Old Nov 05, 2014, 10:19 PM
WZ9V, AMA 409852
United States, VA, Alexandria
Joined Jan 2007
Open TX Companion Mac
Started this thread for those of us crazy enough to attempt to get the Mac version of the latest OpenTX Companion working again.
I noticed that the qt4-mac make suggests phonon be installed separately. I'm trying sudo port install phonon in my setup. So far I'm only up to the Python bindings as far as the prerequisites.
dfruehwald is offline Find More Posts by dfruehwald
Old Nov 05, 2014, 10:35 PM
cae
Australia, NSW, Sydney
Joined May 2012
I have compiled 2.0.12 and it appears to be working OK, although I have not had time to test extensively or to make a package with all the dependencies included.
Once you get your support files installed, if you would like to check it out let me know.
In the meantime I will try and find time to make a stand alone package.
cae is offline Find More Posts by cae
Old Nov 05, 2014, 10:44 PM
WZ9V, AMA 409852
Joined Jan 2007
Sounds good. I'm on track to finish installing all the pre-requisites tonight. My plan was to pull source tomorrow.
I used a Windows laptop to put 2.0.12 on my radio so I already have the firmware to test with. All of muy development has been non-Mac so this is jumping into the deep end for me. Tons of Windows and OS/2 and a decent amount of Unix so I'm not totally worthless
Old Nov 05, 2014, 10:54 PM
United States, MN, Eagan
Joined Feb 2012
As the OpenTX Companion GitHub page hasn't had a Mac build since 2.0.8, myself and others are attempting to build the current release (2.0.12 as of now) on the Mac. This thread can be used for our working notes as we try to get this to build.
I've downloaded and installed all the prerequisites as per the GitHub Wiki, but the actual build is failing for me. It might be as simple as a missing file, but this is the first time I've pulled files from GitHub, and I'm not sure where to go look to see if I'm missing something.
https://github.com/opentx/opentx/wiki/C ... structions
oshmbp:src osh$ make
... (omitting other successful bits)
[ 7%] Built target simulation
[ 8%] Generating ../../radio/src/lua_exports.inc
Generating a list of Lua exported constants in lua_exports.txt
myeeprom.h:40:22: fatal error: inttypes.h: No such file or directory
#include <inttypes.h>
compilation terminated.
make[3]: *** [lua_exports.cpp] Error 1
make[2]: *** [../../radio/src/lua_exports.inc] Error 2
make[1]: *** [CMakeFiles/common.dir/all] Error 2
make: *** [all] Error 2
oshmbp:src osh$
John
JohnOCFII is offline Find More Posts by JohnOCFII
Old Nov 05, 2014, 11:20 PM
cae
Joined May 2012
Try this link, I think you should have access to a zip file containing the app.
https://www.dropbox.com/s/3y2vdxz3jf...n.app.zip?dl=0
Old Nov 05, 2014, 11:22 PM
WZ9V, AMA 409852
Joined Jan 2007
Thats exactly my intention. Perhaps we can collaboratively sort out the issues and find a solution for building a proper bundle for installation that can work for future versions.
oshmbp:src osh$
John
Old Nov 06, 2014, 12:21 AM
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
We should probably try building 2.0.8 first, since we know it worked on that release, then try to narrow down when it broke.
ttabbal is offline Find More Posts by ttabbal
Old Nov 06, 2014, 07:09 AM
WZ9V, AMA 409852
Joined Jan 2007
Good point but it looks like CAE may have already sorted out the compilation issues. He was able to build the app but has not bundled the libraries required. If his works it may just be a matter of folding his fix into the stream and sorting out the library issues. He posted a Dropbox link for those brave enough to try it after installing the tools.
Old Nov 06, 2014, 08:57 AM
dinamich's Avatar
Slovenia, Ljubljana
Joined Aug 2010
oshmbp:src osh$
John
Your system can't find file named "inttypes.h". This file is a part of GCC compiler distribution and should be in a directory with a bunch of other .h files. I don't know a lot about MAC, but on linux (osx seems similar) such files are in /usr/include directory.
What happens if your run this command in terminal?
Code:
find /usr/ -name "inttypes.h"
On my system (linux) I get:
Code:
$ find /usr/ -name "inttypes.h"
/usr/lib/avr/include/inttypes.h
/usr/lib/syslinux/com32/include/inttypes.h
/usr/include/inttypes.h
/usr/include/c++/4.6/tr1/inttypes.h
dinamich is online now Find More Posts by dinamich
Old Nov 06, 2014, 10:11 AM
Rod Cole's Avatar
United States, TX, Austin
Joined Jun 2012
Compilation Error
I was able to get all of the prerequisites installed and have attempted to compile Companion 2.0.12.
This is the error I received:
Scanning dependencies of target simulation
/Library/Frameworks/SDL2.framework/Headers/SDL_platform.h:83:3: error: SDL for
Mac OS X only supports deploying on 10.5 and above.
# error SDL for Mac OS X only supports deploying on 10.5 and above.
1 error generated.
make[2]: *** [simulation/CMakeFiles/simulation.dir/simulatordialog.cpp.o] Error 1
make[1]: *** [simulation/CMakeFiles/simulation.dir/all] Error 2
I checked my SDL and it says I have 10.5 installed. Perhaps the source code is pointing to 10.4 in some module but I don't know where to start looking.
Oddly enough, when the compile failed on OS X (Mavericks) I decided to try compiling Companion 2.0.12 on Linux and it did so with no errors.
I think I will attempt to compile 2.0.8 when I have time as ttabbal has suggested.
Here is my results from find for inittypes.h
Rods-Mac-Pro:src rod$ find /usr/ -name "inttypes.h"
/usr//include/c++/4.2.1/tr1/inttypes.h
/usr//include/inttypes.h
/usr//local/avr/include/inttypes.h
/usr//local/CrossPack-AVR-20131216/avr/include/inttypes.h
Rod Cole is offline Find More Posts by Rod Cole
Old Nov 06, 2014, 10:23 AM
Joined Feb 2012
Excellent start. Thanks for the pointer.
Code:
OshMBP:~ osh$ sudo find / -name "inttypes.h"
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk/usr/include/c++/4.2.1/tr1/inttypes.h
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk/usr/include/inttypes.h
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator.sdk/usr/include/c++/4.2.1/tr1/inttypes.h
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator.sdk/usr/include/inttypes.h
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.10.sdk/usr/include/c++/4.2.1/tr1/inttypes.h
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.10.sdk/usr/include/inttypes.h
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk/usr/include/c++/4.2.1/tr1/inttypes.h
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk/usr/include/inttypes.h
find: /dev/fd/3: Not a directory
find: /dev/fd/4: Not a directory
OshMBP:~ osh$
I broadened the search and found the files in the various Xcode App bundles. Now to determine which is the correct/reliable/future proof way to select the correct path to include. I assume the best selection is to include the most recent Mac OS version, but I'm not sure what is considered the correct way.
Thanks again for the pointer!
John
WZ9V, AMA 409852
Joined Jan 2007
I'm wondering where the OSX version number is coming from, it looks to me as though that check is in error.
I'll try giving 2.0.8 a whirl tonight just to see if I have everything setup correctly before diving into 2.0.12, I did a lot of installs last night and who knows if I got them all 100% especially since I did phonon separate as the make file said to do as opposed to what the wiki said.
Originally Posted by Rod Cole View Post
I was able to get all of the prerequisites installed and have attempted to compile Companion.
1 error generated.
Oddly enough, when it failed on OS X (Mavericks) I decided to try compiling Companion 2.0.12 on Linux and it did so with no errors.
I think I will attempt to compile 2.0.8 when I have time as others have suggested.
Old Nov 06, 2014, 10:45 AM
Portugal, Lisboa, Cascais
Joined Sep 2012
I installed a fresh Yosemite and managed to get all the prerequisites working.
My compile error is the same as noted above and dynamich tips about the inttypes.h gets me this result
Code:
Linking CXX static library libgeneraledit.a
[ 39%] Built target generaledit
[ 40%] Generating ../../radio/src/lua_exports.inc
Luiss-MacBook-Pro:src luis$ find /usr/ -name "inttypes.h"
find: /usr//sbin/authserver: Permission denied
Code:
OshMBP:~ osh$
John
lvale is offline Find More Posts by lvale
Old Nov 06, 2014, 10:55 AM
Joined Feb 2012
I've read of many software version checks failing with Mac OS X 10.10, Yosemite, because they didn't check enough significant digits. For example, while 10.1 < 10.2, 10.10 should not be less than 10.9, but if they drop the trailing zero, it fails.
John
Old Nov 06, 2014, 11:00 AM
Joined Sep 2012
Added the dir where inttypes.h is to the $PATH
and same problem....
back to the drawing board
Code:
Luiss-MacBook-Pro:src luis$ make
[  1%] Generating moc_myslider.cxx
[  2%] Generating ui_simulatordialog-9x.h
[  2%] Generating ui_simulatordialog-taranis.h
[  2%] Generating moc_simulatordialog.cxx
[  3%] Generating moc_cursorwidget.cxx
[  3%] Generating moc_menuwidget.cxx
[  4%] Generating moc_xcursorwidget.cxx
[  4%] Generating moc_xmenuwidget.cxx
[  4%] Building CXX object simulation/CMakeFiles/simulation.dir/simulatordialog.cpp.o
[  4%] Building CXX object simulation/CMakeFiles/simulation.dir/moc_simulatordialog.cxx.o
[  5%] Building CXX object simulation/CMakeFiles/simulation.dir/moc_cursorwidget.cxx.o
[  5%] Building CXX object simulation/CMakeFiles/simulation.dir/moc_menuwidget.cxx.o
[  6%] Building CXX object simulation/CMakeFiles/simulation.dir/moc_xcursorwidget.cxx.o
[  6%] Building CXX object simulation/CMakeFiles/simulation.dir/moc_xmenuwidget.cxx.o
[  7%] Building CXX object simulation/CMakeFiles/simulation.dir/moc_myslider.cxx.o
Linking CXX static library libsimulation.a
[  8%] Generating moc_mixerdialog.cxx
[  9%] Generating ui_setup_timer.h
[  9%] Generating ui_setup_module.h
[  9%] Generating ui_flightmode.h
[ 10%] Generating ui_telemetry_analog.h
[ 10%] Generating ui_telemetry_customscreen.h
[ 11%] Generating ui_modeledit.h
[ 11%] Generating ui_setup.h
[ 12%] Generating ui_heli.h
[ 12%] Generating ui_curves.h
[ 12%] Generating ui_telemetry.h
[ 13%] Generating ui_expodialog.h
[ 13%] Generating ui_mixerdialog.h
[ 14%] Generating moc_flightmodes.cxx
[ 14%] Generating moc_inputs.cxx
[ 15%] Generating moc_mixes.cxx
[ 15%] Generating moc_channels.cxx
[ 15%] Generating moc_logicalswitches.cxx
[ 16%] Generating moc_customfunctions.cxx
[ 16%] Generating moc_mixerslist.cxx
[ 17%] Generating moc_node.cxx
[ 17%] Generating moc_modeledit.cxx
[ 18%] Generating moc_setup.cxx
[ 18%] Generating moc_heli.cxx
[ 18%] Generating moc_curves.cxx
[ 19%] Generating moc_telemetry.cxx
[ 19%] Generating moc_expodialog.cxx
Scanning dependencies of target modeledit
[ 19%] Building CXX object modeledit/CMakeFiles/modeledit.dir/flightmodes.cpp.o
[ 20%] Building CXX object modeledit/CMakeFiles/modeledit.dir/inputs.cpp.o
[ 20%] Building CXX object modeledit/CMakeFiles/modeledit.dir/mixes.cpp.o
[ 21%] Building CXX object modeledit/CMakeFiles/modeledit.dir/channels.cpp.o
[ 21%] Building CXX object modeledit/CMakeFiles/modeledit.dir/logicalswitches.cpp.o
[ 21%] Building CXX object modeledit/CMakeFiles/modeledit.dir/customfunctions.cpp.o
[ 22%] Building CXX object modeledit/CMakeFiles/modeledit.dir/mixerslist.cpp.o
[ 22%] Building CXX object modeledit/CMakeFiles/modeledit.dir/node.cpp.o
[ 23%] Building CXX object modeledit/CMakeFiles/modeledit.dir/edge.cpp.o
/Users/luis/opentx-next/companion/src/modeledit/edge.cpp:49:21: warning: unused
      variable 'Pi' [-Wunused-const-variable]
static const double Pi = 3.14159265358979323846264338327950288419717;
1 warning generated.
[ 23%] Building CXX object modeledit/CMakeFiles/modeledit.dir/modeledit.cpp.o
[ 24%] Building CXX object modeledit/CMakeFiles/modeledit.dir/setup.cpp.o
[ 24%] Building CXX object modeledit/CMakeFiles/modeledit.dir/heli.cpp.o
[ 24%] Building CXX object modeledit/CMakeFiles/modeledit.dir/curves.cpp.o
[ 25%] Building CXX object modeledit/CMakeFiles/modeledit.dir/telemetry.cpp.o
[ 25%] Building CXX object modeledit/CMakeFiles/modeledit.dir/expodialog.cpp.o
[ 26%] Building CXX object modeledit/CMakeFiles/modeledit.dir/mixerdialog.cpp.o
[ 26%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_flightmodes.cxx.o
[ 27%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_inputs.cxx.o
[ 27%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_mixes.cxx.o
[ 27%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_channels.cxx.o
[ 28%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_logicalswitches.cxx.o
[ 28%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_customfunctions.cxx.o
[ 29%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_mixerslist.cxx.o
[ 29%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_node.cxx.o
[ 30%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_modeledit.cxx.o
[ 30%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_setup.cxx.o
[ 30%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_heli.cxx.o
[ 31%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_curves.cxx.o
[ 31%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_telemetry.cxx.o
[ 32%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_expodialog.cxx.o
[ 32%] Building CXX object modeledit/CMakeFiles/modeledit.dir/moc_mixerdialog.cxx.o
Linking CXX static library libmodeledit.a
[ 32%] Built target modeledit
[ 33%] Generating moc_calibration.cxx
[ 34%] Generating ui_generaledit.h
[ 34%] Generating ui_generalsetup.h
[ 35%] Generating ui_trainer.h
[ 35%] Generating ui_calibration.h
[ 35%] Generating moc_generaledit.cxx
[ 36%] Generating moc_generalsetup.cxx
[ 36%] Generating moc_trainer.cxx
Scanning dependencies of target generaledit
[ 36%] Building CXX object generaledit/CMakeFiles/generaledit.dir/generaledit.cpp.o
[ 37%] Building CXX object generaledit/CMakeFiles/generaledit.dir/generalsetup.cpp.o
[ 37%] Building CXX object generaledit/CMakeFiles/generaledit.dir/trainer.cpp.o
[ 37%] Building CXX object generaledit/CMakeFiles/generaledit.dir/calibration.cpp.o
[ 38%] Building CXX object generaledit/CMakeFiles/generaledit.dir/moc_generaledit.cxx.o
[ 38%] Building CXX object generaledit/CMakeFiles/generaledit.dir/moc_generalsetup.cxx.o
[ 39%] Building CXX object generaledit/CMakeFiles/generaledit.dir/moc_trainer.cxx.o
[ 39%] Building CXX object generaledit/CMakeFiles/generaledit.dir/moc_calibration.cxx.o
Luiss-MacBook-Pro:src luis$ echo $PATH
/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/local/bin:/usr/include/c++/4.2.1/tr1
Sold Open LRS 1w RX/TX/USB programmer Busted_wing FPV Equipment (FS/W) 2 Oct 13, 2014 06:29 PM
Question Trouble with opening Mac naza firmware program stony30 Multirotor Talk 12 Aug 07, 2014 09:21 PM
Discussion Mac Hodges B-29 & X-1 routine @ GMA Open House, 9/28/2013 sjw985 Fuel Warbirds 1 Sep 29, 2013 09:41 PM
Discussion ... ClosedAccount Electric Flight Events 0 Jun 05, 2012 12:30 PM
Discussion Phoenix Demo and opening on Mac? Jemo11 Simulators 0 Aug 20, 2011 02:14 PM
