Old Apr 18, 2011, 01:55 PM
choopi's Avatar
New Brunswick
Joined Feb 2006
HET Super Sniper 70 MM
I was looking around for a nice 70mm EDF... Not much info on the HET Super Sniper 70mm http://www.highendrc.com/index_eprod...?products_id=9
Is there is something wrong with it? Also anice one is from Proedf:
http://www.proedf.com/index.php?p=6&lang=en&ev=&id=8
For power I was looking at HET6904 or equivalent on 3000mah 4s pack.
Any comment?
choopi is offline Find More Posts by choopi
Old Apr 19, 2011, 01:16 PM
Dublin Ireland
Joined Aug 2005
My first EDF that lasted a few flights was a sniper.I really enjoyed it while it lasted. There was a good build with photos on the Warbirds site I think it was under experimental . The only problems I found was the fuzz is polyester and crumples very easy and the wings can fold in flightvif flown too fast.
Cheers
Steve
STEVEAIR2 is online now Find More Posts by STEVEAIR2
Old Apr 19, 2011, 03:53 PM
Lipo abuser ... smoke on!
gp125racer's Avatar
Joined Feb 2005
Super sniper on a 6904 with a 2w20 is an awesome setup. We built one to test our bungee setup. While our bungee launcher didn't work out so well, the sniper was a blast.
Don
gp125racer is offline Find More Posts by gp125racer
Latest blog entry: D100
Old Apr 19, 2011, 07:02 PM
skunkworks
Dark Angel's Avatar
United States, CA, Clovis
Joined Apr 2008
Right now the super sniper is cheaper than the silva.
Dark Angel is offline Find More Posts by Dark Angel
Old Apr 19, 2011, 09:27 PM
choopi's Avatar
New Brunswick
Joined Feb 2006
Fair enough! Super sniper, they only thing I could see that need atention is reinforce the wing with fiberglass where they join. As for setup the HET6904 on 4s should do it. Such a small airframe.
Old Apr 19, 2011, 11:18 PM
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Yep, we've got them on sale here:
http://www.ejf.com/index.php?main_pa...roducts_id=241
Talk to Robert, he'll give you the low-down on the recommended mods. You're right though, beefing up the wing is an absolute must. I'd probably run a carbon rod through it and glass the center too. Great flying sport-type jet.
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Apr 20, 2011, 05:50 PM
choopi's Avatar
New Brunswick
Joined Feb 2006
deleted
Old Apr 21, 2011, 06:12 PM
choopi's Avatar
New Brunswick
Joined Feb 2006
I got one of those that I planning to use in there.
Old Apr 21, 2011, 07:31 PM
Joined Jul 2004
That one of the original Sapac 70's??
4s 2600's 35c should keep the weight down and give you a solid 600 watts.
Old Apr 21, 2011, 08:06 PM
choopi's Avatar
New Brunswick
Joined Feb 2006
Ya good Sapac 70, should be fair with that airframe!
Old Mar 18, 2013, 03:12 PM
Joined Oct 2009
Looks like I'm late to the party again with another old classic
I finally maidened my first gen 70mm HET Super Sniper.
Really didn't know what to expect, as I had to add a bunch of lead to the tail and it was still nose heavy at the recommended 90mm CG. Well I loaded up 16lbs of pull on the bungee and she fired off the ramp! Needed only 2 clicks of trim to fly straight.
Seems to be a good flyer so far, a little draggier than I thought, although I flew in sub-zero temperatures. I fitted a CS10/HET 2W-30 on 2X2200mah 3S 45-90C nano's that put out 1125watts and 52 amps static on the ground. At least it made a fantastic intake roar.
Hope to get some videos up soon.
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Mar 18, 2013, 04:07 PM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
wemo mini pro, mega 16/25/1,5r 3750kv, 4s 3300--4000mah. great set up. much more efflux then those aweful CS10 fans.
with a wemo, pinch the tube to 52-53mm for speed
stoneenforcer is online now Find More Posts by stoneenforcer
Old Apr 09, 2013, 06:03 PM
Joined Oct 2009
Flight video from last weekend...
HET 70mm Super Sniper 6S (1 min 51 sec)
Wings haven't folded...YET
P.S. exhaust tube is at 52mm
Old Apr 09, 2013, 08:32 PM
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Wings wont fold right at joint but a few inches out from center were the spar ends...thats were mine folded and it is not pretty when it does....
fh64_lucky is online now Find More Posts by fh64_lucky
Old Apr 10, 2013, 03:13 AM
Aka: Tom Jenkins
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
turn the auto focus off!
ApexAero is online now Find More Posts by ApexAero
Sold Het F-18 Parts, 70 mm bruff Aircraft - Electric - Jets (FS/W) 0 Apr 12, 2011 09:17 PM
For Sale HET Super Sniper for sale awat6508 Aircraft - Electric - Jets (FS/W) 2 Mar 14, 2011 10:35 PM
For Sale Het super sniper 70 mm hondaboy92hatch Aircraft - Electric - Jets (FS/W) 8 Jun 29, 2010 09:48 AM
For Sale Het Sniper 70 mm hondaboy92hatch Aircraft - Electric - Jets (FS/W) 7 Jun 21, 2010 07:30 AM
Discussion HET Super Sniper 70 mm EDF rcairplaneking Electric Ducted Fan Jet Talk 4 Jan 28, 2010 12:53 PM
