Old Yesterday, 03:17 AM
Joined Dec 2013
600 mAh batteries rock! Almost got tired of flying (and that young cat that chased the copter had even more fun, it seems). Didn't measure the time, but that was Long.
Cut-off at 3.35V (checked at home)
PS. Considering a proper way to attach velcro tape to the copter for battery mod.
Mister_AL is offline Find More Posts by Mister_AL
Old Yesterday, 01:34 PM
Joined Dec 2013
You will get about 15 minute or so out of the 600mA so I have my timer on my 9X set at 12 minutes. But your right it seems like forever before it runs out of battery. I got four 600mA and the one 350mA so I can pretty much fly for an hour strait
As for the battery... Take the screw out of the stock battery holder and remove it.. Take the JST connector out of it, then pretty much cover the bottom of the X1 with Velcro. That is how I did mine.
FLDataTeK is offline Find More Posts by FLDataTeK
Old Yesterday, 01:56 PM
DirtyDovi's Avatar
United States, NY, Cortland
Joined Apr 2013
For aftermarket batteries -
Remove the stock battery tray from the bottom of the frame..
Since these center sections are set up in X configuration,
there isn't much of a surface area to work with.. So..
I've always made and used a plastic piece like the one pictured.
If you have an old CD case, the black back section works great..
The velco or even better 'dual lock' only needs to be about the size
of a nickel, so, the plastic plate really only needs to be about
the size of a quarter..
I usually make the plate 1" diameter.
From there, use some sandpaper to rough up the bottom of the frame,
and the plate too [that's adding 'tooth' for the glue to adhere to]
You can use CA glue or hot glue. Both work great..
Hit the frame center and go out far enough to glue the plastic on..
Center up the plastic, glue in place, attach velcro / dual lock, and done!
Edit: I found a better pic of an old X1 frame -
DirtyDovi is online now Find More Posts by DirtyDovi
Old Yesterday, 03:11 PM
Joined Apr 2012
The UPS man picked a great day to come earlier than usual. My new X1 is charging!
stevenator128 is offline Find More Posts by stevenator128
Old Yesterday, 05:04 PM
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Hi Sam, Good to hear from you. I was just thinking if you were okay last night. And here you are.
Heli Pad is online now Find More Posts by Heli Pad
Old Yesterday, 07:32 PM
Childlike Activity for Adults
jbrumberg's Avatar
United States, MA, Cummington
Joined Dec 2012
Hopefully in a few weeks I too will be returning to the world of RCG. Aging parent issues has necessitated my recent absence from this and all other threads here at RCG and all other sites where I have been a frequent flier. I should be as healthy, feisty, and as cognitively intact at 91 y.o. as my Father is presently.
At least I am now able to fly vicariously through the members here and elsewhere.
The RC withdrawal has been extreme, but I will probably make it if I can survive this horrid heat in FL.
That smell is me rotting in the heat.
jbrumberg is online now Find More Posts by jbrumberg
Latest blog entry: Improving Visibility
Old Yesterday, 08:01 PM
Winter, bah humbug.
4_Props's Avatar
United States, NY, Fulton
Joined Aug 2013
Good luck with your parents, my Mom is also failing.
Enjoy the weather it's been freezing up here.
I'm sending you a PM.
4_Props is offline Find More Posts by 4_Props
Latest blog entry: .
Old Today, 03:16 AM
Joined Dec 2013
oh, that "Since these center sections are set up in X configuration, there isn't much of a surface area to work with" was exactly my problem )) Like the idea of a plastic piece, but will wait for the camera to arrive - first wanna have all the gear, then start making serious mods.
Asking again:
I have found an old RC antenna from a toy, Metal stick 27cm long. Does it make any sense to connect it to the built-in antenna of the stock RC (I don't plan to change it yet)?
Old Today, 04:05 AM
Ain't crashing often anymore
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Asking again:
No. The X1 works on 2.4GHz, best antenna length for this application is λ/4=31,25 mm
-mike-
mikefromgermany is online now Find More Posts by mikefromgermany
Latest blog entry: Casal C6P Charger Review
Old Today, 09:39 AM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
The little tabs on the sides work great to hook a few of your kids' rainbow loom bands going in opposite directions. It holds the battery on just fine.
We had 9 guys flying in our church gymnasium the other night. First, a limbo competition. The Pylon racing. Finally, demolition derby! Touching another quad and recovering is 1 point. Flipping into another quad is 3 points.
Bunch of boys at the playground, it was a blast.
The only casualties were one broken boom and a few cut wires. Few minutes on the soldering iron and all like new!
Telemachus is offline Find More Posts by Telemachus
Old Today, 12:36 PM
DirtyDovi's Avatar
Joined Apr 2013
Thanks bro!
Yeah, just hibernating again..
That warm weather got me out and about, but it was short lived..
It's definitely nice to catch up with you guys again!
Old Today, 12:38 PM
DirtyDovi's Avatar
Joined Apr 2013
Nice idea!
I never even thought of using those frame-tabs before...
Before I hacked of my goatee, I had hundreds of those mini rubber bands too!
That's awesome that you guys got to get a little crazy with your quads!
Sounds like you had a little too much fun! haha
Glad that the repairs are simple enough that you'll get things back in action!
Discussion Syma 2012 new publish, syma X1, S800G, S107C,S036G,what's better wjh041 Coaxial Helicopters 9 Jun 20, 2013 03:07 AM
New Product Syma X1 Quadcopter Spare Parts wjh041 Beginner Training Area (Aircraft-Electric) 1 Nov 03, 2012 05:55 PM
