Old Oct 30, 2014, 05:58 PM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Yes, it can! Nanos have servo reversing and center offsets too.
JimDrew is offline Find More Posts by JimDrew
Old Nov 03, 2014, 10:01 AM
Fly inverted, it's more fun.
tholmes345's Avatar
Joined Apr 2006
RFU antennas
DO NOT separate the two antenna leads at the RFU itself and DO NOT remove the RFU from its case.
I am not quite clear on the above in red, taken from the RFU installation portion of the manual. Does it mean to not bend them right at the circuit board or to just flex them to the desired position? A picture of a typical installation would be helpful. I do understand that the white part needs to remain straight but would point 90 deg of each other for best reception.
tholmes345 is offline Find More Posts by tholmes345
Old Nov 03, 2014, 11:48 AM
Lake Havasu, AZ
Joined Jun 2005
This means do not move antenna LEADS (not the antennas). We had some people removing the case and turning one antenna lead 90 degrees to the other - don't do that!
You can certainly bend the antenna leads so the antennas themselves (which is just the white tip of each antenna lead) are perpendicular (90 degrees) to each other.
Old Nov 03, 2014, 12:13 PM
tholmes345's Avatar
Joined Apr 2006
Oh!. That explains it. Thanks
Old Nov 10, 2014, 11:17 AM
Lake Havasu, AZ
Joined Jun 2005
Just a reminder for those using the RFU or Nano with the X10+.... the weight of cable between the X10+ and Nano or RFU is extremely heavy under high g-force loading and prone to "ripping" out of the receiver connection. MAKE SURE that you zip tie the cable and/or connector so that it can't pull out of the receiver (or X10+).
Question X10+ Expander with Nano - customer comments please... JimDrew Xtreme Power Systems 48 Sep 22, 2013 10:54 PM
Discussion Channel expander question Engineer Bill Xtreme Power Systems 9 Jun 24, 2013 06:08 PM
Sold Parkzone X10 6 channel transmitter Tampatexan Aircraft - General - Radio Equipment (FS/W) 0 Jun 10, 2012 08:15 AM
Sold Berg 5 channel receiver w/ 4 channel expander Fizzy Aircraft - General - Radio Equipment (FS/W) 0 Oct 02, 2008 06:52 PM
