Some people CAN........
A G-62 would be a lot of power for a Mulligan.The 80 could turn a scale diameter prop and look awesome.
Work up the speed in increments, watching for rudder and elevator flutter.(they both would). One I saw lost the entire stab, rolled inverted, and made a nice inverted landing. I'd recommend some sheeting as reinforcement along the sides and bottom of the fuse. If you have ,or can get a DuBro belt prop reduction,and install modern belts, they are still an interesting machine. Please don't forget the planes were designed for about 50 to 60 miles per hour. They MAY stay together, but be aware..... |
Latest blog entry: The 'Ancient Modeler"
Ahhhh-that's better !
That sounds good to us....we don't want to see you disappointed...If the previous owner did some modifications, it make be perfectly safe to go fast and 'turn left'.
Cloth covering adds a lot of strength, and if he's strengthened the gear, he may have taken pains with other things also. It sure looks nice. |
United States, WA, Yelm
Joined Feb 2012
I put a 52cc turnigy on mine and still could take more power. This plane can make a very impressive low leval tight turn that the crowd loves. I found that you have to set the thrust 2% right and down to fly. Also mix 35% rudder in the ailerons . This plane once you get set up is a blast to scream around the field. I recently decided to fly inverted and it did that well. Hammer heads are very cool with a 9' wing swinging about.
| Thread Tools | |
| Sold Bud Nosen Mister Mulligan Kit | N925WB | Aircraft - Fuel - Airplanes (FS/W) | 11 | Apr 08, 2012 04:46 PM |
| Sold Mister Mulligan - Bud Nosen Models | wifeswarrior | Aircraft - Fuel - Airplanes (FS/W) | 2 | Feb 14, 2012 02:18 PM |
| For Sale Bud Nosen Mister Mulligan ARC | IowaSilvia | Aircraft - Fuel - Airplanes (FS/W) | 0 | Sep 28, 2007 01:47 PM |
| For Sale Ikon Nwst Mister Mulligan Kit | IowaSilvia | Aircraft - Fuel - Airplanes (FS/W) | 1 | Apr 23, 2007 01:53 AM |
| Wanted WTB: Bud Nosen Mister Mulligan Plans | Biper/Piper | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jun 14, 2005 01:09 PM |
