Espritmodel.com Heli Air
Old Mar 23, 2013, 09:56 PM
HoosierGuy's Avatar
Joined Jan 2012
Basic Inverted Flying Questions
Hey all. I started flying R.C. electric gliders/air planes last year. This is my second year/season. I can fly pretty good right now, banking/turning, gliding, and landing, etc...
Last year I bought myself a Popwing flying wing. It was real twitchy at first but I finally got the dual rates lowered enough and added enough weight to the nose that it flies great.
Anyway, this year I got out my Popwing and started flying it hard, doing loops and rolls. One thing I've noticed is that I'm getting more and more confident with it. I can lose orientation for a second or two but regain orientation and control before it hits the ground. I'm almost at the point where I don't care one bit if i lose orientation because I know I can regain control.
Now I'm trying to fly inverted. That is my main question - are there any hints on learning how to fly inverted? What really helped to learn normal flying last year was this: When the plane is coming towards me I move the stick towards the wing I want to lift. Now I've got that burned into my brain/reflexes.
So now this summer I want to learn how to fly inverted and bank and turn while being inverted. Any hints on how to learn this quickly and efficiently?
HoosierGuy is offline Find More Posts by HoosierGuy
Old Mar 23, 2013, 10:03 PM
kerwin50's Avatar
winston mo
Joined Oct 2006
just practice at 3 mistakes high. and once again play with your sticks. Most planes drop on there nose so holding a little pressure on the stick helps keep it level
kerwin50 is offline Find More Posts by kerwin50
Old Mar 23, 2013, 10:28 PM
Thank ya! Thank ya very much!
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
I haven't been flying much longer than you and I fly inverted pretty good! what helped me is just remembering that you elevator stick (and rudder) are reversed while inverted. I don't use my rudder that much on normal flying, but when you get inverted, remember, right stick up will make plane climb/and maintain altitude and right stick down will make plane go down... the ailerons will act the same as flying normal. once I got that burned into my brain I got it! I have an assassin combat wing too! fast & fun flying!! good luck and happy flying!!
tupeloflyer is offline Find More Posts by tupeloflyer
Old Mar 23, 2013, 10:31 PM
Hardcore EP 3D Flyer
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
just get a simulator, you can do a lot of good practice without risking anything.
VR Eyedoc is offline Find More Posts by VR Eyedoc
Old Mar 23, 2013, 10:45 PM
HoosierGuy's Avatar
Joined Jan 2012
Nice advice, just what I'm looking for. Thanks!
Old Mar 23, 2013, 11:00 PM
Joined Oct 2012
Everyone told me to get a Sim but I never listened! never have tried one? getting in the air is how I learned! Yeah I've picked up some balsa carnage with a garbage bag a few times and a dang good RC repair man! finally found EPP been flying a little over 2 yrs now and feel pretty confident flying most anything now. learning a little 3D now...
Old Mar 23, 2013, 11:28 PM
HoosierGuy's Avatar
Joined Jan 2012
I don't want to use a sim either.
My flying wing is made out of EPP. I also put Goop on the leading edge to make it more flexible in case it hits the ground nose down. I can fly inverted for a few seconds and I have pushed the stick down so that it would go up. But now I need to learn to turn left and right while inverted.
Old Mar 24, 2013, 06:05 AM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
As tupeloflyer mentioned, the ailerons don't reverse when you're inverted. The popwing has no rudder, so the only thing you have to remember is that the elevator is reversed.
Azarr
Azarr is offline Find More Posts by Azarr
Old Mar 24, 2013, 08:32 AM
Slopeaholic
jimbo320's Avatar
Joined May 2011
PPP, practice, practice and more practice, that's all.
jimbo320 is offline Find More Posts by jimbo320
Old Mar 24, 2013, 09:44 AM
Joined Sep 2010
I'd add another vote for getting a sim. In my learning curve, I spent weeks of almost nightly practice flying nothing but inverted on the sim. This helped immensely - mind finally got it straight. I've seen lots of advice about how to move the sticks based on which wing was lower, and other assorted visual aids while flying, but I've found for me, that if I have to think about what way to move the sticks for what condition, it's probably too late. Much better to have it just be natural and never have to think which way to move the sticks for what orientation the plane is in. A decent sim is one of the best ways to do this. I'm not saying you should feel confident that if you learn to fly on a sim, you can automatically fly an actual plane, but you can sure train your brain to thumb memory for orientation with the sim once you learn to fly the real thing. Flying sim vs real might not be the same, but orientation vs stick movements is.
bobly is offline Find More Posts by bobly
Old Mar 24, 2013, 10:04 AM
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
My experience is identical to bobly's.
I spent at least 20 hrs on the Phoenix sim just flying inverted before ever attempting it on a real plane. The vid below is a compliation of the very first few flights after the sim time. Inverted flight was totally effortless.
The first minute of the video is trimming the newly built foamy.
Axis V3 F3P practice plane. (3 min 7 sec)
KC is offline Find More Posts by KC
Old Mar 24, 2013, 10:14 PM
HoosierGuy's Avatar
Joined Jan 2012
I just realized this late winter/early spring when I started flying again a few weeks ago - flying right side up has become second nature to me. It's now automatic in my hands and fingers. Does flying inverted become second nature when you do it a lot too?
Old Mar 25, 2013, 04:04 AM
Azarr's Avatar
Joined Jan 2000
Yes, and that's when it becomes fun.
Azarr
Old Mar 25, 2013, 06:08 AM
Joined Sep 2010
Yes, that's why my hours on the sim worked for me. I'm a slow learner, and hate to try to guess how many thousands of dollars the sim saved me. Even if nothing else is realistic on a sim, the stick movements required in relationship to plane orientation are identical. Up is up when upright, up is down when inverted, and also applies to rudder, and ailerons as far as flying away from you or toward you.
Old Mar 26, 2013, 01:03 AM
Former Futaba employee
Joined Aug 2006
The slower you can fly inverted will help, on a plane with a rudder when inverted and your using the rudder to turn and it is going way from me I think push the tail, when coming toward me push the nose.
keyman923 is offline Find More Posts by keyman923
Discussion F5B basic flying questions Tailslide UK High Performance 18 Oct 13, 2010 04:13 AM
Question Basic Flying Question spagoziak Foamies (Kits) 12 Jun 08, 2010 11:02 AM
inverted flying question ronmeister Micro Helis 5 Apr 03, 2005 02:21 PM
Question Moth...a few basic flying questions?? duganderson Slope 1 Jun 12, 2004 12:08 AM
