Old Feb 28, 2015, 05:17 PM
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Try putting it into a shallow dive (30 degrees) with the power off and let go of the sticks, does it pull up by itself? If not then the CG is too far aft. Then do it again with power does it pull up sooner or later? If it takes longer to pull out with power on then you have too much downthrust sooner not enough. Hope this helps
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Feb 28, 2015, 05:28 PM
Vanadu
Heavy Chevy's Avatar
Canada, YT, Whitehorse
Joined Dec 2008
Terry
Thanks! I'll try it out. Helps a bunch.
Heavy Chevy is offline Find More Posts by Heavy Chevy
Old Feb 28, 2015, 05:43 PM
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Too tail heavy
goldguy is online now Find More Posts by goldguy
Latest blog entry: Flyin' Fool
Old Feb 28, 2015, 05:45 PM
chuck
santa barbara, CA
Joined May 2009
Originally Posted by goldguy View Post
Too tail heavy
yep ..the aerobatics glory spec
chas650r is offline Find More Posts by chas650r
Old Feb 28, 2015, 05:54 PM
flyin' fool
goldguy's Avatar
Joined Jul 2003
All LAR flatties have pitch issues and tail heavy only makes matters worse. As stated above, tail heavy is for silly stuff and nose heavy is for speed.
Although, the NutBall is not a park jet, nor meant to be.
Old Feb 28, 2015, 06:34 PM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Some of our early bigger depron nutballs did suffer from flexing brought on by the constant stressing of the model while doing wild stuff.. stressing the foam made it soft..this resulted in tucking/diving down at speed...
The normal cog was setup at 25% with a bit of "up " trim, but this "up" was just flattening out with the speed, so the model began diving, and it became reluctant to pull out, because the elevator was being pushed back down..
When they were first built all was fine.. only after a few to several months did this tucking problem started up...
these were single layer builds in excess of 24" span..
When I went to stiffer KF builds I also used stiffer splines and the extra stiffness of the build stopped the problem...
So basically its keep it stiff...
you can stiffen up the model with spars or use my favourite, a pallet strapping sandwich.. going down the length , across the wing you will likely already have spars
If you have never seen the results of constantly stressed foam getting soft,
here is a Zagi flapping.. all due to the originals not having spars fitted, they were only taped for stiffness
ZagiFlutter (1 min 50 sec)
davereap is offline Find More Posts by davereap
Old Feb 28, 2015, 11:15 PM
Vanadu
Joined Dec 2008
^^THanks guys ^^
Lost of things to try out now!
Question What is THE best free plan foamy? 3Dude 3D Flying 27 Oct 13, 2009 11:48 PM
Best R/C Day yet! R/C~Mev Electric Sailplanes 3 Nov 22, 2004 11:35 PM
Best Simulator for Foamy 3D Flying ? knut 3D Flying 10 Nov 02, 2004 01:51 PM
Best AXI for Foamy Factory 44" Extra? Doug Cronkhite 3D Flying 10 Mar 16, 2004 12:11 PM
Q: Best covering for foamy scale warbird? dimple Foamies (Kits) 4 Feb 05, 2003 07:14 AM
