Old Apr 21, 2015, 06:31 PM
cakeman68 is offline
Find More Posts by cakeman68
Joined Apr 2015
Voltage Regulator for a LiPo
Hello everyone I have an odd question. I own a Blade 350QX quadcopter and I was wondering would it be possible to build a voltage regulator so that I can connect (2) 11.1 3000mAH batteries together in order to extend my flight time from abut 15 minutes to 30+ minutes. If this is possible, what do I need to do?
cakeman68 is offline Find More Posts by cakeman68
Old Apr 21, 2015, 06:56 PM
CreepyCrawl is offline
Find More Posts by CreepyCrawl
Obsessed with the details.
CreepyCrawl's Avatar
United States, NH
Joined Apr 2013
What you're looking for is a Parallel harness that will allow you to run your two packs together.
Take care to make or purchase the right set up: Parallel doubles your mAh while Series doubles your voltage, so keep that in mind. Connecting two packs in series to an ESC that isn't rated to handle the voltage, will lead to a BBQ.
CreepyCrawl is offline Find More Posts by CreepyCrawl
Old Apr 21, 2015, 07:49 PM
James_S is offline
Find More Posts by James_S
United States, WA, Woodinville
Joined May 2014
Also keep in mind that double batteries doubles the weight of the battery which requires more power to lift. In practice I suspect you'll get something like 20% longer flight time rather than the 100% you are expecting.
James_S is offline Find More Posts by James_S
Old Apr 22, 2015, 02:30 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Welcome to the forum
A parallel harness, mentioned above, is simply a wiring harness that connects both the battery red wires together and both the battery black wires, like this one. That'll add the capacities of the two batteries together but keep the voltage the same, so no extra voltage regulator is needed. As also mentioned, it won't give you double the flight time due to the extra weight, and performance may change too, for the same reason.
abenn is online now Find More Posts by abenn
Old Apr 22, 2015, 08:02 AM
Jaketheone46 is online now
Find More Posts by Jaketheone46
Jaketheone46
United States, KY, Florence
Joined Nov 2014
Yea if your wanting double flight time your best bet is using one pack at a time. For one it's the only way to get double flight time. And as for a voltage regulator this is definitly not needed. As there are 2 ways to combine a Lipo pack one way which is the way your wanting Which is called parallel this doubles your capacity and being it also adds weight it's not going to double the flight time and this weight will also be much harder on your motors.
Then there is combining packs in series which then doubles your voltage.
Jaketheone46 is online now Find More Posts by Jaketheone46
Old Apr 22, 2015, 10:22 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
May I suggest you read this:
http://www.tjinguytech.com/charging-how-tos
It will give you a lot of good information about batteries and chargers.
There has been a lot of good information posted above. This will give you better detail.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Discussion Im looking for a Voltage regulator for 50cc class ? OzparkPilot Giant Electric Planes 10 Apr 26, 2015 08:02 PM
Sold Gryphon Extreme Heli GVR-7020 Voltage Regulator w/ Pulse 2S LiPo egiraldo911 Aircraft - Electric - Helis (FS/W) 0 Apr 03, 2015 10:23 PM
Discussion Voltage regulation.... for X200 LiPo charger JohnW78 DIY Electronics 2 Nov 17, 2014 12:38 AM
LiPos and Voltage Regulator for Rx Pack FlyingW Batteries and Chargers 24 Feb 03, 2005 06:21 PM
Voltage regulator for LiPo rysium DIY Electronics 5 Jun 17, 2004 06:05 PM
