it will be a monumental amount of work, but with perseverance, help from friends and family, and advice from fellow RC Groups forumites, I might even be able to pull it off.
I have read quite a few build threads, along with lots of other information, relating to a project like this. I am reluctant to commit to doing a Build Log because the time required just for the Build Log itself will be significant. But, since I appreciate the efforts of other builders' Build Logs, I hope to contribute just a little bit to the overall amount of information.
The Fast Company will be nearly 100% based on VS Sailplanes Rotor and V-Max. Here is a short list of characteristics:
Pitcheron wing, and maybe a canopy air brake
2 Meter span using the S6062 airfoil, 7" root, 4" tip, straight 25% MAC
100 degree V tail using NACA 0006 airfoil
48" long fuselage
These following threads have been quite influential to me:
BillO's Zmax. http://www.rcgroups.com/forums/showthread.php?t=974539
Hutch's Sushi. http://www.rcgroups.com/forums/showthread.php?t=460568
Reed's Jart. http://www.rcgroups.com/forums/showthread.php?t=259967
blewis01's Tribute. http://www.rcgroups.com/forums/showthread.php?t=892925
In the beginning I am making a fuselage plug. I used 1/4" layers of MDF, laminated with TiteBond glue. I have slathered on several applications of epoxy, and I am getting ready to fair the surface with Bondo. . . . . and a whole bunch of sanding!
Eric
ege53 is online now Find More Posts by ege53
Old Jul 14, 2014, 10:37 PM
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Deja vu! This will be a great project, I learned a lot on mine, I've built several now and they just keep getting better and better. Good luck with yours Eric!
BillO is offline Find More Posts by BillO
Old Jul 14, 2014, 11:45 PM
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Best of luck to you, please keep the pics coming!
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Jul 15, 2014, 02:10 AM
Geppetto
1stGeppetto's Avatar
United States, CA, San Francisco
Joined Dec 2005
Dude! I'm watching!
Geppetto
1stGeppetto is offline Find More Posts by 1stGeppetto
Old Jul 15, 2014, 10:00 AM
bluffman's Avatar
Joined Sep 2003
Awsome
bluffman is offline Find More Posts by bluffman
Old Jul 15, 2014, 11:52 AM
Tehachapi Jim's Avatar
United States, CA, Tehachapi
Joined Jul 2004
I am with ya man. Document as much as you can for us please. Trying to clear some other builds so I can begin the plug for my own 2 meter, but a wingeron. I am using MDF as well. I love VS models, but mine will be more in the Scepter ish family. Not a knock off, just influenced. Wilkerson's comments he made about people copying his design, how he felt about it (and I agree totally) and why people don't create their own is what finally prompted me to get busy.
Good luck man.
Jim
Tehachapi Jim is offline Find More Posts by Tehachapi Jim
Old Jul 15, 2014, 01:32 PM
Less Whinning, More Flying
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
I've seen the plug in person and Eric did a beautiful job of it. The pic doesn't do it justice.
Sean
Sailhigh is offline Find More Posts by Sailhigh
Old Jul 15, 2014, 02:39 PM
slopemeno's Avatar
Joined Jan 2003
Have fuse- will follow.
slopemeno is offline Find More Posts by slopemeno
Old Jul 15, 2014, 03:02 PM
that's gonna hurt...
USA, CA, San Jose
Joined May 2005
Sean
Agreed Sean, but equally impressive was the jigs Eric built to shape the plug.
Eric - thanks for posting ( and the links were pretty cool too! )
Bruce
blewis01 is offline Find More Posts by blewis01
Old Jul 15, 2014, 05:15 PM
ege53's Avatar
Joined Feb 2005
Jigs
Thanks for the comments.
Since Bruce mentioned some of the jigs, here are two photos of the foam pieces I cut to hold the plug while shaping.
Eric
Old Jul 15, 2014, 06:59 PM
Joined Jul 2004
Eric that is one way to get the angle, simple and if done right effective. Nice to see a different spin on things.
Jim
Old Jul 16, 2014, 01:06 AM
Geppetto
Joined Dec 2005
Looking good Eric! Keep it rolling!
Geppetto
Old Jul 17, 2014, 05:58 PM
ege53's Avatar
Joined Feb 2005
Defects and sanding
I tried to wet sand the surface epoxy, and got into a bit of trouble.
I think the first layer of epoxy was thin in some spots, and those places got worn through down to the MDF, allowing it to swell a bit with the water. Subsequent layers of epoxy and further dry sanding left some defects in the surface. I was using 220 grit sandpaper and the affected areas stood out from the unaffected areas.
I scraped the ten or so defects so they are now a depression in the surface. I dry sanded the whole plug with the 220 grit and I am getting ready to apply some Bondo.
Eric
Old Jul 17, 2014, 06:04 PM
Joined Jul 2004
Eric, what type of epoxy are you using. You could go for something thinner so it pent rates deeper into the MDF. But bondo works.
Jim
Old Jul 17, 2014, 11:32 PM
ege53's Avatar
Joined Feb 2005
Epoxy
It is TAP Plastics house brand epoxy.
For the first layer of epoxy I tried to skimp a bit because I don't like to be wasteful. For the first layer, at least, that was a mistake. Sometime in the future if I make another MDF plug, I will really pour the epoxy on the MDF and massage it into the entire surface with gloved hands.
Eric
Video QAV500 used for Pool Company Video designandshutter Multirotor Talk 6 Sep 20, 2013 09:36 PM
Question x company crystal with y company receiver/transmitter custom_builds Radios 7 Mar 01, 2008 07:45 AM
Discussion fast company tic High Performance 31 Apr 10, 2007 09:13 PM
Cool New 68" EPP PSS Hurricane, One Design Racer, fast wing and company AndreasMergner Slope 9 Oct 08, 2004 05:58 AM
