Closed Thread
Old May 22, 2014, 12:19 PM
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Scoring ALES
The AMA rule state:
(X).4 Scoring
1. Time will be recorded by the timekeeper/helper and will be truncated for scoring purposes,
Pretty simple, the timer looks at the watch, ignores tenths of a second and just writes down the whole minute and whole second, a landing score and that's that.
With a raw scores there are no tenths introduced to the scoring, but once normalization takes place tenths are introduced. So are the tenths rounded up or down, or truncated to the whole number? In other words are the tenths ignored and only the whole number used?
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old May 22, 2014, 12:50 PM
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Truncating only applies to the time so it is standardized. Calculated (normalized) scores can go to as many decimal places as desired/needed, I'm not aware of a standard for calculating. In fact, the ALES league calculated scores go to two decimal places, so perhaps that should be the target.
JT
jtlsf5 is online now Find More Posts by jtlsf5
Old May 22, 2014, 02:28 PM
Red Merle ALES
Joined Apr 2002
Here is an example of my spreadsheet.
I do not wish to use tenths but I rolled out the tenths just to show what is going on with rounding and truncating.
So should I use normal rounding rules or truncate like I am currently doing?
Curtis
Old May 22, 2014, 04:20 PM
The Great Filter
kcaldwel's Avatar
Joined Jan 2007
http://www.physics.uoguelph.ca/tutor...ig/SIG_dig.htm
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old May 22, 2014, 04:26 PM
jtlsf5's Avatar
Joined Jul 2007
The last three entries (leghorn, bunny, coyote) calculated wrong. I'm not sure what you're trying to show by adding the 10ths of a point.
JT
Red Merle ALES
Joined Apr 2002
Originally Posted by kcaldwel View Post
I am not well educated in math would you please explain?
If this has nothing to do with then AMA rules please start your own thread. I appreciate the help though, well once you explain how....
Old May 22, 2014, 04:29 PM
Red Merle ALES
Joined Apr 2002
JT
How so? One is .4 and rounded down, the other is .7 and also rounded down; truncated the other one is 1000.0. How can that be wrong?
Old May 22, 2014, 04:57 PM
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
177/239*1000 = 740.6
235/239*1000=983.3
238/239*1000 = 995.8
You must be truncating the result of the division. Only the reported flight time should be truncated to whole seconds.
Wazmo is online now Find More Posts by Wazmo
Old May 22, 2014, 05:28 PM
Red Merle ALES
Joined Apr 2002
So what you are saying is no truncating in the scoresheet is required? The truncating is done from viewing the stopwatch to what the timer writes on the paper.
So te timer would ignore any tenths of a second and only write down the whole number.
Old May 22, 2014, 05:32 PM
The Great Filter
kcaldwel's Avatar
Joined Jan 2007
You can not have more more significant digits in the result than in the inputs - any more digits are meanuingless. The landing scores have two significant digits, well actually 1 1/2 since they are in 5's. The time has 3 significant digits.
Any calculation cannot have more digits with any meaning than the inputs. In this case there really should be only two significant digits in the results, since the landing scores have a maximum of two significant digits. That means there should not be numbers like 956, only 960. Tenths certainly are meaningless.
Kevin
Old May 22, 2014, 05:56 PM
Red Merle ALES
Joined Apr 2002
Kevin,
Thanks but I have to admit I have no clue at all what that means.
Curtis
Old May 22, 2014, 06:00 PM
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
So the timer would ignore any tenths of a second and only write down the whole number.
Correct. But, the numbers after the decimal place in the normalized score are really not significant (per Kevin's post above), since you only have three digits in the raw score (600 seconds + 50 point landing). I would just round those to whole numbers.
Old May 22, 2014, 06:05 PM
Red Merle ALES
Joined Apr 2002
Wazoo you have been a lot of help. From one Virginian to another Thanks!
What I am doing is taking the normalized score and truncating that. There are no tenths in a flight score until the normalization process. So that is what I was normalizing. I think I misunderstood truncating "time" vs "scores". So my spreadsheet is wrong. I will fix it tonight or in the morning,
Thanks to a long time SSJSS friend for finding that!
Curtis
Harrisonburg 1962-1981
Old May 22, 2014, 06:07 PM
Red Merle ALES
Joined Apr 2002
So you are saying after normalization to use "rounding" rules. <5 round down and >5 round up?
Curtis
Old May 22, 2014, 06:15 PM
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
Curtis
Yes, because rounding should tend to accumulate less error than truncating when summing multiple rounds.
For example:
1.1 + 1.3 + 1.5 + 1.7 + 1.9 = 7.5
1 + 1 + 1 + 1 + 1 = 5 (truncating)
1 + 1 + 2 + 2 + 2 = 8 (rounding)
Closed Thread
Discussion Tailwind Gliders ALES Scoring Spreadsheet Curtis Suter Electric Competition Soaring-F5J/ALES/e-Soaring 34 May 22, 2014 11:43 PM
Discussion Would you attend a combined F3K and ALES contest(scored separately) ? Fly2High Electric Competition Soaring-F5J/ALES/e-Soaring 14 May 05, 2014 09:06 PM
Discussion Would you attend a combined F3K - ALES contest(scored separately)? Fly2High Hand Launch 10 May 03, 2014 08:44 AM
Question ALES scoring question. jaizon Electric Competition Soaring-F5J/ALES/e-Soaring 7 Sep 03, 2012 09:21 AM
Discussion ALES scoring programs! alstrahm Electric Competition Soaring-F5J/ALES/e-Soaring 42 Jul 31, 2012 03:26 PM
