Old Oct 07, 2014, 09:50 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
New Product
Lynxmotion UAV - Quadrino Nano - UAV / Drones Flight Controller
Hi All,
We are, at Lynxmotion, very proud and exited to introduce a new UAV / Drones flight controller born from a partnership between the well known FlyingEinstein and Lynxmotion team. We focused on many things on that project:
The Press Release:
RobotShop Continues its Expansion in the UAV Market by Acquiring FlyingEinstein’s Technology
- Have all the available and up to date hardware MultiWii support
- Mount all that hardware on the smallest possible size format
- Provide an easy to use Software Updating Tool
- Integrate protection to the bare PCB
After many long months of work around those constraints, we are ready to show what we did for you.
Description: Name: quadrino-nano-3d-views.jpg
Description: Name: quadrino-nano-black-photo-1.jpg
Description:
The Lynxmotion Quadrino Nano Flight Controller is available on RobotShop and Lynxmotion :
(Lynxmotion Website)
(RobotShop Website)
Pre-Order price of $99.99 (normal price of $149.99)
Launch The Drone ! Lynxmotion Quadrino Nano Official Preview (2 min 59 sec)
Launch The Drone ! Lynxmotion Quadrino Nano (Making Of) (1 min 42 sec)
Specifications:
  • ATmega 2560 (256Kb flash @ 16MHz) Processor
  • Compact, six layer PCB design
  • Mounting options: 3M double sided adhesive foam or screws
  • Vibration dampening mounted PCB
  • Arduino bootloader making DIY / hacking projects possible
  • Onboard micro-USB connection / programming port
  • Invensense MPU9150 sensor chip which includes:
  • 3 Axis Gyroscope
  • 3 Axis Accelerometer
  • 3 Axis Magnetometer
  • MS5611 Barometer with foam cover
  • Latest Venus838FLPx 50Hz GPS chipset with external antenna (SMA connector)
  • 50Hz GPS update rate
  • NEMA serial output for OSD (On-screen display)
  • Motor port with eight speed controller outputs
  • Radio port with eight radio channels inputs
  • use all four AUX inputs
  • Two free serial ports (use for SBUS and/or Bluetooth or 3DR radio links)
  • Three I2C ports, of which two are 3.3V and one is 5V
  • 0.96” OLED port on-board
  • Spektrum R/C receiver port
  • Servo port with five outputs
  • 2x10 I/0 connector expansion port
  • LIPO alarm port and LED indicator
What's Included:
  • 1x Lynxmotion Quadrino Nano PCB (assembled)
  • 1x Dark “smoked” transparent case with damping via rubber grommets for PCB
  • 1x GPS Antenna SMA with 15cm cable
  • 1x Radio connection wiring harness
  • 1x Motor controller wiring harness
  • 1x Micro USB data cable
  • 4x 4-40 x 0.75" screws (for mounting the case to a frame via holes)
  • 4x 4-40 Nylon Lock Nuts (for mounting the case to a frame via holes)
  • 1x 3M double side adhesive Foam (for direct mounting to a frame)
Overview & Size:
BETA - Weights:
Quadrino Nano - Case + PCB + Screws + Dampers + GPS Antenna + Wiring Harnesses + 3M Mount - 64.22g
Quadrino Nano - Case - 11.62g
Quadrino Nano - Wiring Harnesses - 6.72g
Quadrino Nano - GPS Antenna - 29.12g
Quadrino Nano - 3M Mount - 0.82g
Quadrino Nano - PCB - 11.88g
Description: Name: Quadrino-Nano-Info-Bottom.jpg
Description: Name: NanoWithCoke-label-700.png
Description:
Quadrino FCT (Firmware Configuration Tool) Software:
Name: FCT - 01.jpg
Description: Name: FCT - 02.jpg
Description: Name: FCT - 03.jpg
Description: Name: FCT - 04.jpg
Description: Name: FCT - 05.jpg
Description:
Dialfonzo is offline Find More Posts by Dialfonzo
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Lynxmotion Quadrino Nano - Documents / Guides / Downloads
Here you can find the information needed about your Quadrino Nano and the tools to properly setup it for flight including the FCT (Firmware Configuration Tool) and WinGUI. This is a work in progress and we will add documents / guides / download links as they are created.
Until all the manuals are available, you can still contact us to get the information needed.
Lynxmotion Quadrino Nano - User Guides
Lynxmotion Quadrino Nano - Softwares
Lynxmotion Quadrino Nano - MultiWii Files
Pre-Configured MultiWii files to be used with Arduino IDE
Lynxmotion Quadrino Nano - 20 Pins I/O Connector
Name: Quadrino-Nano - IO Pins.jpg
Description:
Lynxmotion Quadrino Nano - I2C & UART Pin-Out
Name: QN-FC - UART & I2C Pinout.jpg
Description:
Lynxmotion Quadrino Nano - VBATT & BUZZER Wiring
Name: Lynxmotion UAV - QuadrinoNano - VBatt & Buzzer.jpg
Description:
Lynxmotion Quadrino Nano - LED's
Name: QN-FC - LED.jpg
Description:
Quadrino Nano - Power / Green:
  • Inform the user that the board is properly powered
Alarm / Red / D32
  • his is configurable in the FCT and will flash as well as trigger a pin on the IO port when active.
Status / Orange / D13
  • LED status signification
AUX1 / Green / D30
  • Presently linked with the Status LED in MultiWii code.
Stable / Blue / D31
  • Stable information provided by MultiWii. Should be ON when the copter is Armed and in Stable (Angle / Horizon) mode.
Serial1 RX / Green
Serial1 TX / Red
GPS Status / Blue
  • This is connected to the GPS chip status output. It is not triggered by the ATmega2560 and we do not have any control on it.
    Steady when no or under 5 satellites are lock and blinking over 5.
Lynxmotion Quadrino Nano - Wiring Harness
Name: QN-IO-WH - Lynxmotion Quadrino Nano - IO Harness V1.1.JPG
Description: Name: QN-SP-WH - Lynxmotion Quadrino Nano - Servo Power Harness.JPG
Description: Name: QN-SV-WH - Lynxmotion Quadrino Nano - Servo Harness.JPG
Description: Name: QN-UART-WH - Lynxmotion Quadrino Nano - UART Harness.JPG
Description:
Old Oct 07, 2014, 09:51 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Lynxmotion Quadrino Nano - Informations
Alexandre Dubus - Alexinparis - Founder/Creator of the MultiWii Project
TriWiiCopter reloaded (4 min 13 sec)
Lynxmotion Quadrino Nano - User Media
Some media created by Users of the Lynxmotion Quadrino Nano
Lynxmotion Quadrino - FCT BETA (06 05 2015) (0 min 53 sec)
Déballage de la Quadrino nano de chez Lynxmotion (2 min 50 sec)
Quadrino (14 min 35 sec)
Lynxmotion Quadrino Nano - Flashing / Testing
We need the Lynxmotion Quadrino Nano to be in perfect working order before shipping them to any customers. This brings us the need to accurately test each unit prior to even packaging them in the injection molded casings.
To solve this, we worked on making an application that would test everything needed in one action. It uses a custom programmer tool made of an Arduino Nano board with the right connector and pin-out for the Quadrino Nano and the boards USB.
Keep in mind that this software is not needed for customers, only for Manufacturing / Testing of the units. We wanted to show it as a teaser of the progress we are making.
Here are the different steps tested with this software:
  • Burn & Verify the Arduino Mega Bootloader to the ATmega2560
  • Program a custom Test Firmware / Sketch to be able to run all the other tests
  • Test the Bootloader / Test Firmware / USB Serial
  • USB Data test for large amounts of data
  • I2C Lines verification
  • Gyroscope test for normal behaviour
  • Accellerometer test for normal behaviour
  • Magentometer test for normal behaviour
  • Barometer test for normal behaviour
  • GPS presence and power-up
  • Program the Venus GPS chip for default settings
  • Program the MultiWii sketch
Everything is done automatically. The Arduino ISP programmer is first detected and then the Quadrino USB initiates the process.
Lynxmotion Quadrino Nano - DUT Software (1 min 36 sec)
Old Oct 07, 2014, 09:53 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Lynxmotion Quadrino Nano - Setup
Lynxmotion Quadrino Nano - MultiWii Connections
Here are the MultiWii connection for different Copter Types. They are color coded to match the Quadrino Nano motor wiring harness. The propellers in Orange are the one on the Top of the Drone and the Yellow ones on the bottom. (when the Copter Type need it)
Description: Name: Y4.jpg
Description: Name: Y6.jpg
Description:
Description: Name: QUAD+.jpg
Description: Name: X8.jpg
Description:
Description: Name: HEX+.jpg
Description:
Description: Name: OCTO+.jpg
Description:
Description: Name: BI.jpg
Description:
Spektrum Satellite - Setup
  • The pins location on the "Quadrino Nano" side of the wiring cable need to be changed.
  • Use a pair of tweezers or the tip of an X-Acto to gently lift the tab retaining the pin in the connector and pull on the wire to release it. Be careful not to break the tab while doing this.
  • Pinout for the Spektrum Cable when looking from the "tab" side of the connector and left to right:
    Spektrum Standard on both side of the cable : Signal | GND | Positive
    Quadrino side of the cable after modification: Positive | Signal | GND
Name: Quadrino-Nano - Spektrum Voltage.jpg
Description:
Lynxmotion Quadrino Nano Spektrum port PinOut
Name: Quadrino-Nano - Spektrum Wiring - Cable View.jpg
Description: Name: Quadrino-Nano - Spektrum Wiring - Bottom View.jpg
Description:
The two cable / Before and After the modification & Quadrino Nano and LemonRX Satellite with cable modified
  • In the FCT you need to select the right configuration for the Spektrum Satellite to work.
  • Our DSMX Compatible receiver (LemonRX) needed the option "ElevenBitsOr2048" to be set to work.
Name: Quadrino-Nano - Spektrum Wiring - FCT Setup.jpg
Description:
FCT (Firmware Configuration Tool) setup for DSMX Satellite
However, right now there is no way to "Bind" the satellite to your transmitter so that need to be done before using it with the Quadrino Nano with the normal way. (Connected to your Spektrum Receiver)
QN FC DSMX Satellite (0 min 23 sec)
Old Oct 07, 2014, 03:14 PM
The Quasar is offline
Find More Posts by The Quasar
Firmware Fiend
The Quasar's Avatar
United States, CA, San Diego
Joined Nov 2013
Wow, really cool board. Digging all the integrated components, and the price isn't bad, either.
The Quasar is offline Find More Posts by The Quasar
Old Oct 07, 2014, 03:20 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Many thanks, we have been hiding this for a while now and it was hard not to talk about it...
Old Oct 07, 2014, 03:24 PM
tntburnett is offline
Find More Posts by tntburnett
tntburnett's Avatar
United States, NC, Charlotte
Joined Apr 2013
Dude that looks great and promising great job. Now I got to get one for my mini 250. Oh I have the old gps antenna from the other Quadrino board will that work.
Be blessed
Isaac
tntburnett is offline Find More Posts by tntburnett
Old Oct 07, 2014, 04:28 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Dialfonzo- is up to it again, with great products. congratz!!!!!
tc3wins is offline Find More Posts by tc3wins
Old Oct 07, 2014, 04:41 PM
Powerdrum is offline
Find More Posts by Powerdrum
Joined Aug 2004
Is this capable of doing missions (Waypoints)?
Thx!!
Powerdrum is offline Find More Posts by Powerdrum
Old Oct 07, 2014, 05:48 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Wow, another great board.
Man you guys knocked this one out the park with all the options!
Powerdrum:
That means yes, way-points will be possible.
Man have I been waiting on this one!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Oct 07, 2014, 06:21 PM
GRIMX is offline
Find More Posts by GRIMX
GRIMX's Avatar
United States, CA, Sacramento
Joined Nov 2011
Drooooollll
GRIMX is offline Find More Posts by GRIMX
Old Oct 07, 2014, 07:37 PM
Ronan87 is offline
Find More Posts by Ronan87
United States, MD, Annapolis
Joined Nov 2012
Cool! I own a bunch of Lynxmotion stuff, it's fun.
Ronan87 is offline Find More Posts by Ronan87
Old Oct 07, 2014, 07:46 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Thanks guys, it was hard keeping that to ourselves.
Old Oct 07, 2014, 07:58 PM
Milwaukie , Oregon
Joined Feb 2003
Man , didn't even tel me nothing.
But , I would have told!
Old Oct 07, 2014, 08:03 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
This will be a lot of fun.
We can't wait to shop the actual board, i know it's frustrating not to have actual real images. There is one of the pcb itself in the pack.
Sold Quadrino flight controller with GPS awkBOTS Aircraft - Electric - Multirotor (FS/W) 1 Mar 21, 2014 09:59 AM
Sold Quadrino Zoom V3 Flight Controller with GPS SoQuaded Aircraft - Electric - Multirotor (FS/W) 3 Mar 13, 2014 08:19 AM
Sold Quadrino Basic Flight Controller $25 ramovan Aircraft - Electric - Multirotor (FS/W) 0 Jan 26, 2014 06:50 PM
Sold Quadrino Zoom Flight Controller (used) N0Glow Aircraft - Electric - Multirotor (FS/W) 6 Nov 04, 2013 02:38 AM
Discussion AR Drone w/ Quadrino (advance) control stilv Multirotor Talk 10 Oct 26, 2011 08:23 PM
