Old Dec 15, 2012, 02:21 PM
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
DiaLFonZo-Copter - SSQ
Hi All,
Here is in BETA version.. the SSQ quad.
It is made of 1/4" black G10 material that is milled in the center to leave about 2.5mm on the bottom.
350mm motor to motor and it has 45mm to 30.5mm slot for FC.
Slot on the bottom for battery strap.
S-uper
S-imple
Q-uad
The top plate will change to one with my logo one day...
HD Here
HD Here
HD Here
Dialfonzo is offline Find More Posts by Dialfonzo
Latest blog entry: DiaLFonZo-Copter - Announcement
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
-- Setup Reserved --
Old Dec 15, 2012, 02:27 PM
United States, NV, North Las Vegas
Joined Sep 2009
Looks Great Eric!
Few questions, what's the weight(bare frame) How stiff are the arms once milled? any twist or flex? How much$$
John
shultz is offline Find More Posts by shultz
Old Dec 15, 2012, 02:35 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by shultz View Post
Looks Great Eric!
John
Sorry John, i don't have it on hand to weight it ..
I sent him for a test.
The arms do have a bit of twist but at the moment i don't know if it's too much.
And for the price.. i have to review a bit what it cost me.. lol
I cut one Arm in Aluminum but i need some better setup on the CNC to do it good.
Old Dec 15, 2012, 03:07 PM
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
I will start building it tonight!
Should take about an hour or two.
But I will weight it all and get back to you.
DoctorAudio is online now Find More Posts by DoctorAudio
Old Dec 15, 2012, 03:15 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
That's what the Aluminum arm look like
Old Dec 15, 2012, 03:25 PM
Joined Dec 2009
Sweet!
It is interesting what threads pop up while I am napping .
@ DA what are you throwing on it?
@shultz If there is any twist, that should not be not hard to fix. There it twist in the Xaircraft / DJI style arms and people still use them. Eric could mill a little less out. Witespy's Flip has nothing milled out. If Eric makes it, it will be good and Tough!
NaterPin is online now Find More Posts by NaterPin
Old Dec 15, 2012, 03:38 PM
Joined Sep 2009
yeah the flex, twist and vibration can be overcome, I fly a DJI F330, LPF and creative FC mounting has it flying very well
Still, it would be nice if the arms are rigid enough to reduce vibration, flex and twist.
I've been looking at the new Flip, It looks tough as nails and is not to heavy. Still, If Eric's design is lighter and nearly as tuff he'll have a winner once again!
Looking forward to seeing some more specs and Video.
John
Milwaukie , Oregon
Joined Feb 2003
Originally Posted by NaterPin View Post
Sweet!
2228/1450kv
DJI 18 amps esc
2200 3S
There is some twist but this is not the Witespy flip.
This is a Super Simple Quad!
Old Dec 15, 2012, 04:57 PM
James not bond
jy0933's Avatar
Joined May 2012
i wonder if it is really necessary to have the "wall" around... all i can think of is adding weights and decrease aerodynamics
jy0933 is offline Find More Posts by jy0933
Old Dec 15, 2012, 05:42 PM
Joined Sep 2009
Makes the arm stiffer, milling out the arm reduces weight more than enough to make up for the "wall . As for aerodynamics..... it's a quad! aerodynamics are basically tossed out the window from the start
John
Old Dec 15, 2012, 06:33 PM
Milwaukie , Oregon
Joined Feb 2003
John
Holy butt cheese!
Someone understands.
I am impressed!
Old Dec 15, 2012, 07:27 PM
James not bond
jy0933's Avatar
Joined May 2012
will be interesting to see if there is any deflection under load and stress concentration at the screw holes..... but just opinion.. could be wrong
(not messing up.. just my instinct tells me those spots are mostly likely break at high load/acro flight)
Old Dec 15, 2012, 08:08 PM
Joined Dec 2009
I wondered about the how the arm tapers in when it gets closer to the centre plate. Then I stopped caring and will wait for DA to put a 4s on it. It should be fine.
Old Dec 15, 2012, 08:27 PM
Milwaukie , Oregon
Joined Feb 2003
It weighs in @ 103 grams .
with screws in it and the top plate!
Discussion DiaLFonZo-Copter Crazy2Fly Quadcopter 340mm Dialfonzo Multirotor Talk 83 Jul 10, 2014 09:24 AM
Build Log Unrealistic's HEXorcism 600 - Luis & DiaLFonZo-Copter unrealistic Multirotor Talk 47 Oct 23, 2012 04:09 AM
For Sale DiaLFonZo-Copter TrinityHEX - ReList Dialfonzo Aircraft - Electric - Multirotor (FS/W) 3 Apr 27, 2012 02:44 PM
For Sale DiaLFonZo-Copter TrinityHEX - USED Dialfonzo Aircraft - Electric - Multirotor (FS/W) 7 Apr 20, 2012 11:34 AM
