Old Jul 12, 2015, 07:45 AM
Kooshball is offline
Find More Posts by Kooshball
Joined Jan 2014
Motor, battery or esc problem?
I have had my crack yak for about a year and a half and my turbo beaver for 7 months and they both started acting funny in different ways with no shared components.
Yak on 2s flies fine sometimes then other times the motor basically gets confused and just bobbles around not really turning. Doesn't matter what the throttle setting is.
The beaver is on 3s and now only gets 15 second flights before the motor powers down to 20% or so. Voltage on the battery is still 100% so I am confused with both issues.
Does this sound like any particular common problems?
Kooshball is offline Find More Posts by Kooshball
Old Jul 12, 2015, 08:01 AM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Your batteries are shot. Even if voltage shows good. Try new battery. Once under load bad batteries go south. how old are they ? do you run them two low ?
dankar04 is online now Find More Posts by dankar04
Old Jul 12, 2015, 08:35 AM
spastic is offline
Find More Posts by spastic
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
the confused motor is most likely a broken intermittent winding in the motor or the leads coming out of the motor (connection to the esc).. the 15sec thing, is harder to tell, can you get a watt meter to check the volts and amps? I've had a damaged ESC do that, bad bearings, glue in the bearings...
spastic is offline Find More Posts by spastic
Old Jul 13, 2015, 02:40 PM
Joined Jan 2014
So I did some investigating and found that when I move the wires going into the motor the confused motor works fine...probably a loose wire.
I ordered some new 3s batteries for the other one so we will see. I don't let them hit low voltage cutoff so they haven't been abused but maybe they don't last more than 7 months anyway?
Discussion Help! ESC or Motor Problem!? MemphysX Electric Power Cars 11 May 25, 2015 05:29 AM
Discussion S800 evo problem.. Motor or esc or both? charles hidalgo Multirotor Electronics 1 Nov 30, 2014 04:01 PM
Question 250-size quad - ESC or Motor or Naze32 or operator problem? mihavalencic Mini Multirotors 8 Nov 29, 2014 02:27 PM
Discussion Micro quad build - motor or esc problem Waterbound Scratchbuilt Multirotors 6 Jan 04, 2014 04:06 PM
Help! Problem with battery, ESC, or connection? Pantsy Multirotor Talk 1 Dec 05, 2013 01:26 PM
