Old Dec 13, 2014, 06:12 AM
Joined Dec 2009
It also happens when a wire on the balance cable isnt contacting the opposite plug well. Just make sure all wire ends sit right in their plugs. Sometimes all you need is to push the wire into the plug.
Can'tFly is offline Find More Posts by Can'tFly
Old Dec 13, 2014, 06:48 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Originally Posted by Snowflake6515 View Post
I forget where I read it, but someone recommended the use of DeOxit; a contact cleaner. The theory was that the error messages are a result of oxidized connections. A drop in each balance connector pinhole, followed by a few insertions/removals by the appropriate counterpart balance connector, has often worked. It even worked on the power leads.
I found the stuff either at Radio Shack or one of the big box home stores.
A lot of the time, that is sufficient and the pack will accept a charge. I also use a Wayne Giles ESR meter to track my packs. Incidentally, I've measured seemingly faulty packs with the ESR meter before and after application of DeOxit. If the connection needs cleaning, the ESR meter will measure higher than usual, but, after cleaning, reads back to the usual range.
Occasionally, it is a faulty cell, but give the inexpensive DeOxit a try; cannot hurt.
Sure wish I could remember the source; would like to give credit where it is due.
Michael
http://www.amazon.com/s/?ie=UTF8&key...l_9b0esdpjsu_e
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Dec 13, 2014, 09:11 AM
Michael
United States, ME, Wells
Joined May 2008
Drip Bottle vs. Aerosol Can
I have both the drip bottle (http://www.amazon.com/CAIG-DeOxIT-Li...eywords=deoxit) and one of the aerosol cans (not near workshop, so cannot check).
I found that I prefer the drip bottle as it is very easy to insert the tip over a balance plug opening and get just the right amount.
One interesting bit, at least on the aerosol can that I have, is that it is not a continuous stream; rather, depressing the trigger causes a short burst to come out.
Still, I like the simple drip tube.
Michael
Originally Posted by ggcrandall1 View Post
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Dec 15, 2014, 01:11 PM
United States, CA, Santa Monica
Joined Jan 2012
Reading the cell voltages from the V2, at 100% charge, it looks like Cell 5 (out of 6) is at 4.15v while the remaining cells are uniformly at 4.19v. Bad pack? If so, is there any hope for it (discharge or balance?) or is it just toast?
[edit] And when I tried to do a discharge cycle, Cell 5 immediately dropped to <3.8v while the others remained charged. Looks fried. [/edit]
Alterscape is offline Find More Posts by Alterscape
Old Dec 15, 2014, 02:42 PM
Joined Dec 2009
coincidentally i managed to recover a pack whose 4th cell was reading 5-10 volts lower than the others.
i charged/store charged the pack many times at 1.5c and cell 4 now is perfect. the battery was brand new though and i have no idea why a specific cell was reading that low.
Old Dec 15, 2014, 04:24 PM
Seattle
Joined Sep 2007
Sadly this is common in some brands of packs. Only when new and typically on the larger packs. In this case a slow charge rate is the best method to get the cells balanced and broken in. If the pack is old, or damaged, cells out of balance could be a bad connection on the balance connector or a bad cell.
Gregor99 is online now Find More Posts by Gregor99
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 32 Sep 17, 2014 04:09 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 04:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 06:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 05:43 AM
