Well, she looks ready:
And that's a LOT of wires to route: This is no bird to disassemble too often.... With all wiring and EDF inside I still need extra nylon bolts to keep the fuselage halves together at the rear. Ended up drilling holes through the EDF housing to route the motor wires, it was the only way to do this elegantly. Next is a full up flight controls setup and test. Quite happy with the gear, seems to work well. |
Managed to make some time for RC....
Found a way to hold fuselage halves better together at the bottom: Made four squares in hard balsa and drilled two 4 mm holes in them. Made a cutout in fuselage same size as the balsa parts. Glued counter-nuts to the balsa parts. Then glued balsa part with the counter-nuts down into fuselage: Cut glued balsa part in two at the separation plane of fuselage halves, Then used an identical balsa part, drove screws through them that go into the counter-nuts below. Et voila, fuselage secured: Next step is to do something similar on the upper side of the fuselage, near the tail, where the EDF pushed both halves open still. Meanwhile I'm working on my own lights controller with an Arduino, which will allow me to switch steady or strobe lights depending on the input of a given receiver channel: - upper and lower strobe lights triggered by throttle channel (engines on = strobes on) - landing lights triggered by gear down I might use the same controller to disable the nose wheel steering when gear is up, and even use it to reverse a flaps servo. Just because I can :-) |
Added one more nylon bolt at the front of the tail, using washers to prevent the bolt head and the nut from being pulled into the foam:
Next I started to arrange the wiring, preparing to finally close the fuselage. One might say it will be a tight fit: A bit of work is still needed to cut some foam to make room for the receiver and the LiPo, then I can close the fuselage and attach the wing. I stll have some concern about excessive play on the flaps. At the servo side, I used a z-bend, and when the flaps are up, this gives too much of transversal play. To be continued. |
Joined Jan 2006
Hi !
I just bought an Graupner Epic Victory and the precut plywood plate, dedicated for the gear mounting is missing in my box. Could someone help me out by sending to me a precise scan of this plate ? It would help me A LOT !!!! Hoping your help .... THIERRY |
Joined Feb 2010
Just bought two Victory S kits. MIght add retracts which I have on hand, but maybe just fly off of grass and hand launch. I have ordered the HK combo 70MM fan with 3300KV motor. This is my first EDF, so looking forward to learning about that aspect of our hobby.
Probably keep it simple and light. Phaedra, any late news on how yours is coming along? Thanks for all the info you have posted. SpadCat |
Just waiting for some better weather (we're having snow and heavy wind today). It's spring!!
Bought the Dynex balancer, I will balance my EDF before I fly it. Still having a problem of tightly fitting fuse halves together, Ithink I'll add another nylon bolt just before the vertical fin, underneath the dummy air intake. Then I'll do my final cg balance. |
Joined Feb 2010
HI Phaedra,
Do you mind me posting this here, or would you prefer my own thread? I am not doing a build log, as you are already doing a superb job with yours. Completed the fuse tonight. I moved the DF to the rear a little over an inch in hopes of not needing the extra tail weights since I was not installing retracts, but I still needed them. I found the instruction manual pretty clear except the photos could be a little clearer. It cracked me up when it said to use a drop of CA and then in a warning box below it emphasized "Really use just a drop to secure the impeller against slippage......." ![]() Also, it says nothing about the hinging process, so at this point I am assuming that the elevator, etc just need the sides cut and the slotted foam acts as the hinge. One error I found says to glue the battery compartment cover assembly clips to the provided fuselage cutouts with the opening pointing to the rear of fuse, but they need to be pointing up so that the compartment cover bolts can be pushed in from above and clicked into place. Hopefully I will maiden the Victory next weekend. SpadCat |
Why would I mind? :-)
I have been extremely busy for my job, so no time for building or flying. As soon as I have balanced the edf, I want to add a bolt right through the 'lip' on top of the edf, instead of underneath the fake air inlet as I mentioned earlier. That way I also keep it better in place without the 'drop of CA glue'. Please keep us informed about the maiden! Phaedra |
Joined Feb 2010
Ready to Fly!
Got the window decals on and just need to stick on rest of decals, but she is ready. It balanced right on the recommended CG and AUW came in at 15grams less then book (without retracts).
My overall take on the build is that it was real easy. Everything fits just perfectly. The hardest part was routing out foam so that I could push the 70mm fan back a bit. I am glad I did because it gave me a little more flexibility with the Lipo. I said earlier I bought two Epic Victory S kits. The 2nd one was for my brother, and his is almost finished also. He is rigging his up with lights for night flying. Not sure if I will take her out tomorrow or Sunday, but will let you all know how it goes. SpadCat |
| Thread Tools | |
| Video Captain Jack's epic F4F Wildcat flight | mgrande11 | Electric Plane Talk | 0 | May 24, 2011 07:01 PM |
| Video Epic Victory from Graupner | Jurgen Heilig | Fuel Plane Talk | 4 | Oct 07, 2008 02:09 PM |
| Discussion Epic wind today at the Butte (Pic's) | wackyd | Slope | 13 | Mar 15, 2006 01:41 AM |
| Anyone tried the Epic 3300's from battlepack.com??? | Joe Ford | Batteries and Chargers | 5 | Aug 16, 2004 02:53 PM |
