Old Oct 26, 2014, 07:41 AM
Keith
United States, FL, Fort Lauderdale
Joined Sep 2013
Question
300 cfx main gear
Has anyone changed the main gear in a 300 cfx? I damaged a few teeth in a crash and was able to repair it with a file but it is going to need replacement. It looks like it could be quite a project so I am hoping for a shortcut.
golforheli is offline Find More Posts by golforheli
Old Oct 26, 2014, 01:39 PM
Canada, BC, Vancouver
Joined Feb 2014
I've done it once.
From memory, first disconnect the cyclic servo links from the swash. Loosen the screws on the boom mount, push the boom in to provide slack to the tail rotor belt, and then slip the belt off the gear above the main gear. Remove the anti rotation guide. Remove the screw holding the belt gear to the main shaft. The head and shaft should now be able to be pulled off the gear and off the heli, and the gears can then be slid out. It took a bit of a tug for me to remove the head.
From memory, the belt gear is pressure fitted onto a sleeve on the main gear, so it is pulled apart.
I hope I haven't forgotten anything.
Ben M is offline Find More Posts by Ben M
Old Oct 27, 2014, 04:59 PM
Keith
Joined Sep 2013
Thanks for the feedback!
Sold Fs: 300 cfx: reduced Riff_Raff Aircraft - Electric - Helis (FS/W) 1 Nov 09, 2014 11:06 AM
Sold Blade 300 CFX "relist " h8ata38 Aircraft - Electric - Helis (FS/W) 0 Oct 16, 2014 08:52 PM
Sold Blade 300 CFX ( NO fbl unit )+extra parts+2 batts rchelicar Aircraft - Electric - Helis (FS/W) 8 Oct 14, 2014 09:54 PM
Sold Cox Extra 300 EP 2.4GHz RTF 20" NIB with Extra Prop and Main Gear sst2000 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Oct 03, 2013 02:27 PM
Sold Cox Extra 300 EP 2.4GHz RTF 20" NIB with Extra Prop and Main Gear sst2000 Aircraft - Electric - Airplanes (FS/W) 0 Oct 02, 2013 05:09 PM
