Old Oct 22, 2014, 11:30 AM
Joined Sep 2013
Originally Posted by mikefromgermany View Post
The Alien FC
http://micro-motor-warehouse.com/col...ducts/alien-fc
Quite expensive. And needs DSM, too.
Afro mini
http://abusemark.com/store/index.php...products_id=45
Cheap, capable of driving brushed motors but you have to install the FETS yourself.
PPM connect only, so your FrSky RX choice is quite limited.
If you seriously want to hop into the brushed micro quad world there will be no excuse for a DSM module for your TX imho.
-mike-
The naze32 mini souds good! Will buy one when they are in stock and the fets I need to solder them on the FC? Frsky have one micro receiver that is PPM and is only 5grams.
Then I might need to upgrade the motors...
mfc123 is offline Find More Posts by mfc123
Old Oct 22, 2014, 11:31 AM
Joined Sep 2013
Originally Posted by limmacslim View Post
mfc123, as far as I know there's not really many other options , maybe someone else will know better.
I also toyed with the idea of using a Frsky VD5M rx with Muliwii on an arduino pro mini, GY521 gyro board & homemade brushed ecs's but came to the conclusion it would turn out too heavy for a tiny quad like the q-bot. The setup is put to use much better with some brushless gear on a slightly bigger quad.
Just for reference, the Pro mini board & GY521 can be had for very cheap at banggood & makes a really nice lightweight (5g) Multiwii flight controller but you do need an external FTDI adapter & possibly a USBASP programmer. I cobbled together a cheap wooden frame quad that far exceeds what the q-bot can do using those bits, some H-King 10a esc's (with Blheli FW) & 1822 motors that were on sale.
Another option is, if you can get your hands on a cheap spektrum tx you can rip out the radio module & install it in a 9X (with upgraded firmware). I used one of these low power tx's & installed the guts inside a module but never really use it, nice to have around though.
Old Oct 22, 2014, 05:51 PM
Ain't crashing often anymore
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
I have no clue how to solder the Mosfets there. I suspect a DIY board has to be made then. I just got the info of the manufacturer that it is possible. You should askn him for advice.
Regarding a PPM capable FrSky RX - You are talking of the D4R-II?
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Oct 22, 2014, 08:25 PM
Joined Feb 2014
I would be interested in buying this quad! I would like to ask you questions
1. Can I bind a radio FlySky FS-T6 2.4GHz System: AFHDS ?.
2. If yes, how to bind a WLtoys(example) simply pressing the bind or Is it necessary to follow certain steps?
3. in terms of stability and reactivity is lost somthing to bind in this way without RF module?
Thanks!!!
Bi7hazard is offline Find More Posts by Bi7hazard
Old Oct 24, 2014, 02:54 AM
Australia, QLD, Townsville
Joined Feb 2013
Thanks!!!
The FlySky protocol does not work with the Turnigy Micro Q-Bot. It comes with the (HiSky) HT8 adapter which is best connected to a TX via a Futaba trainer port. The Futaba port supplies power from the TX to the adapter module. The alternate JR stereo plug trainer does not readily supply power (I had no luck with the Turnigy 9X)
Binding with the HiSky protocols is mostly by powering up the TX module then simply turn on the RX. The RX will find and bind to the strongest rf signal it finds.... the TX must be as close to the quad as possible if there is a chance of anyone else using a compatible RF within range.
The HT8 adapter works with the Turnigy / HiSky FBL100 (WL Toys V922) and the HiSky HCP 100. It does not work with the WL Toys V911.
By adding the back-stand accessory to the Turnigy 9XR, the HT8 adapter fits neatly between the stand legs. I have the FlySky module plugged in at the same time. No conflicts. See pic
IanPellant is online now Find More Posts by IanPellant
Old Oct 24, 2014, 03:13 AM
Germany, Berlin
Joined Jun 2012
Originally Posted by IanPellant View Post
... It comes with the (HiSky) HT8 adapter which is best connected to a TX via a Futaba trainer port. The Futaba port supplies power from the TX to the adapter module. The alternate JR stereo plug trainer does not readily supply power (I had no luck with the Turnigy 9X) ...
See for a solution that worked for me:
http://www.rcgroups.com/forums/showthread.php?t=1871616
Remember: You have to mod the JR style trainer plug to enable power supply.
-mike-
Old Oct 28, 2014, 09:40 AM
Joined Sep 2013
-mike-
Well I was thinking on that but it's just 4ch...is there any other frsky ACCST receiver that is lightweight and PPM to use with Afromini32??
Old Oct 28, 2014, 12:43 PM
Germany, Berlin
Joined Jun 2012
in PPM mode this RX has 8 channels.
-mike-
Old Oct 28, 2014, 12:55 PM
Joined Sep 2013
-mike-
Old Nov 15, 2014, 01:25 AM
Joined Feb 2007
I don't know why but I had so much trouble setting this up with my FrSky Taranis X9D, but I did it.
Set the mode on the module to F (green LED).
Setup the model mix to
Code:
CH1   Ail   100
CH2   Ele  -100
CH3   Thr  -100
CH4   Rud  -120
Turn off the internal module
Turn on trainer port in slave mode
Binding needs to happen with the antennas extremely close to each other
I don't know why my mixer settings are different from what other people recommend but this setup works for me
Edit: look what I made with my 3D printer
http://eleccelerator.com/q-bot-tx-module-for-taranis/
It's a JR style module bay cover that contains the Q-Bot transmitter
frank26080115 is offline Find More Posts by frank26080115
Old Nov 15, 2014, 06:05 PM
Joined Feb 2013
Code:
CH1   Ail   100
CH2   Ele  -100
CH3   Thr  -100
CH4   Rud  -120
Your channel ordering is Futaba sequence - as per Q-Bot instructions; Channel reversing does seem to vary between tx brands. My Turnigy 9XR has CH 1&2 NOR; CH 3&4 REV. The Q-Bot instructions have CH 3 NOR.... that is Throttle and is opposite to what I needed to set... first binding was a ceiling intercept event.
Like your TX bay cover adaptation of the HT8 adapter. Why HiSky don't do it is a mystery.
Their illustrations of using tape on the back to mount to the TX is just so inept... the battery cover is flimsy and will pull off; the adapter is out of sight so cannot be monitored and the antenna cannot swing forward / away from the TX... a truly poor way to mount the thing.
I have a new HiSky FF120 (original Q-Bot) in the mail from Banggood... yet another HT8 adapter. I'm wondering if it is any different to the Turnigy rebrand that came with the micro Q-Bot and the FBL100.... about time to do some mods on one of them.
New Product BNF Spectrum/JR DSM2-DMSS compatible REDCON HiBiRD Mini 120mm Quadcopter richos Mini Multirotors 37 Oct 25, 2014 06:20 AM
Sold $60 Shipped -- FlySky CT-6B Tx and Six 6-Channel Rx's (Compatible with 9X) Cobra68 Aircraft - General - Radio Equipment (FS/W) 2 Feb 09, 2013 12:00 PM
Sold Hobby King 2.4 ghz Spektrum compatible Receiver = $18 shipped shawn595 Aircraft - General - Radio Equipment (FS/W) 3 Aug 07, 2010 03:35 PM
