DLG Laser Cut Balsa Kit 1000mm
Looking for a Winter Project?
1000mm Wingspan DLG Kit
If you are looking for an easy project for the winter, check out this new DLG kit from HobbyKing. It's a simple mosquito class glider with rudder and elevator for control that can be used on the slope or an open field discus launch style. The small size is great for taking it with you for spontaneous flights. The kit is laser cut, so it will go together in a snap. The tail section is joined to the fuse with a carbon tube. The wing also benefits from carbon reinforcements. This is a pure kit so you'll need to provide your radio gear and building supplies. It could be just the thing to occupy your mind while the weather outside is frightful.
Learn more about the DLG Kit at HobbyKing
Old Dec 17, 2014, 11:45 AM
glidermang is offline
Find More Posts by glidermang
Elf-like. Should work fine.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Dec 18, 2014, 05:25 AM
scruffy1 is offline
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
all sold out already
outrage !
scruffy1 is offline Find More Posts by scruffy1
Old Dec 18, 2014, 07:05 AM
gem31 is offline
Find More Posts by gem31
Joined May 2014
Hi all, do you think this is a good product to learn DLG ?
For the price...
gem31 is offline Find More Posts by gem31
Old Dec 18, 2014, 11:18 PM
Rayven is offline
Find More Posts by Rayven
Lift is good
Rayven's Avatar
Olympic Penninsula, WA
Joined Dec 2001
Doesn't perform near as well as the Elf. I've flown both.
Rayven is offline Find More Posts by Rayven
Old Dec 19, 2014, 06:06 AM
ConEx is offline
Find More Posts by ConEx
ConEx's Avatar
Bern, Switzerland
Joined Jun 2010
Are you talking about this kit or the mini-dlg BNF version also sold by hobbyking?
ConEx is offline Find More Posts by ConEx
Old Dec 19, 2014, 09:24 AM
Rayven is offline
Lift is good
Rayven's Avatar
Joined Dec 2001
Actual I've flown both versions of the hobbyking models...and the same holds true about the Elf as the best performer. I'm really not knocking the hobbyking offerings though, as they do offer a low cost way to get into DLG. But at some point you will want a more robust model for more powerful (and thus higher) launches....which the Elf allows for. It also has a more efficient airfoil I believe as it does seem to outfloat the HK's. But again, if $ is an issue, go for HK and get into DLG. Warning...it is extremely addictive and you WILL spend more money on it! But its cheaper than helicopters! And its good for your body as it will keep you limber and active.
Old Dec 19, 2014, 09:46 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
This should be posted on top of the stickies
But dont throw away your heli's, there will be days it is too windy to DLG and you just want to chop through the rough air
sp00fman is offline Find More Posts by sp00fman
Old Dec 19, 2014, 11:03 AM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
buyer of the farm
United States, FL, DeLand
Joined Mar 2009
That's one I'd snag if it were available. I'll just have to stalk it for awhile.
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Dec 22, 2014, 07:32 PM
lesb is offline
Find More Posts by lesb
Northern California
Joined Apr 2002
They are back in stock. I received a notice that they were packing mine for shipment!!!
lesb is offline Find More Posts by lesb
Old Dec 23, 2014, 01:57 AM
scruffy1 is offline
scruffy1's Avatar
Joined Feb 2008
on reflection, i would be really chuffed to be able to just buy the tail boom as an item and design my own version of the rest of it
but a nice kit for those that want to build easily
Old Dec 23, 2014, 03:14 AM
Rusty Nail is offline
Find More Posts by Rusty Nail
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
I spotted this tonight (R2 have some real cheap sailplanes at the mo including the famous Speedo, out of stock of course).
No idea if it is wrapped but incredibly light for a thicker tube at 600mm? Might need to check out the Spectre threads ($52!) to see how strong they are. Also check out fishing stores for broken carbon rods as a cheap (free) source fo suitable booms for smaller gliders. Traditionally people use kite spars ar la Mimi.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Dec 23, 2014, 12:58 PM
E.Scheffler is offline
Find More Posts by E.Scheffler
Thermal searchin
E.Scheffler's Avatar
United States, CA, Rio Linda
Joined Aug 2011
what size of tube
What size of tubing is adequate for 1 - 2 meter sail planes? I need length and OD
E.Scheffler is offline Find More Posts by E.Scheffler
Old Dec 23, 2014, 04:09 PM
Rusty
Rusty Nail's Avatar
Joined Feb 2006
There is a big difference between booms for 1 metre and 2 metre spans. DLG needs are greater than other sailplanes. Tubes need to be wrapped carbon preferably tapered.
One metre DLGs usually use a commercially available kite spar. One metre Mimi recommends 510mm of a 3PT.
The 50 inch Gambler has OEM Goodwins boom that may be available soon as the Geforce UL.
Mountain models has a boom available.
Old Jan 06, 2015, 05:54 AM
homemade_project is offline
Find More Posts by homemade_project
Joined Jan 2015
nice stuff
homemade_project is offline Find More Posts by homemade_project
For Sale Guillow's 1903 Wright Flyer Laser Cut Balsa Model Display Kit hoffboy Aircraft - Electric - Airplanes (FS/W) 0 Nov 09, 2014 10:20 PM
Article NQRC's Aussie Easy Box II Balsa Laser Cut KIT Review glydr Parkflyers 25 Apr 23, 2009 01:11 AM
Article Hobby Lobby Miss Stick Senior Balsa Laser Cut Kit Review wahrhaftig Electric Plane Talk 15 Apr 23, 2007 02:31 AM
For Sale NIB House Of Balsa Electric MICRO CUB Laser Cut KIT punkindrublik Aircraft - Electric - Airplanes (FS/W) 2 Feb 19, 2007 01:52 PM
Sold iStar kit Laser-cut Balsa Pattern Parkflyer 13-14 oz. JWarren Aircraft - Electric - Airplanes (FS/W) 6 May 07, 2006 10:14 PM
