Old Dec 04, 2014, 06:33 AM
USA, NY, Poughkeepsie
Joined Mar 2010
no swastika decals included with this model. You can get them from Callie graphics, or order up a complete set of custom cut vinyl, the decals in the pic I posted earlier are from Callie.
rcguy1958 is offline Find More Posts by rcguy1958
Old Dec 04, 2014, 10:34 AM
Joined Nov 2014
Thanks for the tip, but being in Europe I probably can't use Callie. Oh well, I will live without or paint some myself Seems like some adjustments to the landing gear are a must. Think I will just finish the build and test fly it and then adjust as needed. Just hope it can handle the cold weather here in DK.
Beatwolf is offline Find More Posts by Beatwolf
Old Dec 04, 2014, 03:28 PM
Joined Nov 2012
....why you cant use callie ?
I live also in europe and have had no problems to order different sizes of german decals incl. The sw.
Best regards russ
russcramer is offline Find More Posts by russcramer
Old Dec 04, 2014, 05:07 PM
Joined Mar 2010
If you look back in the thread, you'll see the mod for the landing gear( basically just a plywood spacer under the back of the retract mount, slight enlarging of the wheel well, and I highly recommend finding longer set screws and putting one on each side of the unit to hold the landing gear wire in)
Old Dec 05, 2014, 04:46 PM
Joined Nov 2014
Thanks, its just often danish custom snap up things from USA, China and other non-eu countries and you have to pay tax. But I guess a pair of swastikas wouldn't go over the allowed minimum.
On another note, I'm having a problem with the build. It seems the control rod that is supposed to be attached to the rear wheel is not attached, or has come off somehow. Either that or I am retarded. Problem is that area is not really reachable without splitting it apart....any ideas?
Old Dec 05, 2014, 11:31 PM
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Beatwolf - there is a separate control rod for the tail wheel. It should tie into the same servo as the rudder. Is this control rod attached at the servo?
Kman
kman24 is online now Find More Posts by kman24
Old Dec 06, 2014, 12:54 PM
Joined Nov 2014
Hi, the control rod was there but was not attached to the piece that was supposed to hold the wheel. I got it exchanged from where I bought and got a new fuselage where that piece was attached from the beginning and did not come off.
Old Dec 06, 2014, 01:16 PM
kman24's Avatar
Joined Jan 2010
Good to hear
Kman
New Product FW-190 Typ B 1200mm EPO retracts lights mopetista Electric Warbirds 18 May 24, 2012 12:15 PM
Sold Hobbico Flyzone Focke-Wolf 190 RxR FW-190 propflipper Aircraft - Electric - Airplanes (FS/W) 10 May 08, 2012 07:07 AM
Build Log GWS FW-190 in EPO Foam mcsarge Electric Warbirds 259 Feb 20, 2010 05:58 PM
Discussion Just finished my EPO FW-190 TopSpin GWS (Grand Wing Servo) 34 May 22, 2009 06:55 AM
Sold GWS EPO FW-190 PNP Brushless + Retracts!! $150 SHIPPED!! Andrew1944 Aircraft - Electric - Airplanes (FS/W) 2 Jul 21, 2008 03:26 AM
